Enpass 6.11.12 update constantly crashes on Big Sur 11.6
Hi all
I updated Enpass just now to v6.11.12 via the App Store and now it won't start at all....it just crashes every single time.  This sort of BS is far too common with Enpass and I'm sick of it.
When will it be fixed?  I use Enpass constantly every single day and need it working ASAP.
What info is required to help troubleshoot?
Cheers, Gary
EDIT: It looks like v6.11.12 only works with Ventura and yet the App Store updated my install on Big Sur.  For frig's sake, Enpass, how did you allow an updater to install on an unsupported version of macOS????!?  Where can I download an earlier version that'll run on 11.6? I need this ASAP.
Edited by Maddcow
same with Catalina: Enpass 6.11.12 gets installed and immediately crashes when I try to start the app. I hope you fix this quickly.
And that's really not funny: no indication in the Apple Store that the system requirements have been changed. And how is it possible that the update can still be carried out with Catalina? I would expect that the update cannot be carried out.
Should I open a separate Catalina thread for this?
And yes: a direct download link to the version before would be great ; )
Many thanks and best regards
Stefan
Crash Log:
Process:               Enpass [729]
Path:                  /Applications/Enpass.app/Contents/MacOS/Enpass
Identifier:            in.sinew.Enpass-Desktop
Version:               6.11.12 (2002)
App Item ID:           732710998
App External ID:       875520945
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Enpass [729]
User ID:               501
Date/Time:             2025-06-18 17:54:58.047 +0200
OS Version:            Mac OS X 10.15.7 (19H2026)
Report Version:        12
Anonymous UUID:        1C3688FC-7F10-F65D-CDDA-BE2012D98AF6
Time Awake Since Boot: 1800 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Segmentation fault: 11
Termination Reason:    Namespace SIGNAL, Code 0xb
Terminating Process:   exc handler [729]
VM Regions Near 0:
    __TEXT                 000000010e869000-0000000112a21000 [ 65.7M] r-x/r-x SM=COW  /Applications/Enpass.app/Contents/MacOS/Enpass
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   ???                               000000000000000000 0 + 0
1   in.sinew.Enpass-Desktop           0x00000001106aea16 0x10e869000 + 31742486
2   in.sinew.Enpass-Desktop           0x00000001106ae70c 0x10e869000 + 31741708
3   in.sinew.Enpass-Desktop           0x000000010efb88f2 0x10e869000 + 7665906
4   in.sinew.Enpass-Desktop           0x000000010eee96bf 0x10e869000 + 6817471
5   in.sinew.Enpass-Desktop           0x000000010eee90d7 0x10e869000 + 6815959
6   in.sinew.Enpass-Desktop           0x000000010f01a760 0x10e869000 + 8066912
7   libdyld.dylib                     0x00007fff6ee41cc9 start + 1
Thread 1:
0   libsystem_pthread.dylib           0x00007fff6f045b68 start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00000000ffffffff  rbx: 0x0000600002a8d380  rcx: 0x0000600002088000  rdx: 0x0000000000000000
  rdi: 0x000000000007407c  rsi: 0x00007fff6c162750  rbp: 0x00007ffee13966c0  rsp: 0x00007ffee1396668
   r8: 0x0000000000000000   r9: 0x0000000000000018  r10: 0x00000000000001d6  r11: 0x000000182d343668
  r12: 0x000000000007407c  r13: 0x000000000000000e  r14: 0x00007ffee1396718  r15: 0x00007ffee13967d8
  rip: 0x0000000000000000  rfl: 0x0000000000010286  cr2: 0x0000000000000000
Logical CPU:     2
Error Code:      0x00000014 (no mapping for user instruction read)
Trap Number:     14
Binary Images:
       0x10e869000 -        0x112a20887 +in.sinew.Enpass-Desktop (6.11.12 - 2002) <269AE6FD-1C76-37CB-8451-94B36930FD81> /Applications/Enpass.app/Contents/MacOS/Enpass
       0x11c086000 -        0x11c118267  dyld (750.7) <9F48F7F8-94D0-3793-99B7-DDEF657EF956> /usr/lib/dyld
    0x7fff308ab000 -     0x7fff308afffb  com.apple.agl (3.3.3 - AGL-3.3.3) <D5670F33-361F-3971-9382-290BB12EA788> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x7fff308b0000 -     0x7fff30aabff8  com.apple.avfoundation (2.0 - 1855.3) <0837D912-3783-35D6-A94A-E474E18600CF> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
    0x7fff30aac000 -     0x7fff30b78ffe  com.apple.audio.AVFAudio (1.0 - 415.75) <CAC3CA5F-FCF6-37EB-8F1A-090340E2C38E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framework/Versions/A/AVFAudio
    0x7fff30c98000 -     0x7fff30c98fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <C1FB2338-2D52-3884-BED3-071A82B1FD77> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff30c99000 -     0x7fff30cb0ff7  libCGInterfaces.dylib (524.2.1) <69118118-1CEC-3019-A36E-3EC2FF1CAD8F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff30cb1000 -     0x7fff3154cfcf  com.apple.vImage (8.1 - 524.2.1) <4B6AB2C1-7CF5-3FDA-AC1C-04E531AB9BCE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff3154d000 -     0x7fff316e2fef  libBLAS.dylib (1303.60.1) <C157903D-417A-322B-916E-DDCFE2AF97EE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff316e3000 -     0x7fff31a24fff  libBNNS.dylib (144.100.2) <69FA0C4F-B59D-374A-9DCF-E9FA79F332FD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff31a25000 -     0x7fff31dccfff  libLAPACK.dylib (1303.60.1) <6FEC8434-0C35-3528-A3DE-E3C78A748B6C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff31dcd000 -     0x7fff31de2ffc  libLinearAlgebra.dylib (1303.60.1) <AAC1A8DA-0B44-3D52-A03F-1DFED19D33BB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff31de3000 -     0x7fff31de8ff3  libQuadrature.dylib (7) <371F36A7-B12F-363E-8955-F24F7C2048F6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff31de9000 -     0x7fff31e59fff  libSparse.dylib (103) <B8A10D0C-4577-343D-B310-A3E81265D107> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff31e5a000 -     0x7fff31e6cff7  libSparseBLAS.dylib (1303.60.1) <CFFEAA75-99FB-369E-80A1-4BC73ADEBEA9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff31e6d000 -     0x7fff31ffffe3  libvDSP.dylib (735.140.1) <1586D162-55FD-3EC0-AFC7-975EAE2D0DD6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff32000000 -     0x7fff3217efe7  libvMisc.dylib (735.140.1) <61CF1106-41C2-3971-9187-BD1D53C00343> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff3217f000 -     0x7fff3217ffff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <4686AE53-FD05-302C-AC20-C014EFC2305F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff32180000 -     0x7fff321dfff0  com.apple.Accounts (113 - 113) <E2438070-30AB-3B89-AE63-1E485B92D108> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff32329000 -     0x7fff330e7ffb  com.apple.AppKit (6.9 - 1894.70.110) <058D0F31-D353-36D9-83CD-1709EBB1390E> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff33137000 -     0x7fff33137fff  com.apple.ApplicationServices (48 - 50) <A74C5919-EA2A-30FB-917E-09AAB26E96B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff33138000 -     0x7fff331a3fff  com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <87EA5DE1-506A-39FD-88BE-D8A3416C9012> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff3323c000 -     0x7fff3327aff0  libFontRegistry.dylib (274.0.5.1) <F3461C05-0370-359B-9F03-5C1C1F7763EC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff332d5000 -     0x7fff33304fff  com.apple.ATSUI (1.0 - 1) <5F513967-DDD7-3F22-AD14-8A38ABD9F2D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff33305000 -     0x7fff33309ffb  com.apple.ColorSyncLegacy (4.13.0 - 1) <4E0574BC-921B-33D4-916B-2DD60D141BF6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff333a3000 -     0x7fff333faffa  com.apple.HIServices (1.22 - 676) <14DF4D42-E24D-3EBD-9A9D-93124D8D6AA1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff333fb000 -     0x7fff33409fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <01B8B6B3-E2C3-3607-B34A-8283A7E0E924> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff3340a000 -     0x7fff3344fffa  com.apple.print.framework.PrintCore (15.4 - 516.2) <437BCF12-48D2-3770-8BC9-567718FB1BCA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff33450000 -     0x7fff3345aff7  com.apple.QD (4.0 - 413) <27A36D07-B5E9-32E6-87B6-3127F260F48D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff3345b000 -     0x7fff33468ffc  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <75344F8F-32CA-3558-B4E6-F56D498250E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff33469000 -     0x7fff3354aff2  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <43014BB0-6604-3513-AB52-8D8577204FA6> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff3354c000 -     0x7fff3354cfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <2FAE7F8D-2358-3B10-B47E-27B90B368557> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff3367f000 -     0x7fff3368dffc  com.apple.AuthenticationServices (12.0 - 1.0) <3EBBA3DB-1EC4-36C4-A7A6-E55555B1989B> /System/Library/Frameworks/AuthenticationServices.framework/Versions/A/AuthenticationServices
