Posted
I'm using the Windows 10 PC application (German language version). Parts of certain Enpass windows are outside of my screen and I can't reach them. Resizing the window isn't possible. This is particularly frustrating with the Settings window, because the menu tabs at the top aren't visible nor clickable.
I was able to fix the problem by changing my Windows screen settings. By default the size of text, apps, etc. is set to 150% (see screenshot). If I change it to 125% then I can see the full Enpass Settings window. However text is so small that it's hardly usable.
Would it be possible to fix this in a future release, so that also at 150% Enpass fits the screen - or at least has a scroll bar?
Thanks.
Posted
Hi @Andi
Thanks for reporting this issue and I apologize for the inconvenience. I have noted down this issue and forwarded to the dev team, so they can try to fix this issue asap. Till then I request you to please bear with us.
