Remove custom icon?
Hi, I messed up with the sizes of custom icons and I need a way to remove them again. Any solution for that?
  • 2 weeks later...
  • 3 weeks later...
Hey @Joey J.
39 minutes ago, Joey J. said:
Can you give us an estimation when this update will be available?
Hopefully before the end of this month.
Cheers!
  • 3 weeks later...
@Anshu kumar @Ankur Gupta Thanks for the latest update of Enpass – it's great to be able to delete custom icons again. HOWEVER, all custom icons still show up on the mobile device. It seems that the deletion is not synched? (I'm using iCloud to synch between Mac, iPhone and iPad). Is there something we can do to get rid of old custom icons on the mobile devices, too?
I can confirm this issue. It also happens between two Windows machines, both running Enpass 6.0.6 (if I delete the icons on one machine, they are still visible on the second one).
I have noted down this issue in the bug tracker and notified the dev team to look into it.
Thanks for your co-operation.
  • 2 weeks later...
I'm having the same problem syncing my Windows, Linux and my iPhone.
  • 3 weeks later...
On 3/5/2019 at 10:37 AM, Joey J. said:
@Anshu kumar @Ankur Gupta  it's great to be able to delete custom icons again.
I can add new icons but I don't know how to delete my own icons.
I can't find a way to to this on mobile, but on the desktop app, you right-click on the icon you want to remove.
Hey guys,
Currently, the Mobile version of Enpass doesn't have the option to delete the custom icon. However, it's already planned and will be available with the subsequent update.
Till then please co-operate with us.
thanks, that works fine on the PC .  After a synchronization nothing happens on the mobile phone.
I can wait :-)
You're 100% right. I hadn't noticed because I hardly ever use the mobile app. That's definitely a bug. Enpass team probably realizes this, but calling @Vikram Dabas to the thread nonetheless.
EDIT: I see @Anshu kumar is already here. Didn't realize that. :)
Edited by 100 Watt Walrus
  • 9 months later...
So, is this in the desktop version yet? I can't find a way to delete a custom icon.
Hey @timcricket,
Welcome to the forums!
To change icon of an item in Enpass, in the edit menu of the item, left click on the icon to choose website icon or the default icon. However, if you wish to delete the custom icon, click on the particular custom icon in Choose icon menu and you'll find an option to delete the custom icon.
Thanks.
  • 3 weeks later...
Hello @Enpass Team and @Community.
I would like to change the background of some icons - where are the standard icons stored?
Custom icons should have these requirements, right?
  • 200x200px
  • 100 KB
  • .jpg?
Gruß aus Berlin,
Dave