    0x7fff338e3000 -     0x7fff33c71ffa  com.apple.CFNetwork (1128.1 - 1128.1) <04F37E21-8AC6-35BF-8D2C-8ED954B09026> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff33ced000 -     0x7fff33cedfff  com.apple.Carbon (160 - 162) <0C07A0EC-9474-3A5E-82A0-FD98B7C83BD8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff33cee000 -     0x7fff33cf1ff3  com.apple.CommonPanels (1.2.6 - 101) <9F6E13D9-374B-386F-8E15-FDD6CE967859> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff33cf2000 -     0x7fff33fe6ff3  com.apple.HIToolbox (2.1.1 - 994.7) <1869947E-482B-30F2-A8A9-B8F78CA69F6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff33fe7000 -     0x7fff33feaff3  com.apple.help (1.3.8 - 71) <36483951-6F3E-3F7E-8A5B-191C2357EF17> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff33feb000 -     0x7fff33ff0ff7  com.apple.ImageCapture (9.0 - 1600.65.1) <19E8B178-4C4D-3779-8815-E905310F20EF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff33ff1000 -     0x7fff33ff1fff  com.apple.ink.framework (10.15 - 227) <284507AE-EF47-3ABC-86A4-669243DB1D33> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff33ff2000 -     0x7fff3400cffa  com.apple.openscripting (1.7 - 185.2) <C0F2228C-9B4D-3976-AE4F-56608176A9C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff3402d000 -     0x7fff3402dfff  com.apple.print.framework.Print (15 - 271) <0D9FB08F-EA87-3BE7-821B-C61BA5601050> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff3402e000 -     0x7fff34030ff7  com.apple.securityhi (9.0 - 55008) <390C6FAA-99BF-3924-9180-9EAE41D9C6BE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff34031000 -     0x7fff34037fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <9614A01E-8303-3422-A3BA-6CE27540E09A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff34038000 -     0x7fff341d0ffa  com.apple.cloudkit.CloudKit (867 - 867) <1B851180-FC00-357F-B6C1-BB0EA7D6D5CA> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
    0x7fff341d1000 -     0x7fff341d1fff  com.apple.Cocoa (6.11 - 23) <9C7AC07A-7C05-37D4-910C-E9CDB239AFA8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff341df000 -     0x7fff342d5fff  com.apple.ColorSync (4.13.0 - 3394.15) <97F94272-0DB2-307F-A2B6-4FEC74DB37A6> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff345c0000 -     0x7fff34ac9ffb  com.apple.audio.CoreAudio (5.0 - 5.0) <47923B12-3D14-328A-9C86-27A3A2A73068> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff34b1c000 -     0x7fff34b54fff  com.apple.CoreBluetooth (1.0 - 1) <23DBB313-A082-3C08-8E1F-2D31EE4247EF> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff34b55000 -     0x7fff34f50ff8  com.apple.CoreData (120 - 977.3) <CEAA4BC1-62AB-3702-B790-82A55EA10302> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff34f51000 -     0x7fff35083ff6  com.apple.CoreDisplay (1.0 - 186.6.15) <213D7011-8180-3CF4-9BE7-FB8F75DCDB95> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff35084000 -     0x7fff35504ff9  com.apple.CoreFoundation (6.9 - 1678.104) <CA9600EB-C7BE-38C4-968D-4BF90B1C9550> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff35506000 -     0x7fff35b9eff0  com.apple.CoreGraphics (2.0 - 1355.24) <9B167C47-1FDB-3D44-93D0-64CC7B30AB2A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff35bac000 -     0x7fff35f07ff0  com.apple.CoreImage (15.0.0 - 940.9) <69361069-01AB-342E-862B-73A74271A765> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff35f08000 -     0x7fff35f71ff0  com.apple.corelocation (2394.0.22 - 2394.0.22) <75966124-2FB7-33C3-BE49-3DD5F327F911> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
    0x7fff362c9000 -     0x7fff363a4ffc  com.apple.CoreMedia (1.0 - 2625.9.4.1) <516C5604-EDE4-3F50-BCE7-234BB99610E0> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff363a5000 -     0x7fff36407ffe  com.apple.CoreMediaIO (1000.0 - 5125.6) <164B4E4F-CFFD-3DB9-9873-97A9640C2213> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
    0x7fff36491000 -     0x7fff36491fff  com.apple.CoreServices (1069.28 - 1069.28) <45131B9C-99AA-340E-947F-E53F2C829F20> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff36492000 -     0x7fff36517fff  com.apple.AE (838.1 - 838.1) <450501B5-0161-38D0-8986-90718DC3CAE5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff36518000 -     0x7fff367f9ff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <BE379206-99FA-30CD-8391-2708473A633F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff367fa000 -     0x7fff36847ffd  com.apple.DictionaryServices (1.2 - 323.6) <26B70C82-25BC-353A-858F-945B14C803A2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff36848000 -     0x7fff36850ff7  com.apple.CoreServices.FSEvents (1268.100.2 - 1268.100.2) <D9B9A080-C59D-3A0D-BC7B-A67137C317C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff36851000 -     0x7fff36a8cff8  com.apple.LaunchServices (1069.28 - 1069.28) <07C85310-A894-344D-8181-CC1E68CA0C82> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff36a8d000 -     0x7fff36b25ff1  com.apple.Metadata (10.7.0 - 2076.7.2) <BB387ED8-F398-3016-B5FC-49202BDD182C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff36b26000 -     0x7fff36b53fff  com.apple.CoreServices.OSServices (1069.28 - 1069.28) <704B2084-2AF5-342E-A554-C0DE93229A3F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff36b54000 -     0x7fff36bbbfff  com.apple.SearchKit (1.4.1 - 1.4.1) <2C5E1D85-E8B1-3DC5-91B9-E3EDB48E9369> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff36bbc000 -     0x7fff36be0ff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <02DE0D56-E371-3EF5-9BC1-FA435451B412> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff36f05000 -     0x7fff370bdffc  com.apple.CoreText (643.1.5.8 - 643.1.5.8) <C6CBD65A-B081-3F0F-A5EE-2AEA10498FA4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff370be000 -     0x7fff37102fff  com.apple.CoreVideo (1.8 - 0.0) <D35529AE-8740-320B-BB12-D1E60FDAB06B> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff37103000 -     0x7fff37190ffc  com.apple.framework.CoreWLAN (13.0 - 1601.2) <CCF3BB09-A571-3589-917B-D646A4BDD7CC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff371c7000 -     0x7fff37207ff5  com.apple.CryptoTokenKit (1.0 - 1) <85B4A992-8B61-39FB-BCDE-05A2D5989D74> /System/Library/Frameworks/CryptoTokenKit.framework/Versions/A/CryptoTokenKit
    0x7fff3734c000 -     0x7fff37357ff7  com.apple.DirectoryService.Framework (10.15 - 220.40.1) <6EACB7D0-A013-3D2B-93D2-5113F7C2559D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
    0x7fff37358000 -     0x7fff37402ff0  com.apple.DiscRecording (9.0.3 - 9030.4.5) <726E7C26-239D-3343-9E3A-2C171CF79E8B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff37427000 -     0x7fff3742dfff  com.apple.DiskArbitration (2.7 - 2.7) <C5272B1C-C2D1-3A64-8116-3AC6FAB9E18B> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff37622000 -     0x7fff37751ff6  com.apple.FileProvider (304.141.2 - 304.141.2) <D0854CAD-19E0-39CB-A5A4-A3C4F2ED369A> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff37769000 -     0x7fff37b2eff7  com.apple.Foundation (6.9 - 1678.104) <69B915AD-CE6F-3958-8E3A-9D6050989AC2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff37b9b000 -     0x7fff37bebfff  com.apple.GSS (4.0 - 2.0) <993DB520-C98D-35BB-844D-562EC1A24514> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff37d28000 -     0x7fff37e3cff3  com.apple.Bluetooth (7.0.6 - 7.0.6f8) <E7634AA3-92E9-3E8A-80BA-0716B3E05C78> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff37ea2000 -     0x7fff37f46ff3  com.apple.framework.IOKit (2.0.2 - 1726.148.1) <0A9D244C-AECC-3D29-86DE-4F3B04F8DD25> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff37f48000 -     0x7fff37f59ffb  com.apple.IOSurface (269.11 - 269.11) <BCD744D4-E17E-3C2E-B69C-F69C789892E9> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff37fd8000 -     0x7fff38138ff6  com.apple.ImageIO.framework (3.3.0 - 1976.14.1) <8C43C897-A78F-339F-8B7C-1DC3F861349D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff38139000 -     0x7fff3813cfff  libGIF.dylib (1976.14.1) <6DAA6146-4508-3883-AF1A-7CF4B06B1D7D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff3813d000 -     0x7fff381f6ff7  libJP2.dylib (1976.14.1) <A324445F-79FF-38CE-8DBD-BD8749D045D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff381f7000 -     0x7fff3821bff7  libJPEG.dylib (1976.14.1) <A5037397-1DF9-3E34-AB1E-41ABF2AC7F55> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff38499000 -     0x7fff384b3ff7  libPng.dylib (1976.14.1) <B569035E-0E07-39D7-91AC-145618184EC9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff384b4000 -     0x7fff384b5fff  libRadiance.dylib (1976.14.1) <91EA6BBB-0797-3688-9C78-5F38FD04FE06> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff384b6000 -     0x7fff384fcff7  libTIFF.dylib (1976.14.1) <56CE66AC-2701-35CE-9891-3244F3B07FBA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff389a7000 -     0x7fff39a47fe1  com.apple.JavaScriptCore (15609 - 15609.4.1.1.1) <5CAFF570-DC41-32A9-9CFB-28210A9B8367> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
