August 24, 20242 yr Hello Team, For a while, I don't remember when exactly, Enpass won't come in foreground when using Mission Control. I use it a lot on my Mac and it's very frustrating. Every time I'm selecting Enpass's main window with Mission Control he stay in foreground for half a second and then return in background. If i open the preference window of Enpass and trying to select it with Mission Control it work well. I've just tried to uninstall Enpass (using Pearcleaner) restart my computer and reinstall it and the behavior didn't change. Have you any fix or debug step to try to return to correct operation ? Thanks a lot ! Enpass version : 6.11.2 (1753) MacOs version : 14.6.1 Edited August 24, 20242 yr by Inkx adding some test info
August 28, 20242 yr I've reported this issue to the Enpass technical team. They are currently investigating it, and I will reach out to you with updates as soon as I receive them. #SI-3976
September 2, 20242 yr Please provide the following details: Which device are you using? Is there a specific scenario in which the issue occurs, or does it happen every time? Does the issue occur in windowed mode, full screen mode, or both? Could you please share a video of the issue so that we can analyze it further?
September 3, 20242 yr Author 20 hours ago, Amandeep Kumar said: Please provide the following details: Which device are you using? Is there a specific scenario in which the issue occurs, or does it happen every time? Does the issue occur in windowed mode, full screen mode, or both? Could you please share a video of the issue so that we can analyze it further? Hello here is the answer 1. MacBook Pro M3 - 14.6.1 2. Every time 3. Windowed 4. Flow the link to download the video : https://dropover.cloud/f81914 Thank you !
September 19, 20242 yr Author Hello, just to informe that the bug still persist with MacOS Sequoia 15.0
September 21, 20242 yr I have a similar issue in Sequoia 15.0, final release. The app installed fine, it opens without issues, the browser extensions are working properly (Firefox and Safari), but when the Enpass window is closed (command-W), the application cannot come back to the foreground when called again. It flashes very fast at a rate of 5-10 times a second and the app icon keeps showing up in the dock every time the app tries to come back to the front. This also happens if I option-click on the Desktop to send Enpass to the background. The only 2 solutions I found are: 1. click on the Enpass icon in the Menu Bar, then click open Enpass. 2. do not close the window app (command-W) but send it to the dock (command-M). It then reopen without a problem like with the command-W method before Sequoia. Mac Studio M1 Max macOS Sequoia 15.0 (fresh install) Edited September 21, 20242 yr by fermati
September 24, 20242 yr The same thing is happening on another volume where I had Sonoma installed. Afetr upgrading to Sequoia (no fresh install here), the same behavior described above started to happen. It never occurred with any previous macOS. Is a solution underway?
October 30, 20242 yr Author Updated to MacOS 15.1 and the issue still active with Enpass's version 6.11.4 (1803)
October 30, 20242 yr 5 hours ago, Inkx said: Updated to MacOS 15.1 and the issue still active with Enpass's version 6.11.4 (1803) macOS 15.1 is not causing the problem to come back here after the update yesterday (v6.11.4).
November 5, 20242 yr Author I know that is not an OS's issue. I'm just taking advantage of the information to follow up on my problem. The problem we're having is not quite the same. Mine occurs when using Mission Control. I'm adding a link to a screen recording of the problem. https://dropover.cloud/5eb6dc#40040396-d6f4-40f5-8eb1-94d87f508a06 @Amandeep Kumar can i have an update about this please ? Thanks a lot
November 13, 20241 yr Author Hello, after Enpass update to 6.11.5 (1819) the issue is fixed ! Thanks EDIT : The bug came back after quitting and reopening it fix the issue. Will see if it happen again EDIT 2 : It seems that the issue happened after I have hide Enpass (cmd+H). Soon as the app have bee hide once the bug come and persist until quit and relaunch Enpass Edited November 14, 20241 yr by Inkx
November 26, 20241 yr The technical team is investigating the issue and working on a solution. We appreciate your patience and understanding as we work to resolve it.
December 20, 20241 yr Author Hello, just to follow up. After Enpass update 6.11.7 (1859) the issue is still present
December 20, 20241 yr Thanks for the info, Inkx. I will not take the risk of seeing that bug coming back here, so I'll skip that update.
January 22, 20251 yr The technical team is still investigating the issue and working on a solution. While we don't have an estimated timeline for its release, it will be made available as soon as it's ready.
April 23, 20251 yr Author Any kind of No information on when a fix is in progress? This bug is really annoying... Do you need any other information?
June 17, 20251 yr Regrettably at this time, we don’t have any new updates to share. Please be assured that our technical team is promptly working on fixing this on the upcoming releases and we will keep this thread informed.
