Posted
Hey!
I use Enpass with Google Drive.
The problem is, I have to reconnect the Cloud with eatch system start.
The status just shows "synchronizes..", but it never ceases.
This also happends on android.
Thanks.
Posted
Hi @tobias,
Sorry for the trouble. Please let us know some details for further investigation.
  • On which devices (all of them, along with OS version) are you using Enpass?
  • Which Enpass version are you running?
  • Are you using two step verification in Google drive?
  • Log into your Google Drive account and look for the Enpass folder there (should be one Enpass folder there). Now inside that folder, check for the sync_default.walletx for the number of copies it has (should be one)
Waiting for your reply!:)
Posted
3 hours ago, Anshu kumar said:
Hi @tobias,
Thanks for the answer!
I checked my Drive and found out that there were 2 folder for enpass. (Image below).
So, I have deleted the second one. Hopefully the problem is now solved.
577a88f6108eb_enpassweird.PNG.c79192e08f
Thanks!