    0x7fff39a5e000 -     0x7fff39a70ff3  com.apple.Kerberos (3.0 - 1) <03BB492B-016E-37BF-B020-39C2CF7487FE> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff39a71000 -     0x7fff39a71fff  libHeimdalProxy.dylib (77) <0A2905EE-9533-3345-AF9B-AAC71513BDFD> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff39a72000 -     0x7fff39aa8ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <45AD36CB-D311-32A2-843C-ED6350A59B5A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff39bbc000 -     0x7fff39bdeffc  com.apple.CoreAuthentication.SharedUtils (1.0 - 693.140.3) <A3F9CE45-4F7A-3F5D-865C-6EB9B6C3B3B4> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/Versions/A/SharedUtils
    0x7fff39bdf000 -     0x7fff39bf5ff2  com.apple.LocalAuthentication (1.0 - 693.140.3) <5D391FD1-391B-390A-BBC1-62A537C8DAFE> /System/Library/Frameworks/LocalAuthentication.framework/Versions/A/LocalAuthentication
    0x7fff39e03000 -     0x7fff39e0dffb  com.apple.MediaAccessibility (1.0 - 125.1) <98065EA1-3484-3A5A-B05C-D2FABED8CEA4> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff39ed9000 -     0x7fff3a626ff2  com.apple.MediaToolbox (1.0 - 2625.9.4.1) <6AB09C34-154A-3CB0-8A64-6AA25335751A> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff3a628000 -     0x7fff3a6f2fff  com.apple.Metal (212.8 - 212.8) <98C944D6-62C8-355E-90F8-C1CA2429EF24> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff3a70f000 -     0x7fff3a74cff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <7EBAC15D-7837-395D-B405-1E29F7DA68FA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff3a74d000 -     0x7fff3a7d7fe2  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <B424FE0C-6E90-3BFA-A6E7-DD86C735AE90> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff3a7d8000 -     0x7fff3a7fdff4  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <02006D92-E2AB-3892-A96B-37F6520C19BA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff3a7fe000 -     0x7fff3a813ffb  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <CAA5A368-DB71-34F6-AEF9-27A8BC298F53> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff3a814000 -     0x7fff3a972ffc  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <05612E06-50CB-318F-9F8E-EF4D49FAB3B0> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff3a973000 -     0x7fff3a9c2ff4  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <B0B591F8-6875-351E-867F-8EB3CD38CD52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff3a9c3000 -     0x7fff3a9c4ff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <F2921F9A-3041-3495-878D-64134267B847> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff3b883000 -     0x7fff3b88fffe  com.apple.NetFS (6.0 - 4.0) <57CABC68-0585-3989-9161-157DBB544B82> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff3b890000 -     0x7fff3b9e7ff3  com.apple.Network (1.0 - 1) <7F64A643-A7D5-3089-AF96-78AAF943C1D3> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff3b9e8000 -     0x7fff3bc48ffa  com.apple.NetworkExtension (1.0 - 1) <D1E26D99-8D1D-3A19-A4E9-B5B1DEC4BD17> /System/Library/Frameworks/NetworkExtension.framework/Versions/A/NetworkExtension
    0x7fff3e419000 -     0x7fff3e471fff  com.apple.opencl (3.5 - 3.5) <405873C3-6C6E-307B-9813-8741E1CABD95> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff3e472000 -     0x7fff3e48efff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <7E6C88EB-3DD9-32B0-81FC-179552834FA9> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff3e48f000 -     0x7fff3e49affd  com.apple.OpenDirectory (10.15 - 220.40.1) <4A92D8D8-A9E5-3A9C-942F-28576F6BCDF5> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff3ee00000 -     0x7fff3ee02fff  libCVMSPluginSupport.dylib (17.10.22) <4DFF84FA-1F0C-3283-8F56-512344B725CE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff3ee03000 -     0x7fff3ee08fff  libCoreFSCache.dylib (176.21) <627E34BF-5E91-3D07-945B-1B9F3432BFB3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff3ee09000 -     0x7fff3ee0dfff  libCoreVMClient.dylib (176.21) <8A019B96-5D30-3140-B3D3-B6225E484BFD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff3ee0e000 -     0x7fff3ee16ff7  libGFXShared.dylib (17.10.22) <7D2BF684-33B2-32F5-A070-EA0AC692D10D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff3ee17000 -     0x7fff3ee21fff  libGL.dylib (17.10.22) <D782B7B9-CD02-35CC-833D-00A76DC28D2D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff3ee22000 -     0x7fff3ee56ff7  libGLImage.dylib (17.10.22) <F9E0AB2E-3123-361B-BB43-30111B03395B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff3efec000 -     0x7fff3f028fff  libGLU.dylib (17.10.22) <E5027491-0309-3E86-8435-1A1D0DA6C86F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff3fa64000 -     0x7fff3fa73ff7  com.apple.opengl (17.10.22 - 17.10.22) <BCC1E523-1843-3FF8-8F7D-29DA67756434> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff400d1000 -     0x7fff400d7ff6  com.apple.PushKit (1.0 - 1) <AD547A25-1A0B-3FA6-8676-82C37F267A4A> /System/Library/Frameworks/PushKit.framework/Versions/A/PushKit
    0x7fff40a31000 -     0x7fff40cb4ffb  com.apple.QuartzCore (1.11 - 841.6) <DCD6050B-DB0E-3469-B18B-3DF3FAE77DEC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff41215000 -     0x7fff41230ff6  com.apple.SafariServices.framework (15613 - 15613.3.9.1.16) <986B5C11-ED3F-3BEB-9B69-7C6DC179A879> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
    0x7fff41838000 -     0x7fff41b83ff9  com.apple.security (7.0 - 59306.140.11) <3B46FC31-708A-3526-B888-BB7C1A9FBD98> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff41b84000 -     0x7fff41c0cffb  com.apple.securityfoundation (6.0 - 55236.60.1) <954B6238-07CB-3357-BC4F-AE827DD3F9E3> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff41c0d000 -     0x7fff41c3aff7  com.apple.securityinterface (10.0 - 55139.120.1) <D25421B0-F6F6-34DA-BA33-258447A972C9> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
    0x7fff41c3b000 -     0x7fff41c3fff8  com.apple.xpc.ServiceManagement (1.0 - 1) <055976F5-69DF-3846-B7CC-D72FA09D1A98> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff41f73000 -     0x7fff41f90ff9  com.apple.StoreKit (1.0 - 1) <D39EA2FD-A7E7-341F-80BD-18912272CAFE> /System/Library/Frameworks/StoreKit.framework/Versions/A/StoreKit
    0x7fff428eb000 -     0x7fff42965ff7  com.apple.SystemConfiguration (1.19 - 1.19) <D3494EFE-F392-379E-B21C-0F1B094ECE77> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff42b2e000 -     0x7fff42b63ff2  com.apple.UserNotifications (1.0 - ???) <8DB163D1-66F0-3B52-933F-48F945E3FF4D> /System/Library/Frameworks/UserNotifications.framework/Versions/A/UserNotifications
    0x7fff42be5000 -     0x7fff42f68ff4  com.apple.VideoToolbox (1.0 - 2625.9.4.1) <65ABE2CC-8180-397A-B783-EC7449871985> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff4320a000 -     0x7fff439a7fe7  libwebrtc.dylib (7609.4.1.1.1) <C7174FA6-6A0C-3F13-9A64-C262A6655A5D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
    0x7fff439a8000 -     0x7fff45c12ffb  com.apple.WebCore (15609 - 15609.4.1.1.1) <75D5D854-2A87-3C42-A5A4-A7CA11A56B5C> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
    0x7fff45c13000 -     0x7fff45e1fffb  com.apple.WebKitLegacy (15609 - 15609.4.1.1.1) <4F71E2AC-239D-322C-8CF9-AA74CA16341A> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
    0x7fff45e20000 -     0x7fff46525ffd  com.apple.WebKit (15609 - 15609.4.1.1.1) <898C11F5-0EB7-3CF3-840A-F2168D1B0805> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
    0x7fff468d5000 -     0x7fff4699afe7  com.apple.APFS (1412.141.3 - 1412.141.3) <E1179E8D-56DC-3F20-9C5E-B960D608F053> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff46fe6000 -     0x7fff46ff1ffc  com.apple.accessibility.AXCoreUtilities (1.0 - 1) <34D2C8C5-0BBC-39CA-B37C-B053A9C327EF> /System/Library/PrivateFrameworks/AXCoreUtilities.framework/Versions/A/AXCoreUtilities
    0x7fff472ea000 -     0x7fff4739bff6  com.apple.accounts.AccountsDaemon (113 - 113) <F8B91912-80AD-34C0-99CC-4A3569D9F6FD> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
    0x7fff47aaf000 -     0x7fff47ab0ff1  com.apple.AggregateDictionary (1.0 - 1) <95A291F5-B69F-3C37-9483-C3B2EBF52AC1> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff4804a000 -     0x7fff48067ff4  com.apple.AppContainer (4.0 - 448.100.6) <87CEE13C-8585-3EFB-92CD-0852DFF0921B> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff48068000 -     0x7fff48088fff  com.apple.AppSSO (1.0 - 1) <660152F4-68DE-3909-AE65-EC6EFAACB44C> /System/Library/PrivateFrameworks/AppSSO.framework/Versions/A/AppSSO
    0x7fff480bc000 -     0x7fff480caff7  com.apple.AppSandbox (4.0 - 448.100.6) <0F49AA04-3400-349A-9096-6D4D7ED61027> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff480cd000 -     0x7fff4812bff5  com.apple.AppStoreDaemon (1.0 - 1) <45A8F3C3-E165-37CD-BC70-1D83EBEEAC39> /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Versions/A/AppStoreDaemon
    0x7fff484b5000 -     0x7fff4851aff7  com.apple.AppSupport (1.0.0 - 29) <7408886B-B0CC-3EF0-9F11-9088DEE266ED> /System/Library/PrivateFrameworks/AppSupport.framework/Versions/A/AppSupport
