Posted (edited)
I have enabled "Minimize app to System Tray" option, but application is still on the task bar after I minimize it.
Version 5.2
Regards.
Edit: Got it: I shall click "Close" button to make it dissapear from taskbar. The label is confusing, it shall sound like "Close to System Tray", or "Hide to System Tray when close" :)
Edited by dexter
Found the solution.
  • Like 1
  • 3 months later...
Posted (edited)
I had the same question. When the option says "Minimize to system tray" is should function as described by disappearing from the task bar and moving to the system tray when you minimize the Win32 app. Otherwise, to avoid confusion, the option should say "Close to system tray" or "Minimize to system tray when closed" or "Minimize to system tray on startup". Thanks.
Edited by mikeg
