Posted (edited)
Hello everybody.
I‘m using the latest Enpass on Windows, Mac and iOS.
I do have a login item which had a custom section “2FA”. Some time later I decided to get rid of the custom section and placed its existing subitems somewhere else. I saved the edited item.
Now it’s getting strange:
on Windows and Mac, the edited item shows up correctly. Even in edit mode. But on iOS the custom section “2FA” remains with all its subitems! More strange: when switching to the item’s edit mode (on iOS), the custom section disappears and everything shows up correctly. After re-editing and re-saving the problem remains.
The vault is in sync.
What else can I do?
What’s the reason for that?
-remo
Edited by remo
Posted
Hi @remo,
Thanks for the message!
As it seems that the issue is occurring in the iPhone only, you can disable to sync once in the phone and then enable it again. This may resolve the issue. If however, it doesn't work, feel free to message us at support@enpass.io.