    0x7fff48546000 -     0x7fff4856affb  com.apple.framework.Apple80211 (13.0 - 1610.1) <33B50F2F-88CD-3B02-B72E-1E1B916A7FC9> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff48828000 -     0x7fff48837fd7  com.apple.AppleFSCompression (119.100.1 - 1.0) <466ABD77-2E52-36D1-8E39-77AE2CC61611> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff48936000 -     0x7fff48941ff7  com.apple.AppleIDAuthSupport (1.0 - 1) <74F6CD9C-27A7-39C7-A7EB-47E60D2517EB> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff48942000 -     0x7fff48982ff1  com.apple.AppleIDSSOAuthentication (1.0 - 1) <C185B6DB-B784-3C52-983B-EA9B866327B0> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/Versions/A/AppleIDSSOAuthentication
    0x7fff48983000 -     0x7fff489cbff7  com.apple.AppleJPEG (1.0 - 1) <6DE30A07-C627-319B-A0DE-EB7A832BEB88> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff489dd000 -     0x7fff48d81ffd  com.apple.AppleMediaServices (1.0 - 1) <533DB7DE-4799-3A05-B75F-AEE8B45FF6F5> /System/Library/PrivateFrameworks/AppleMediaServices.framework/Versions/A/AppleMediaServices
    0x7fff48d8e000 -     0x7fff48db4ffb  com.apple.aps.framework (4.0 - 4.0) <3ED300B6-43E3-31DC-B3C6-6A0FF41A2595> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
    0x7fff48db5000 -     0x7fff48db9ff7  com.apple.AppleSRP (5.0 - 1) <70C25EA9-F7A7-366C-97C6-EEE7845FFCC3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff48dba000 -     0x7fff48ddcfff  com.apple.applesauce (1.0 - 16.25) <68E0364C-AEA7-3654-A030-136BF3CD92F3> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff48e9c000 -     0x7fff48e9ffff  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <67255151-F989-39F0-BC87-0C0BDAE70730> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff48ea0000 -     0x7fff48ef0ff7  com.apple.AppleVAFramework (6.1.2 - 6.1.2) <5BBCA7FB-5435-30CA-862F-D82437C383C2> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff48f39000 -     0x7fff48f48ff9  com.apple.AssertionServices (1.0 - 223.140.2) <48AD21CA-B81D-380E-A04F-90C48FDA5203> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff4948b000 -     0x7fff49886ff8  com.apple.audio.AudioResourceArbitration (1.0 - 1) <2BD68521-C19C-3D67-B5EB-DE3E9A4DAF0A> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff49adc000 -     0x7fff49d1dff8  com.apple.audio.AudioToolboxCore (1.0 - 1104.104) <AB379BF7-A824-3F9C-BF26-BC3BE44A575F> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff49d21000 -     0x7fff49e3dfff  com.apple.AuthKit (1.0 - 1) <DC1A27C5-0172-3C72-9B24-06996D0B6207> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff49e3e000 -     0x7fff49ed9ffd  com.apple.AuthKitUI (1.0 - 1) <A36F5C29-2391-3FDF-80CB-1AF83779E85D> /System/Library/PrivateFrameworks/AuthKitUI.framework/Versions/A/AuthKitUI
    0x7fff49fe3000 -     0x7fff49ff9ff8  com.apple.BackBoardServices (1.0 - 1.0) <18DEEF47-BA8F-38B9-A49A-C56C2BACE1CC> /System/Library/PrivateFrameworks/BackBoardServices.framework/Versions/A/BackBoardServices
    0x7fff49ffa000 -     0x7fff4a003ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <A6877DAD-8F47-363C-983A-DC8DDE83B7B5> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff4a004000 -     0x7fff4a0a5ff5  com.apple.backup.framework (1.11.8 - 1298.8.1) <196068B7-B3E8-3CC5-8875-9121190AD954> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff4a0a6000 -     0x7fff4a132ff6  com.apple.BaseBoard (466.3 - 466.3) <10D0F3BB-E8F3-365E-8528-6AC996A9B0E7> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff4a151000 -     0x7fff4a157ffa  com.apple.BezelServicesFW (336 - 336) <A97A4311-A5FC-3A94-8EC6-25759ACF4BF9> /System/Library/PrivateFrameworks/BezelServices.framework/Versions/A/BezelServices
    0x7fff4a203000 -     0x7fff4a233ffa  com.apple.BoardServices (1.0 - 466.3) <95D829A0-6339-35F7-BC46-5A54AE62DB30> /System/Library/PrivateFrameworks/BoardServices.framework/Versions/A/BoardServices
    0x7fff4a234000 -     0x7fff4a270ff7  com.apple.bom (14.0 - 219.3) <CE0B1297-4B57-3D61-9B7A-1C945742A4CE> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff4a38e000 -     0x7fff4a3c5ff5  com.apple.C2 (1.3 - 495) <4A7E2A63-E19A-3936-92F5-03F2FD602172> /System/Library/PrivateFrameworks/C2.framework/Versions/A/C2
    0x7fff4adf0000 -     0x7fff4ae3ffff  com.apple.ChunkingLibrary (307 - 307) <5B09C30D-FD2B-3E98-8B64-C5EF470FC13C> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff4af9a000 -     0x7fff4b025ff8  com.apple.CloudDocs (1.0 - 698.20) <F28635C0-9935-31FF-8EE1-ADD6972F8848> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
    0x7fff4bcec000 -     0x7fff4bcfcffb  com.apple.CommonAuth (4.0 - 2.0) <16117F3D-4803-3A1E-8CE5-078245DB978F> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff4bd10000 -     0x7fff4bd27fff  com.apple.commonutilities (8.0 - 900) <F4C97244-E5D8-3F7D-8D94-4B6841C5A4EC> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff4c42e000 -     0x7fff4c803fc8  com.apple.CoreAUC (283.0.0 - 283.0.0) <4341271C-D270-3F9F-8464-31A20D15158D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff4c804000 -     0x7fff4c831ff7  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <C3CFDC68-C7D9-3C44-9E7C-801D45575C10> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff4c854000 -     0x7fff4c875ff4  com.apple.analyticsd (1.0 - 1) <5BEB8C96-A227-34D4-9F8C-2C06493C1C5B> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff4cb81000 -     0x7fff4cb8cff7  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <BB7D67B1-2102-3D71-9BB6-AEB8C6A6EBB2> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff4ce0d000 -     0x7fff4ce1dff3  com.apple.CoreEmoji (1.0 - 107.1) <7C2B3259-083B-31B8-BCDB-1BA360529936> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff4d45e000 -     0x7fff4d4c8ff0  com.apple.CoreNLP (1.0 - 213) <E70E2505-8078-324E-BAE1-01A2DA980E2C> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff4d786000 -     0x7fff4d78affb  com.apple.CoreOptimization (1.0 - 1) <0FFD7AA1-6E0B-395B-BCDC-73C1CCECC25B> /System/Library/PrivateFrameworks/CoreOptimization.framework/Versions/A/CoreOptimization
    0x7fff4d8f6000 -     0x7fff4d8feff8  com.apple.CorePhoneNumbers (1.0 - 1) <E4DAD514-0B3B-3E0B-8AEA-39B320FAAF03> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff4d8ff000 -     0x7fff4d95194b  com.apple.CorePrediction (1.0 - 1) <CDF739BA-70AA-3FA2-9E0E-2E1BFC348A59> /System/Library/PrivateFrameworks/CorePrediction.framework/Versions/A/CorePrediction
    0x7fff4e301000 -     0x7fff4e324fff  com.apple.CoreSVG (1.0 - 129.3) <F38189F9-C8F9-3D62-9D5F-3F520FB81724> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff4e325000 -     0x7fff4e358fff  com.apple.CoreServicesInternal (446.7 - 446.7) <65F53A22-6B61-382C-AAC2-B2C53F8FFB44> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff4e359000 -     0x7fff4e387ffd  com.apple.CSStore (1069.28 - 1069.28) <85962C9A-1EAC-3231-B387-86AFD07D5A79> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff4e8ac000 -     0x7fff4e942ff7  com.apple.CoreSymbolication (11.4 - 64535.33.2) <955BD339-F593-3A70-8C08-71989480CC93> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff4e9da000 -     0x7fff4eb06ff6  com.apple.coreui (2.1 - 609.4) <D8DA588B-CC17-339D-8D96-03B15100AE4C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff4eb07000 -     0x7fff4ecc0ffa  com.apple.CoreUtils (6.2.4 - 624.7) <F2AF53B1-8A90-3AE4-B958-E4C508D10DF0> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff4edfa000 -     0x7fff4ee0dff1  com.apple.CrashReporterSupport (10.13 - 15016.1) <D584FFA6-32C5-328B-BE77-2C256B2B116C> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff4eec6000 -     0x7fff4eed8ff8  com.apple.framework.DFRFoundation (1.0 - 252.50.1) <8162057E-E856-3451-9160-04AEDDECFFA4> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff4eed9000 -     0x7fff4eedefff  com.apple.DSExternalDisplay (3.1 - 380) <31ECB5FD-7660-33DB-BC5B-2B2A2AA7C686> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff4ef68000 -     0x7fff4efe2ff0  com.apple.datadetectorscore (8.0 - 659) <E7AEE55D-7C62-3F38-9C44-9EA3BECE27ED> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff4f02e000 -     0x7fff4f06bff8  com.apple.DebugSymbols (194 - 194) <040AE30B-CF2C-3798-A289-0929B8CAB10D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff4f06c000 -     0x7fff4f1f4ff6  com.apple.desktopservices (1.14.6 - 1281.6.1) <C2355E6B-C5F7-3E39-B778-B117BD4652C6> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff4f20a000 -     0x7fff4f216ff8  com.apple.DeviceIdentity (1.0 - 1) <9BD89DB6-F26F-32D8-99DE-A6CA18DECCFB> /System/Library/PrivateFrameworks/DeviceIdentity.framework/Versions/A/DeviceIdentity
    0x7fff4f40f000 -     0x7fff4f452fff  com.apple.DifferentialPrivacy (1.0 - 1) <92019C5F-2BE7-38A8-87D2-FF698B6461CC> /System/Library/PrivateFrameworks/DifferentialPrivacy.framework/Versions/A/DifferentialPrivacy
