Safari Extension 6.0.0 autofill shortcut
Hello,
after update to Enpass 6.0 I' am unable to set the shortcut for autofilling.
The docs says: "Go to Preferences → Extensions → Select Enpass in the sidebar → from here you can set the shortcut."
https://www.enpass.io/docs/manual-desktop/browser_ext_setting.html#creating-keyboard-shortcut
But there is no option at all see attached screenshot
regards Martin
  • Replies 74
  • Views 36.2k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The shortcut doesn't work on a German keyboard layout. Does anyone the corresponding combination? I would really like to switch from 1Password but this is an essential feature for me.
  • Florian Kriener
    Florian Kriener
    Why is it not implemented as in version 5 where I could freely choose my key combination?
  • Yogesh Kumar
    Yogesh Kumar
    Hi all, Sorry for inconvenience. Safari Shortcut will make comeback in upcoming update. Cheers:)
Posted Images
Same here.
This Update is a step back regarding browser extensions, because of the missing shortcut.
Please fix it!
Same here. Default shortcut is unusable with safari. A step back.
Same here - App Store says to open extension but it is not there!
Hi all,
Cheers:)
I updated the Enpass to 6.0.2 today, they fixed the filling but now it is terrible :( . I have to press "command + /" then I have to choose the login name from Enpass assistant and then press enter to be filled. So I need 3 steps to do it while in the past it was only press "command +/" and then it will be filled automatically.
I enabled "Autofill details without showing Enpass assistant" but it is the same.
Also, I noticed that "command+/" has different service in Safari which is to view and hide the status bar :( .
I hope you can fix this as all other password managers have it.
783297607_ScreenShot2019-01-03at9_28_31AM.thumb.png.e450314882cc2b4c58dfa803a97b5ecb.pngdoing
Edited by Bassam
adding other information
Edited by C__O
Same here. Unusable with german keyboard. Very annoying.
......very bad...........disappointed.........
Edited by StefanT
This needs to be fixed ASAP. It makes Enpass very cumbersome to use in Safari without a shortcut.
Edited by _Eric
It's working but only with a German keyboard with numeric keypad (see screenshot). On a MacBook... no chance... very frustrating that it's not possible to set a custom shortcut for this. I just switched from 1Pass and I'm getting to regret it...Unbenannt-1.jpg.046aba168168d568b7814d40da3e6f8b.jpg
Hi all,
3 hours ago, Florian Kriener said:
Why is it not implemented as in version 5 where I could freely choose my key combination? >:(
We are working on it. We provided a hard-coded shortcut to make it available earlier.
Here is a workaround(ugly fix) for German Keyboard Layouts:
1. Finder->Go->Go to Folder-> enter below path
~/Library/Group Containers/7ADB8CC6TF.in.sinew.Enpass-Safari-Group/Library/Preferences
Download the attached plist file with this post and paste inside the folder. Overwrite the existing one.
REBOOT YOUR MAC(do this just after pasting).
Your safari keyboard shortcut will be "Cmd+ ä" now.
Thanks.
7ADB8CC6TF.in.sinew.Enpass-Safari-Group.plist
It works for me. Thanks.
After restarting the Mac, I get an error "can't connect to extension". After reauthorizing it (which seems like a bug to me), the shortcut is working fine. Thanks,
WOW! Great! Works for my fine! Thank you very much!
@Admin
I wanted to report other bugs, but unfortunately, the spam protection system of this forum doesn't allow me to open new threads for no obvious reason ("forbidden").
7 hours ago, Vinod Kumar said:
Hi all,
Thanks.
Thanks for this temporary workaround.
I managed to change the shortcut to one of my liking.
Hi, new user here! Just trying to understand what should I do to have a safari shortcut as "cmd + \" . A manual shortcut is (for now) pretty much ok :)
What should be the correct entry for 'ctrl+option+space' ?
