Posted
I received a popup this morning to update to desktop beta version 5.5.3.  After installing it, the Edge extension no longer works (it worked great with 5.5.2).
When I click the extension icon, I get the "enpass connection error" page.  I've verified the extension is enabled and loaded, I re-ran the checknetisolation command just in case, and verified that beta updates, browser extensions, and edge extension are all enabled in settings (I even turned them off & on again).
Is there some other setting I need to change?  Or a new edge extension version to install?  (I don't see a new version anywhere).
Thanks,
g.
Create an account
Register a new account
Sign in
Sign In Now
