Exporting vault crash Enpass.exe!
Hello.
I really like Enpass. But everytime I want to export vault as .txt or as .csv, the program just crash...
Using Enpass 5.5.3 on Windows 10 Pro (x64).
Edited by Nolan
Hi @Nolan
Thanks for reporting this issue. This issue has already been fixed in the current beta update. If you are willing to test before public release you can turn on the beta update from Enpass settings.
  • Log into Enpass -->  Settings --> Advanced --> Enable Beta updates.
Cheerio!
2 hours ago, Anshu kumar said:
Hi @Nolan
Cheerio!
Hi @Anshu kumar
Thank you for the reply. I've just tried v5.5.4 beta and it works! Thanks! :)
Keep up  the good work!
