I get the message that I have reached the maxium storage quota. What to do? I have 297 objects/passwords saved.
Hi @Rolllex
Please let us know if you are using sync? If Yes, check if the storage is full of your cloud. If the issue persists revert to us.
Thanks!
It got solved. It seems to be a bug in Enpass. There was no shortage of space. The reason was that I had changed password for Onedrive.
