bjorkblom Posted April 4, 2017 Report Posted April 4, 2017 It would be really nice if you could copy multiple fields in a password object once so it will be easier to use Enpass in a native application where Enpass not able to autofill. Scenario: 1. You launch ie Spotify application 2. You open Enpass (short key?) 3. You enter Master/Pin code if needed. 4. You enter Spotify in search field 5. You press arrow down to mark Spotify item and copy the item (ctrl+shift+c?) 6. In the Spotify app, first ctrl+v paste username, second ctrl+v paste password 2
Hemant Kumar Posted April 26, 2017 Report Posted April 26, 2017 Hi @bjorkblom, The already planned, Auto-type feature might be useful here.