    0x7fff4f4a3000 -     0x7fff4f56bffe  com.apple.DiskImagesFramework (559.100.2 - 559.100.2) <71022C31-42C2-399C-9337-BBB3F40F77D8> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff4f56c000 -     0x7fff4f63fff1  com.apple.DiskManagement (13.0 - 1648.140.2) <640DBACE-B6EC-3C72-9F73-F484E891534E> /System/Library/PrivateFrameworks/DiskManagement.framework/Versions/A/DiskManagement
    0x7fff4f6ec000 -     0x7fff4f721ff7  com.apple.SystemConfiguration.EAP8021X (14.0.0 - 14.0) <D3F76E01-2F9F-33E1-B5C9-CAC6E01724C2> /System/Library/PrivateFrameworks/EAP8021X.framework/Versions/A/EAP8021X
    0x7fff4f722000 -     0x7fff4f726ff9  com.apple.EFILogin (2.0 - 2) <3BFE697B-469F-38F4-B380-4A4F4A37C836> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff5025a000 -     0x7fff5026fff2  com.apple.Engram (1.0 - 1) <83200CE7-9D5C-32B8-90B9-D762AC748D8B> /System/Library/PrivateFrameworks/Engram.framework/Versions/A/Engram
    0x7fff50bb4000 -     0x7fff50fcfff1  com.apple.vision.FaceCore (4.3.0 - 4.3.0) <5D32F65D-2CD7-3204-975C-F4C9256E505F> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff5166e000 -     0x7fff517a5ffc  libFontParser.dylib (277.2.6.9) <9EA679F4-CFF0-3FC9-87E0-71757CB7830B> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff517a6000 -     0x7fff517dafff  libTrueTypeScaler.dylib (277.2.6.9) <2CC0BB41-BC5C-3609-AA48-268B93639058> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
    0x7fff5183e000 -     0x7fff5184eff6  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <030D657D-634C-3A3E-8952-ED7F1C408D74> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff51852000 -     0x7fff518c9ff5  com.apple.FrontBoardServices (626.8 - 626.8) <2C044425-27FC-373A-94EE-4C0370001432> /System/Library/PrivateFrameworks/FrontBoardServices.framework/Versions/A/FrontBoardServices
    0x7fff563ea000 -     0x7fff563f0fff  com.apple.GPUWrangler (5.2.7 - 5.2.7) <F632C729-7779-3B7F-BFAD-14B388964131> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff5670f000 -     0x7fff56735ff1  com.apple.GenerationalStorage (2.0 - 314) <54483E50-20BB-3AF8-900F-992320C109B0> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff5674e000 -     0x7fff57737ff1  com.apple.GeoServices (1.0 - 1624.26.4.26.9) <F735575F-7DEF-3202-9151-589BEB162596> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
    0x7fff57863000 -     0x7fff57871ffb  com.apple.GraphVisualizer (1.0 - 100.1) <507D5812-9CB4-3C94-938C-59ED2B370818> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff57872000 -     0x7fff5787fff3  com.apple.GraphicsServices (1.0 - 1.0) <5DAF38C9-53CF-319A-A853-C2EDC46F30EF> /System/Library/PrivateFrameworks/GraphicsServices.framework/Versions/A/GraphicsServices
    0x7fff57a10000 -     0x7fff57aceff4  com.apple.Heimdal (4.0 - 2.0) <59263B72-FF28-3D81-88BC-C7F0B31FB2C9> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff5922f000 -     0x7fff59270ffd  com.apple.IASUtilities (1.0 - 550.4) <F9E31022-0BB4-3D71-99BD-5F294A50A6AC> /System/Library/PrivateFrameworks/IASUtilities.framework/Versions/A/IASUtilities
    0x7fff59271000 -     0x7fff5936fffd  com.apple.ids (10.0 - 1000) <D75A81B5-8D0A-3DF8-BF42-A3F566927D5D> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
    0x7fff59370000 -     0x7fff594acff5  com.apple.idsfoundation (10.0 - 1000) <B9E26263-9B3E-3884-888B-B7E686D4DF46> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
    0x7fff59aca000 -     0x7fff59b2aff2  com.apple.imfoundation (10.0 - 1000) <BAEB40B7-908F-3D97-9BE9-5EAB83930543> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
    0x7fff59c5a000 -     0x7fff59c62ff5  com.apple.IOAccelerator (438.7.4 - 438.7.4) <3C973800-3AE0-3908-9922-EFBC57C3F5B2> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff59c6f000 -     0x7fff59c86fff  com.apple.IOPresentment (47.10 - 37) <C97340B5-C71D-32CC-A519-30A5D7184BD3> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff5a00e000 -     0x7fff5a059ff1  com.apple.IconServices (438.3 - 438.3) <0DADB4C3-46FF-3FDB-8A86-51E2067FC7F4> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff5a217000 -     0x7fff5a21eff9  com.apple.InternationalSupport (1.0 - 45.4) <8D8D4A7D-FD35-36B8-A456-7C93030EDAB3> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff5a4ab000 -     0x7fff5a4caffd  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <42DEA6AF-7D35-37CC-A943-8CAEF0C482FF> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff5a5ff000 -     0x7fff5a6cdffd  com.apple.LanguageModeling (1.0 - 215.1) <C456087D-5B3A-390E-A665-862FA284C59C> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff5a6ce000 -     0x7fff5a716fff  com.apple.Lexicon-framework (1.0 - 72) <41F208B9-8255-3EC7-9673-FE0925D071D3> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff5a71d000 -     0x7fff5a722ff3  com.apple.LinguisticData (1.0 - 353.18) <3B92F249-4602-325F-984B-D2DE61EEE4E1> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff5a749000 -     0x7fff5a76dffe  com.apple.locationsupport (2394.0.22 - 2394.0.22) <CA6C86FD-051A-31BB-B3AF-3D02D6FD94B6> /System/Library/PrivateFrameworks/LocationSupport.framework/Versions/A/LocationSupport
    0x7fff5a7c6000 -     0x7fff5a7cbff7  com.apple.LoginUICore (4.0 - 4.0) <25CA17AF-8A74-3CE3-84D8-67B4A2B76FEA> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
    0x7fff5afbb000 -     0x7fff5afbefff  com.apple.Mangrove (1.0 - 25) <482F300F-9B70-351F-A4DF-B440EEF7368D> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff5b17b000 -     0x7fff5b17bff5  com.apple.marco (10.0 - 1000) <CBC576AC-3AB9-349E-A0DF-4CDC4AB30A37> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
    0x7fff5b227000 -     0x7fff5b2b1ff8  com.apple.MediaExperience (1.0 - 1) <2A47BA9D-1250-3388-9366-15A84F38D18F> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff5b2b2000 -     0x7fff5b2e5fff  com.apple.MediaKit (16 - 923) <09FEE738-41E4-3A9C-AF1E-1DD00C56339D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff5ba8b000 -     0x7fff5bad7fff  com.apple.spotlight.metadata.utilities (1.0 - 2076.7.2) <80008658-61C6-32E6-823A-23A8CE5FF620> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff5bad8000 -     0x7fff5bba9ffa  com.apple.gpusw.MetalTools (1.0 - 1) <99876E08-37D7-3828-8796-56D90C9AFBDB> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff5bddd000 -     0x7fff5bdfbfff  com.apple.MobileKeyBag (2.0 - 1.0) <D5FA7041-297F-3ADC-8C7A-6EAAAB82EB68> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff5c05e000 -     0x7fff5c08eff7  com.apple.MultitouchSupport.framework (3440.1.1 - 3440.1.1) <A11C1DDC-6DE0-3F14-A526-2552CC5CCBD4> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff5c58e000 -     0x7fff5c598fff  com.apple.NetAuth (6.2 - 6.2) <B0C03C41-87A3-352B-B130-96E1A6F94B47> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff5cd05000 -     0x7fff5cd07ffe  com.apple.OAuth (25 - 25) <7C2D9BA1-E683-3257-8ADB-A4846C8D42F2> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
    0x7fff5cfb0000 -     0x7fff5cffbffb  com.apple.OTSVG (1.0 - 643.1.5.8) <F5A6C8C2-837D-3446-9B1A-491C780CF8DF> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff5e218000 -     0x7fff5e223ff2  com.apple.PerformanceAnalysis (1.243.3 - 243.3) <7B2C4193-68D7-3B95-ACA3-0FDD33A74D45> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff5e224000 -     0x7fff5e24cffb  com.apple.persistentconnection (1.0 - 1.0) <5B2D87A8-2641-3F6D-ACEA-96B00F85AAB5> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff5fcc7000 -     0x7fff5fcf7ff7  com.apple.pluginkit.framework (1.0 - 1) <AACD7323-D5AE-330E-88EB-EBE7D1B9CF26> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
    0x7fff5fd22000 -     0x7fff5fd35ffc  com.apple.PowerLog (1.0 - 1) <76D14DBC-1D4C-3D15-B076-9DE487BADC41> /System/Library/PrivateFrameworks/PowerLog.framework/Versions/A/PowerLog
    0x7fff60bb1000 -     0x7fff60c0bff6  com.apple.ProtectedCloudStorage (1.0 - 1) <6F271388-3817-336D-9B96-08C7AAC4BA39> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff60c0c000 -     0x7fff60c25ffb  com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <5A020941-C43C-303E-8DE8-230FC6A84DBC> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff61065000 -     0x7fff61071ff5  com.apple.xpc.RemoteServiceDiscovery (1.0 - 1738.140.3) <B03BB504-A296-3559-857F-8A8A175BCE8B> /System/Library/PrivateFrameworks/RemoteServiceDiscovery.framework/Versions/A/RemoteServiceDiscovery
    0x7fff61085000 -     0x7fff610aeff1  com.apple.RemoteViewServices (2.0 - 148) <D3AAC2BE-3423-3F18-9654-E35F1DD8DDB3> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff610af000 -     0x7fff610c4ffa  com.apple.xpc.RemoteXPC (1.0 - 1738.140.3) <E207DE98-6F82-34B3-8AB7-5EF6D265B1D2> /System/Library/PrivateFrameworks/RemoteXPC.framework/Versions/A/RemoteXPC
    0x7fff61213000 -     0x7fff6124eff0  com.apple.RunningBoardServices (1.0 - 223.140.2) <96BB04BD-D6E0-3D70-8F36-89B46DA1DA30> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff61f02000 -     0x7fff61f66ffe  com.apple.Safari.Core (15609 - 15609.4.1.1.1) <EF7ED7D5-5B45-3E92-BEFE-EB4A792721D1> /System/Library/PrivateFrameworks/SafariCore.framework/Versions/A/SafariCore
    0x7fff61f67000 -     0x7fff61f72ff8  com.apple.SafariFoundation (15609 - 15609.4.1.1.1) <C7CD68EA-CD1D-3375-BE92-4F1C9738FA0B> /System/Library/PrivateFrameworks/SafariFoundation.framework/Versions/A/SafariFoundation
