Display issue after update - Gnone 3.34.4
After a recent update, Enpass and assistant looks enormous ...
OS: Manjaro Linux x86_64
Host: ThinkPad X1 Yoga 4th
Kernel: 5.5.6-1-MANJARO
Shell: zsh 5.8
Resolution: 1920x1080
DE: GNOME 3.34.4
WM: Mutter
Theme: Adwaita [GTK2/3]
Icons: Adwaita [GTK2/3]
Terminal: tilix
CPU: Intel i7-8565U (8) @ 4.600GHz
GPU: Intel UHD Graphics 620
$ pacman -Qd | grep -i qt
appstream-qt 0.12.10-2
bluez-qt 5.66.0-1
libaccounts-qt 1.16-1
libdbusmenu-qt5 0.9.3+16.04.20160218-4
modemmanager-qt 5.66.0-1
networkmanager-qt 5.66.0-1
phonon-qt5 4.11.1-1
polkit-qt5 0.113.0-1
poppler-qt5 0.85.0-1
pulseaudio-qt 1.2-1
python-pyqt5-sip 12.7.1-1
python-sip-pyqt5 4.19.19-3
qt5-base 5.14.1-2
qt5-declarative 5.14.1-1
qt5-graphicaleffects 5.14.1-1
qt5-location 5.14.1-1
qt5-multimedia 5.14.1-1
qt5-quickcontrols 5.14.1-1
qt5-quickcontrols2 5.14.1-1
qt5-script 5.14.1-1
qt5-sensors 5.14.1-1
qt5-speech 5.14.1-1
qt5-svg 5.14.1-1
qt5-tools 5.14.1-1
qt5-wayland 5.14.1-1
qt5-webchannel 5.14.1-1
qt5-webengine 5.14.1-1
qt5-webkit 5.212.0alpha3-9
qt5-x11extras 5.14.1-1
enpass-bin 6.3.3.601-1
Any clue ?
Edited by xakraz
Format code blocs
Hi @xakraz,
Please follow the below steps and share the findings-
  • Please refer to this link.
  • Go to Home > Show hidden files using Ctrl+H > Navigate to .bashrc > Open it in edit mode using a text editor > Append both lines at the end of the file and restart the system.
Thanks.
Hi @Garima Singh,
Thank you for your suggestion.
However it does not seem to fix the issue as you can see in the attached screenshot (I have set the environment variable as suggested and launched Enpass).
Hi @xakraz
Thanks for writing back to us.
I have noted down this issue and notified the QA team to look into it.
Thanks for your cooperation.
