April 29, 20251 yr I accidentally have a few items in my Enpass database with a trailing space in my email address. E.g. "myname@example.com ". I like to find those entries, but when I search for that, Enpass searches for "myname@example.com", and finds basically all records. Is there any way I can figure out which records have a trailing space in the email address? Sadly, going over each one manually won't work, since I have >500 records in Enpass by now...
April 30, 20251 yr I guess one way to do this kind of easy would be exporting your entire vault and then searching in the created file for the affected entries. Then you could either clear all current entries in your vault and import the corrected export file. Or manually open all entries (after finding them in the exported file) and correct them. Not a nice way, but from my pov and knowledge the fastest/easiest.
April 30, 2025Apr 30 Author 5 hours ago, AnakinCaesar said: I guess one way to do this kind of easy would be exporting your entire vault and then searching in the created file for the affected entries. That is a good approach! I quickly found the two affected records, and fixed it. Thanks for the suggestion!