    0x7fff61f77000 -     0x7fff61fc3ff9  com.apple.Safari.SafeBrowsing (15609 - 15609.4.1.1.1) <FC75F84F-3A90-3F50-BBED-4B1806D0EAFD> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/Versions/A/SafariSafeBrowsing
    0x7fff62b2f000 -     0x7fff62b32ff5  com.apple.SecCodeWrapper (4.0 - 448.100.6) <C4BF691D-A09E-37E8-A6CC-1145B79B8722> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff62c93000 -     0x7fff62ca4ff5  com.apple.SharedWebCredentials (213.5 - 213.5) <31CB2847-A5BF-3B6D-93C8-8407CD2EFFAE> /System/Library/PrivateFrameworks/SharedWebCredentials.framework/Versions/A/SharedWebCredentials
    0x7fff62ca5000 -     0x7fff62dccfff  com.apple.Sharing (1526.37 - 1526.37) <CBDA0ADD-F1E7-3B06-9118-C5E183F0D3D6> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff641e1000 -     0x7fff644d7fff  com.apple.SkyLight (1.600.0 - 451.6) <489A2996-E719-346E-BACE-DCCDB5E00553> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff64d24000 -     0x7fff64d32ffb  com.apple.SpeechRecognitionCore (6.0.91.2 - 6.0.91.2) <4D6CAC2A-151B-3BBE-BDB7-E2BE72128691> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff64df4000 -     0x7fff65080ff6  com.apple.spotlight.index (10.7.0 - 2076.7.2) <F9DB1307-6383-367E-9E3C-A8D8392A7E9F> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
    0x7fff65566000 -     0x7fff6556fff7  com.apple.SymptomDiagnosticReporter (1.0 - 1238.120.2) <C3D66901-7E31-3FDB-BD7A-441EB0520D1D> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff655e0000 -     0x7fff6560affe  com.apple.framework.SystemAdministration (1.0 - 1.0) <C8E68146-EE00-399C-BBB3-F07DBFD6F1F0> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
    0x7fff65826000 -     0x7fff65836ff3  com.apple.TCC (1.0 - 1) <0DD6C92B-5648-3B0C-B318-B0981A7F9EF3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff65d5b000 -     0x7fff65e21ff0  com.apple.TextureIO (3.10.9 - 3.10.9) <EEDAB753-329A-396A-8119-5BEDF7DB5A56> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff65fb8000 -     0x7fff65fb9fff  com.apple.TrustEvaluationAgent (2.0 - 33) <10E56F70-E234-31E0-9286-96D93A8ED17E> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff65ff1000 -     0x7fff66249ff0  com.apple.UIFoundation (1.0 - 662) <EC55B9E5-7E62-380A-9AB1-FC7BEF663653> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff662e0000 -     0x7fff662e6ffe  com.apple.URLFormatting (119 - 119.18) <7F99D166-86DC-3F77-A34A-2DA7183D7160> /System/Library/PrivateFrameworks/URLFormatting.framework/Versions/A/URLFormatting
    0x7fff66c78000 -     0x7fff66c98ffc  com.apple.UserManagement (1.0 - 1) <9F00880E-6EA6-3684-B208-455E14EC07C8> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff67a44000 -     0x7fff67b2fff2  com.apple.ViewBridge (468 - 468) <E35C7CF5-DE95-3B39-ACB8-A3C72C785E8F> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff67cd5000 -     0x7fff67cd6fff  com.apple.WatchdogClient.framework (1.0 - 67.120.2) <FFA17DA1-F6DD-34D3-A708-1F73C8BA7EA7> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff67ea9000 -     0x7fff67ea9fff  com.apple.WebInspectorUI (15609 - 15609.4.1.1.1) <3EB896D9-E7A8-37A5-B49A-C049CF4FCF6C> /System/Library/PrivateFrameworks/WebInspectorUI.framework/Versions/A/WebInspectorUI
    0x7fff68065000 -     0x7fff680a0fff  libAWDSupport.dylib (949) <EBE20139-E443-30DF-BCAD-2A6A8470F631> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
    0x7fff680a1000 -     0x7fff68381ff7  libAWDSupportFramework.dylib (3541.2) <D1EA2A4B-BC59-3FE2-BAA9-4448D6F8393F> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
    0x7fff68382000 -     0x7fff68393fff  libprotobuf-lite.dylib (3541.2) <578CA7D8-149E-3643-937B-DAD5501E4575> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
    0x7fff68394000 -     0x7fff683edffb  libprotobuf.dylib (3541.2) <0CDB164D-E7C3-3D4F-BF11-47402D67D7B0> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
    0x7fff683ee000 -     0x7fff68432ff6  com.apple.awd (1.0 - 949) <9DA8A821-4354-3E24-BAA1-4519D2279F2B> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
    0x7fff68906000 -     0x7fff68909ffa  com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <00FA6272-2017-3199-9E0F-F6DEF5E868D5> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff68983000 -     0x7fff68991ff5  com.apple.audio.caulk (1.0 - 32.3) <06D695EA-E2BC-31E4-9816-9C12542BA744> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff68cd3000 -     0x7fff68cd5ff3  com.apple.loginsupport (1.0 - 1) <540BB904-0A51-3B37-A436-969D24CD28AC> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff68d1b000 -     0x7fff68d27ffd  com.apple.perfdata (1.0 - 51.100.6) <21760CFD-62FF-3466-B3AD-191D02411DA0> /System/Library/PrivateFrameworks/perfdata.framework/Versions/A/perfdata
    0x7fff6b6c7000 -     0x7fff6b6dcffe  libAccessibility.dylib (2790.70.1) <2742A6B5-3297-3558-998F-D43108271737> /usr/lib/libAccessibility.dylib
    0x7fff6b7ac000 -     0x7fff6b7b8ff9  libAudioStatistics.dylib (1104.104) <ABAE8040-11E9-3E33-8638-DB40EFF147F1> /usr/lib/libAudioStatistics.dylib
    0x7fff6b7b9000 -     0x7fff6b7ecffa  libAudioToolboxUtility.dylib (1104.104) <262BD36D-7989-3C7D-AC9A-737D274EF36E> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff6b7f3000 -     0x7fff6b827fff  libCRFSuite.dylib (48) <5E5DE3CB-30DD-34DC-AEF8-FE8536A85E96> /usr/lib/libCRFSuite.dylib
    0x7fff6b82a000 -     0x7fff6b834fff  libChineseTokenizer.dylib (34) <7F0DA183-1796-315A-B44A-2C234C7C50BE> /usr/lib/libChineseTokenizer.dylib
    0x7fff6b835000 -     0x7fff6b8bdfff  libCoreStorage.dylib (551.0.1) <D2F45D31-91C3-31A0-85BF-56FFDC4EB793> /usr/lib/libCoreStorage.dylib
    0x7fff6b8c0000 -     0x7fff6b8c2ff7  libDiagnosticMessagesClient.dylib (112) <C94F3B7B-1854-38EB-9778-834501C53B3F> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff6b908000 -     0x7fff6babfffb  libFosl_dynamic.dylib (100.4) <737573B2-190A-3BA1-8220-807AD0A2CE5E> /usr/lib/libFosl_dynamic.dylib
    0x7fff6bae6000 -     0x7fff6baecff3  libIOReport.dylib (54) <75D177C4-BAD7-3285-B8E1-3019F49B3178> /usr/lib/libIOReport.dylib
    0x7fff6bbce000 -     0x7fff6bbd5fff  libMatch.1.dylib (36) <5C6F3971-9D9E-3630-BDB6-60BFC5A665E0> /usr/lib/libMatch.1.dylib
    0x7fff6bc04000 -     0x7fff6bc24ff7  libMobileGestalt.dylib (826.140.5) <2BE94E6A-FA61-312F-84A1-F764D71B7E39> /usr/lib/libMobileGestalt.dylib
    0x7fff6bc25000 -     0x7fff6bc8efff  libParallelCompression.dylib (142.100.3) <44C95AB4-0523-370A-B907-1DD9F7D01B69> /usr/lib/libParallelCompression.dylib
    0x7fff6bca4000 -     0x7fff6bd81ff7  libSMC.dylib (20) <5C9C17F2-1E6F-3A19-A440-86F74D82284F> /usr/lib/libSMC.dylib
    0x7fff6bd96000 -     0x7fff6bd97fff  libSystem.B.dylib (1281.100.1) <5A20AE6C-BF4D-3689-B7D2-19F0721F6375> /usr/lib/libSystem.B.dylib
    0x7fff6bd98000 -     0x7fff6be23ff7  libTelephonyUtilDynamic.dylib (5017.1) <174030B2-E35F-3F17-A9EF-DF8631F30CCF> /usr/lib/libTelephonyUtilDynamic.dylib
    0x7fff6be24000 -     0x7fff6be25fff  libThaiTokenizer.dylib (3) <4F4ADE99-0D09-3223-B7C0-C407AB6DE8DC> /usr/lib/libThaiTokenizer.dylib
    0x7fff6be3d000 -     0x7fff6be53fff  libapple_nghttp2.dylib (1.39.2) <07FEC48A-87CF-32A3-8194-FA70B361713A> /usr/lib/libapple_nghttp2.dylib
    0x7fff6be88000 -     0x7fff6befaff7  libarchive.2.dylib (72.140.2) <F9EA2883-5D5C-3FA6-B3F8-C5031BF88ABD> /usr/lib/libarchive.2.dylib
    0x7fff6befb000 -     0x7fff6c02afed  libate.dylib (3.0.1) <DE609B9D-AD02-34FE-A91B-464ECDECC73A> /usr/lib/libate.dylib
    0x7fff6c02e000 -     0x7fff6c02eff3  libauto.dylib (187) <B6124448-7690-34AE-8939-ED84AAC630CE> /usr/lib/libauto.dylib
    0x7fff6c0f4000 -     0x7fff6c104ffb  libbsm.0.dylib (60.100.1) <00BFFB9A-2FFE-3C24-896A-251BC61917FD> /usr/lib/libbsm.0.dylib
    0x7fff6c105000 -     0x7fff6c111fff  libbz2.1.0.dylib (44) <14CC4988-B6D4-3879-AFC2-9A0DDC6388DE> /usr/lib/libbz2.1.0.dylib
    0x7fff6c112000 -     0x7fff6c164fff  libc++.1.dylib (902.1) <59A8239F-C28A-3B59-B8FA-11340DC85EDC> /usr/lib/libc++.1.dylib
    0x7fff6c165000 -     0x7fff6c17affb  libc++abi.dylib (902) <E692F14F-C65E-303B-9921-BB7E97D77855> /usr/lib/libc++abi.dylib
    0x7fff6c17b000 -     0x7fff6c17bfff  libcharset.1.dylib (59) <72447768-9244-39AB-8E79-2FA14EC0AD33> /usr/lib/libcharset.1.dylib
    0x7fff6c17c000 -     0x7fff6c18dfff  libcmph.dylib (8) <E72A20DB-2E86-378D-A237-EB9A1370F989> /usr/lib/libcmph.dylib
    0x7fff6c18e000 -     0x7fff6c1a6fd7  libcompression.dylib (87.1) <F3C7F9B4-71CF-3398-AAD3-456C9FEECD08> /usr/lib/libcompression.dylib
    0x7fff6c480000 -     0x7fff6c496ff7  libcoretls.dylib (167) <770A5B96-936E-34E3-B006-B1CEC299B5A5> /usr/lib/libcoretls.dylib
    0x7fff6c497000 -     0x7fff6c498fff  libcoretls_cfhelpers.dylib (167) <940BF370-FD0C-30A8-AA05-FF48DA44FA4C> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff6c93b000 -     0x7fff6ca3ffcf  libcrypto.44.dylib (47.140.3) <E0D79EB7-D1D7-3890-866F-A0A29979B068> /usr/lib/libcrypto.44.dylib
