October 19, 20242 yr Import data to primary I have two vaults one primary and another. would like to replace all the data from the primary with the second. I have made a backup of the second and I would like to import the data from the second to the primary, how can I do it? Thank Hispa
October 21, 20242 yr You could just easily move all your data from Vault#2 to Vault#1 by following these steps: 1. Select Vault#2 in the generall Enpass window. 2. Click on any entry and then hit "CTRL + A" to select all entries. 3. Rightclick on the marked entries. 4. Select "Add to Vault" 5. In the new window choose Vault#1 and hit "Move to Vault" 6. You're all set and done.
