Appearance Settings "Dark, Follow System" bug
With the last update of Enpass it not remembers the appearance settings in Windows.
When you choose Dark or Follow System, after a restart its back to light.
Please restore these settings.
Edited by Tuinpad
It is happening with me too. Windows 10 22H2 with Enpass 6.12.4 (2630). I am not on the beta channel.
Edited by korg250
With Version 6.12.4 (2635) in Windows the bright mode switches too dark mode whenever the app the started again.
This is annoying, I do want to keept the brigth mode.
Why are such basic things messed up again and again, do you not do release tests?
Yes, this should be adressed.
I always use the Dark but yesterday it started with the Light for no apparent reason and i had to manually change it back to Dark, so the same thing has happened to me as well, iow that it swithces from one Appearance (Dark) to another one (Light).
I have the same issue since a while. it's extremely annoying that Enpass changes to dark mode over and over again
It's funny because I have the opposite experience. PLEASE FIX. Add tests to prevent regression and push a hotfix. Dark mode not working properly. The app seems to forget Dark mode and switches to light mode all the time. Sometimes it switches at random (without restarting the app). Also, the CHECK FOR UPDATES button in the settings doesn't work. I have to use the Help > Check for updates.... Waiting on this fix please.