    0x7fff6ca42000 -     0x7fff6ca4dfff  libcsfde.dylib (551.0.1) <FDD996E0-B876-3B82-8B12-D311324E8331> /usr/lib/libcsfde.dylib
    0x7fff6ca55000 -     0x7fff6cab4ff7  libcups.2.dylib (483.9) <D98C594E-BD7F-3A3D-9709-CEAFE2A39105> /usr/lib/libcups.2.dylib
    0x7fff6cab6000 -     0x7fff6cb1bff7  libcurl.4.dylib (118.120.6) <5ECFDF8F-E82B-3194-984C-181897781A64> /usr/lib/libcurl.4.dylib
    0x7fff6cbbe000 -     0x7fff6cbbefff  libenergytrace.dylib (21) <162DFCC0-8F48-3DD0-914F-FA8653E27B26> /usr/lib/libenergytrace.dylib
    0x7fff6cbbf000 -     0x7fff6cbd9ff7  libexpat.1.dylib (19.60.3) <4FD5D517-B4C8-365B-A2C0-D998A624D5A0> /usr/lib/libexpat.1.dylib
    0x7fff6cbe7000 -     0x7fff6cbe9fff  libfakelink.dylib (149.1) <36146CB2-E6A5-37BB-9EE8-1B4034D8F3AD> /usr/lib/libfakelink.dylib
    0x7fff6cbf8000 -     0x7fff6cbfdfff  libgermantok.dylib (24) <D2AE5AC0-EDCE-3216-B8C9-CF59292A545F> /usr/lib/libgermantok.dylib
    0x7fff6cbfe000 -     0x7fff6cc07ff7  libheimdal-asn1.dylib (564.140.8) <79098F5B-A5DF-3FD5-A393-B0E65A88E2C3> /usr/lib/libheimdal-asn1.dylib
    0x7fff6cc08000 -     0x7fff6ccf8fff  libiconv.2.dylib (59) <18311A67-E4EF-3CC7-95B3-C0EDEE3A282F> /usr/lib/libiconv.2.dylib
    0x7fff6ccf9000 -     0x7fff6cf50fff  libicucore.A.dylib (64261.1.1) <66CDEADD-1B4A-3AEA-951F-EA4DBF0BEB09> /usr/lib/libicucore.A.dylib
    0x7fff6cf6a000 -     0x7fff6cf6bfff  liblangid.dylib (133) <30CFC08C-EF36-3CF5-8AEA-C1CB070306B7> /usr/lib/liblangid.dylib
    0x7fff6cf6c000 -     0x7fff6cf84ff3  liblzma.5.dylib (16) <C131EF18-2CDD-3271-8A30-A8760D4FE166> /usr/lib/liblzma.5.dylib
    0x7fff6cf9c000 -     0x7fff6d043ff7  libmecab.dylib (883.11) <0D5BFD01-D4A7-3C8D-AA69-C329C1A69792> /usr/lib/libmecab.dylib
    0x7fff6d044000 -     0x7fff6d2a6ff1  libmecabra.dylib (883.11) <E31DE74D-1B88-377F-ACD3-D789D29C3AE7> /usr/lib/libmecabra.dylib
    0x7fff6d613000 -     0x7fff6d642fff  libncurses.5.4.dylib (57) <995DFEEA-40F3-377F-B73D-D02AC59D591F> /usr/lib/libncurses.5.4.dylib
    0x7fff6d772000 -     0x7fff6dbeeff5  libnetwork.dylib (1880.120.5) <D5FA26D5-7CE4-33AF-B8A4-7867AA022D16> /usr/lib/libnetwork.dylib
    0x7fff6dbef000 -     0x7fff6dc06fff  libnetworkextension.dylib (1095.140.2) <84E23CED-73F1-3D31-BDC9-9D8F6E549B4C> /usr/lib/libnetworkextension.dylib
    0x7fff6dc8f000 -     0x7fff6dcc1fde  libobjc.A.dylib (787.1) <265783CE-6D74-36C9-B6D2-95D3910199EC> /usr/lib/libobjc.A.dylib
    0x7fff6dcc2000 -     0x7fff6dcc3ff7  libodfde.dylib (26) <33F49412-5106-35B8-AA60-5A497C3967E6> /usr/lib/libodfde.dylib
    0x7fff6dcd4000 -     0x7fff6dcd8fff  libpam.2.dylib (25.100.1) <0502F395-8EE6-3D2A-9239-06FD5622E19E> /usr/lib/libpam.2.dylib
    0x7fff6dcdb000 -     0x7fff6dd11fff  libpcap.A.dylib (89.120.2) <86DAA475-805A-3E01-86C5-6CAE4D1D9BC6> /usr/lib/libpcap.A.dylib
    0x7fff6dd51000 -     0x7fff6dd5fff9  libperfcheck.dylib (37.100.2) <9D9C4879-8A80-34C4-B0D2-BE341FD6D321> /usr/lib/libperfcheck.dylib
    0x7fff6dd95000 -     0x7fff6ddadfff  libresolv.9.dylib (67.40.3) <6A5B8293-7CA1-300F-B96E-2316C15D55A9> /usr/lib/libresolv.9.dylib
    0x7fff6ddaf000 -     0x7fff6ddf3ff7  libsandbox.1.dylib (1217.141.9) <C357CAEC-EB2B-30BE-9CE0-2E83190CB950> /usr/lib/libsandbox.1.dylib
    0x7fff6ddf4000 -     0x7fff6de06ff7  libsasl2.2.dylib (213.120.1) <E7573AC1-83FD-305A-8FB8-03145BDA286B> /usr/lib/libsasl2.2.dylib
    0x7fff6de07000 -     0x7fff6de08ff7  libspindump.dylib (281.4) <76562AC6-4289-374D-8EDE-15FC96187805> /usr/lib/libspindump.dylib
    0x7fff6de09000 -     0x7fff6dfebff7  libsqlite3.dylib (308.6) <3E17BEE7-19F3-329D-BBF9-1DD5D54913AD> /usr/lib/libsqlite3.dylib
    0x7fff6e0df000 -     0x7fff6e10cffb  libssl.46.dylib (47.140.3) <7D1EE8D0-4DBD-379E-8888-B10EF4D0BBBA> /usr/lib/libssl.46.dylib
    0x7fff6e18e000 -     0x7fff6e1bfff7  libtidy.A.dylib (17.3) <7C35ED99-CDB7-3A46-835E-4ACEF9F90643> /usr/lib/libtidy.A.dylib
    0x7fff6e23c000 -     0x7fff6e23fffb  libutil.dylib (57.140.1) <6EC380B0-FBB1-3AE3-8A09-1851E128C70F> /usr/lib/libutil.dylib
    0x7fff6e240000 -     0x7fff6e24dfff  libxar.1.dylib (425.7) <4EA640CD-74CE-3A79-ABB7-FFE98C9C1C3A> /usr/lib/libxar.1.dylib
    0x7fff6e24e000 -     0x7fff6e252fff  libxcselect.dylib (2373) <E2324619-42E5-38C7-82A2-17E639581E7F> /usr/lib/libxcselect.dylib
    0x7fff6e253000 -     0x7fff6e335ff7  libxml2.2.dylib (33.14) <618BECE1-F1FD-3923-BA5C-58E5899D0CAA> /usr/lib/libxml2.2.dylib
    0x7fff6e339000 -     0x7fff6e361fff  libxslt.1.dylib (16.12) <42938E5F-5FE9-3265-8D10-1D1115BC5402> /usr/lib/libxslt.1.dylib
    0x7fff6e362000 -     0x7fff6e374ff3  libz.1.dylib (76.0.1) <E3495313-4CFF-34C4-AD9F-5DE24F66E15D> /usr/lib/libz.1.dylib
    0x7fff6ec23000 -     0x7fff6ec28ff3  libcache.dylib (83) <AF488D13-9E89-35E0-B078-BE37CC5B8586> /usr/lib/system/libcache.dylib
    0x7fff6ec29000 -     0x7fff6ec34fff  libcommonCrypto.dylib (60165.120.1) <C7912BE5-993E-3581-B2A0-6AABDC8C5562> /usr/lib/system/libcommonCrypto.dylib
    0x7fff6ec35000 -     0x7fff6ec3cfff  libcompiler_rt.dylib (101.2) <49B8F644-5705-3F16-BBE0-6FFF9B17C36E> /usr/lib/system/libcompiler_rt.dylib
    0x7fff6ec3d000 -     0x7fff6ec46ff7  libcopyfile.dylib (166.40.1) <3C481225-21E7-370A-A30E-0CCFDD64A92C> /usr/lib/system/libcopyfile.dylib
    0x7fff6ec47000 -     0x7fff6ecd9fdb  libcorecrypto.dylib (866.140.2) <E9AAA2A6-D0D4-328A-BEA2-4DC5E513BA30> /usr/lib/system/libcorecrypto.dylib
    0x7fff6ede6000 -     0x7fff6ee26ff0  libdispatch.dylib (1173.100.2) <CD9C059C-91D9-30E8-8926-5B9CD0D5D4F5> /usr/lib/system/libdispatch.dylib
    0x7fff6ee27000 -     0x7fff6ee5dfff  libdyld.dylib (750.7) <AB99C9EE-7127-3451-89AB-339F8F2CEE61> /usr/lib/system/libdyld.dylib
    0x7fff6ee5e000 -     0x7fff6ee5effb  libkeymgr.dylib (30) <DB3337BE-01CA-3425-BD0C-87774FC0CDC0> /usr/lib/system/libkeymgr.dylib
    0x7fff6ee5f000 -     0x7fff6ee6bff3  libkxld.dylib (6153.141.66) <1058F62C-5E2D-388B-B885-CA838379901D> /usr/lib/system/libkxld.dylib
    0x7fff6ee6c000 -     0x7fff6ee6cff7  liblaunch.dylib (1738.140.3) <E2CFD17D-F36C-3734-8F37-16798799EF9E> /usr/lib/system/liblaunch.dylib
    0x7fff6ee6d000 -     0x7fff6ee72ff7  libmacho.dylib (959.0.1) <AA613A9C-961A-3B67-B696-4622FA59FC4E> /usr/lib/system/libmacho.dylib
    0x7fff6ee73000 -     0x7fff6ee75ff3  libquarantine.dylib (110.40.6) <6CADF28C-2F20-3FA5-9FB9-49EAB0FD2489> /usr/lib/system/libquarantine.dylib
    0x7fff6ee76000 -     0x7fff6ee77ff7  libremovefile.dylib (48) <7C7EFC79-BD24-33EF-B073-06AED234593E> /usr/lib/system/libremovefile.dylib
    0x7fff6ee78000 -     0x7fff6ee8fff3  libsystem_asl.dylib (377.60.4) <BDE4E1E6-BB8F-3EAC-A9CD-53B9FBD96554> /usr/lib/system/libsystem_asl.dylib
    0x7fff6ee90000 -     0x7fff6ee90ff7  libsystem_blocks.dylib (74) <0D53847E-AF5F-3ACF-B51F-A15DEA4DEC58> /usr/lib/system/libsystem_blocks.dylib
    0x7fff6ee91000 -     0x7fff6ef18fff  libsystem_c.dylib (1353.100.4) <BCD3F031-4A3F-32CF-AB9A-D6EE7A7499D4> /usr/lib/system/libsystem_c.dylib
    0x7fff6ef19000 -     0x7fff6ef1cffb  libsystem_configuration.dylib (1061.141.2) <393137B7-3631-3450-B6F4-95EECD3ADDFF> /usr/lib/system/libsystem_configuration.dylib
    0x7fff6ef1d000 -     0x7fff6ef20fff  libsystem_coreservices.dylib (114.1) <72857ADA-AA97-398B-B089-F50B2E89064B> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff6ef21000 -     0x7fff6ef29fff  libsystem_darwin.dylib (1353.100.4) <19242BF1-BAF6-3DF0-AAD3-93E3E0870DBE> /usr/lib/system/libsystem_darwin.dylib
    0x7fff6ef2a000 -     0x7fff6ef31fff  libsystem_dnssd.dylib (1096.100.3) <EBB4C2C2-E031-3094-B40A-E67BF261D295> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff6ef32000 -     0x7fff6ef33ffb  libsystem_featureflags.dylib (17) <29FD922A-EC2C-3F25-BCCC-B58D716E60EC> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff6ef34000 -     0x7fff6ef81ff7  libsystem_info.dylib (538.1) <D057695A-F11C-3863-971C-EA1EBF8662B1> /usr/lib/system/libsystem_info.dylib
    0x7fff6ef82000 -     0x7fff6efaeff7  libsystem_kernel.dylib (6153.141.66) <FF081F3A-F653-3F8F-9E64-9F34792EEDB3> /usr/lib/system/libsystem_kernel.dylib
    0x7fff6efaf000 -     0x7fff6effafef  libsystem_m.dylib (3178) <D1CF3A92-2424-3420-B375-DEED7AA68C53> /usr/lib/system/libsystem_m.dylib
    0x7fff6effb000 -     0x7fff6f022fff  libsystem_malloc.dylib (283.100.6) <8549294E-4C53-36EB-99F3-584A7393D8D5> /usr/lib/system/libsystem_malloc.dylib
    0x7fff6f023000 -     0x7fff6f030ffb  libsystem_networkextension.dylib (1095.140.2) <F06C65C5-2CBE-313C-96E1-A09240F9FE57> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff6f031000 -     0x7fff6f03aff7  libsystem_notify.dylib (241.100.2) <FA22F928-D91B-3AA5-96BB-3186AC0FB264> /usr/lib/system/libsystem_notify.dylib
    0x7fff6f03b000 -     0x7fff6f043fef  libsystem_platform.dylib (220.100.1) <009A7C1F-313A-318E-B9F2-30F4C06FEA5C> /usr/lib/system/libsystem_platform.dylib
    0x7fff6f044000 -     0x7fff6f04efff  libsystem_pthread.dylib (416.100.3) <62CB1A98-0B8F-31E7-A02B-A1139927F61D> /usr/lib/system/libsystem_pthread.dylib
