MAC to iPhone Wi-Fi sync not working
I’m able to sync using Wi-Fi between my iPhone and MacBook, but after a short while and then it stops!? I contacted support before, and they asked me to install the Discovery App to confirm that Wi-Fi sync is available, and it is (see details below). I sync at home so on the same Mac/iPhone network, no firewall, VPN..etc
I’ve also attached iPhone/MAC screenshots to this post for reference.
Thank You
5cd33998-1807-463f-a2f3-720f2ec13cc7._enpasswifisync._tcp.local.
MBP-local.local:53042
192.168.4.125:53042
fe80::1c74:b3bb:3f5b:ac26%en0:53042
machine_name = MBP
pinned_cert_hash = df2KccqdTvEClKcuMKWriqsNabwOoSwYpLvMmalrsC4=
pinned_cert_hash_base32 = OX6YU4OKTVHPCAUUU4XDBJNLRKVQ22N4B2QSYGFEXPGJTKLLWAXA====
Edited by KOTB
  • 2 months later...
I opened ticket number ECS-59044 a couple of months ago. Support reached out and asked for some data, and then I never heard back. I’m still experiencing the same issue, and the only temporary fix is to uninstall and reinstall the iPhone app. After a few days, the issue happens again.
@KOTB Thank you for following up.
We’ve reviewed the details of ticket ECS-59044, and I can confirm that this issue is already with our development team. They are actively working on a permanent fix. We did share a workaround earlier, but since it only helped temporarily in your case, the team is focusing on addressing the root cause.
We truly appreciate your patience, and we will update you as soon as we have further progress or a fixed build available.
  • 2 weeks later...
"We did share a workaround earlier!?"
The last time this worked was in June and we are in Dec now.
  • 3 months later...
Hi Tarun,
I reported this back in August of last year, so I’m surprised it’s taking this long to resolve. Maybe this solution can help others experiencing the same issue. What I did today was uninstall the Enpass iPhone app, reinstall it, and perform a manual sync (instead of scanning the QR code). I also reserved my MacBook’s IP address on the router so it won’t change. I rebooted iPhone and Macbook for testing So far, sync is working.