    0x7fff6f04f000 -     0x7fff6f053ff3  libsystem_sandbox.dylib (1217.141.9) <75C7915D-19C4-3F32-B320-394BA4B18655> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff6f054000 -     0x7fff6f056fff  libsystem_secinit.dylib (62.100.2) <F80872AA-E1FD-3D7E-8729-467656EC6561> /usr/lib/system/libsystem_secinit.dylib
    0x7fff6f057000 -     0x7fff6f05effb  libsystem_symptoms.dylib (1238.120.2) <702D0910-5C34-3D43-9631-8BD215DE4FE1> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff6f05f000 -     0x7fff6f075ff2  libsystem_trace.dylib (1147.120.1) <BC141783-66D9-3137-A783-211B38E49ADB> /usr/lib/system/libsystem_trace.dylib
    0x7fff6f077000 -     0x7fff6f07cff7  libunwind.dylib (35.4) <42B7B509-BAFE-365B-893A-72414C92F5BF> /usr/lib/system/libunwind.dylib
    0x7fff6f07d000 -     0x7fff6f0b2ffe  libxpc.dylib (1738.140.3) <8DA7D88F-AE2F-3BCF-8426-8D041E57A9AA> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 628
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=757.1M resident=0K(0%) swapped_out_or_unallocated=757.1M(100%)
Writable regions: Total=579.7M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=579.7M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
CoreServices                       172K        1
Kernel Alloc Once                    8K        1
MALLOC                           184.9M       29
MALLOC guard page                   16K        4
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.0M        5
Stack                             10.0M        5
VM_ALLOCATE                         52K        3
__DATA                            40.1M      374
__DATA_CONST                        41K        3
__FONT_DATA                          4K        1
__LINKEDIT                       390.1M        3
__OBJC_RO                         32.3M        1
__OBJC_RW                         1904K        1
__TEXT                           367.0M      372
__UNICODE                          564K        1
mapped file                       45.0M       11
shared memory                      632K       14
TOTAL                              1.5G      831
TOTAL, minus reserved VM space     1.1G      831
Model: MacBookPro9,1, BootROM 429.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2,3 GHz, 8 GB, SMC 2.1f175
Graphics: kHW_IntelHD4000Item, Intel HD Graphics 4000, spdisplays_builtin
Graphics: kHW_NVidiaGeForceGT650MItem, NVIDIA GeForce GT 650M, spdisplays_pcie_device, 512 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x855D, -
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x855D, -
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xF5), Broadcom BCM43xx 1.0 (7.21.190.33 AirPortDriverBrcm4360-1601.1)
Bluetooth: Version 7.0.6f8, 3 services, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: CT1000MX500SSD1, 1 TB
Serial ATA Device: OPTIARC DVD RW AD-5970H
USB Device: USB 3.0 Bus
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: FaceTime HD Camera (Built-in)
Thunderbolt Bus: MacBook Pro, Apple Inc., 25.1
Edited by sdp
Question
I have exactly the same problem after the Apple store updated my Enpass to 6.11.12 on my Catalina iMac.
If the latest version won't run on a Catlina iMac how about making an older version available with a facility to stop it updating. I need advice urgently as I cannot access any password information and am really struggling.
Edited by Pineman
Please!
same trouble on my system. Support contacted....but still no response
Enpass 6.11.12 update constantly crashes on Big Sur 11.6
Macbook Pro
Using Time Machine on my iMac I rolled back a couple of weeks and installed the earlier version, which works ok.  but that is not good enough!
Enpass is a brilliant app but when something goes wrong the 'support team' are hopeless.
I have the same problem, and this change was so sudden and so disruptive.
I wonder why there's no longer support for older versions of MacOS (11.x).
Please help us out!!
Mine is also not working properly since the update, though I am on macOS 26 Tahoe Beta. Enpass does crash sometimes, but the bigger problem I am having is that none of my browsers will connect to Enpass anymore. They all show the "Looking for Enpass App" page, which launches Enpass, but it doesn't actually connect to the browser for autofilling. It's been frustrating. I would like to echo the sentiment of others that Enpass lately has been very unstable and crashes a lot.
I'm utterly flabbergasted that this has been going since June and the only response is "send us an email, we'll look at it".   At an absolute minimum there should be a direct link to the last working version so that we can all get back our passwords, get back work, pay our bills, and do all the things that we depend upon Enpass to enable.  It is utterly irresponsible to knowingly leave us locked out.  "Here's how to download a working version and get back into your Enpass" should be the VERY FIRST response, and "email us and maybe we will look at it" the second.
Enpass, you have failed us.
On 7/1/2025 at 6:15 AM, Tarun Singh Rawat said:
Please reach out to us directly at support@enpass.io so our support team can look into this and assist you promptly.
Surely you have passed ALL these concerns to support yourself haven't you?
We truly understand your frustration, and we’re very sorry for the inconvenience this has caused. Please know that your access to Enpass and your data is extremely important to us.
To ensure we provide the correct solution tailored to your setup, we are currently handling such requests individually. We’ll be happy to provide you with a direct download link to a working version of Enpass.
Kindly email us at support@enpass.io, and our team will assist you promptly.
Thank you for your patience and understanding, we’re here to help you regain access as quickly as possible.
I have mostly the same issue on Windows thought it was my PC seems like it may not be. That is good to hear. Thanks.
Noticed it happening a long while ago. Very long while ago.
I am surprised that support weren't notified by the team member on this forum and when I queried this my post was not published.
I emailed support. I was replied to by a Tarun Rawat who provided a link to version 6.11.10.1951 and a set of instructions on how to activate and restore from a backup. But, it doesn't work.  Enpass starts but it will not accept my master password. It will not allow me to restore from backup. It will not allow me to activate.  Nothing.  I replied back seeking more guidance and received no reply. I replied again yesterday asking for help. Nothing. No reply.  I am still locked out.
We purchase Enpass and trust our passwords, our data, our jobs, our whole lives to Enpass.  Nothing.  Zero.  Not even an acknowledgement of the gravity of this situation.  Words fail me.  I'm now well along the process of resetting passwords for everything that I can remember touching over the years. Awful.
We are excited to announce that we’ve addressed this issue in our latest Enpass macOS beta release: Try out Enpass beta
For the Enpass App Store version (requires macOS Monterey 12.0 or later), you can join our TestFlight program to access the beta.
Alternatively, you can download the Website version of the Enpass macOS beta.
Thank you for your patience, and we’ll notify you as soon as a stable update with the fix is officially released.
The issue with messages not being displayed on the forum was due to a technical glitch. We've since resolved the problem and implemented measures to prevent it from happening again. We appreciate your understanding!
Hi all.
I downloaded the beta version and I am trying to restore from my backup. I couldn't select the files in
~/Library/Containers/in.sinew.Enpass-Desktop/Data/Documents/Vaults/primary/vault.enpassdb
 during backup process, so I clicked on 'all files' and selected the file. However, when I went ahead to enter my password, it said my password is wrong.
If anyone was successful in using the beta version please let me know. I will greatly appreciate any help.
Thanks
EDIT: My iMac is on 10.14.6
Edited by john64
Will the next App Store update version be compatible with 10.14.6?
I read through the thread, and it looks like the app requires Monterey but somehow it updated the app running on MacOS version below Monterey.
I really hope the next update fixes for all versions that were compatible before, including 10.14.6!
Thanks!
Hello. I couldn't find a version for my computer. Just to remind you, I have Catalina 10.15 OS.
I don't need new features if the program won't work.
Edited by vas76
add info
Hi Tarun,
Would the next update be fixed for 10.14.6?
Thanks!
7 hours ago, Tarun Singh Rawat said:
To fix this issue and keep everything running smoothly, please update your Enpass app for macOS to the latest version (6.11.13). Thanks for your patience!
Note: This update addresses a crash that occurred on macOS versions earlier than 13 after updating the app.
Thanks for the update!
I checked the app store but the update doesn't appear yet. What is the timeline for the release of 6.11.13?
Thanks!
