Rooco Posted March 6, 2018 Report Share Posted March 6, 2018 Hi I have a problem with saving login details on a specific website, Enpass does not propose to save the registration data. Without the popup window, there is no way to save your login details Here is the website addresshttps://www.sfd.pl/sklep/aspx/Login.aspx?ReturnUrl=%2fsklep%2f Windows 8.1 64bit Enpass (latest) Please check it Link to comment Share on other sites More sharing options...
Guest Akash Vyas Posted March 7, 2018 Report Share Posted March 7, 2018 Hey @Rooco Thanks for bringing this to our notice. We tested this in our lab and it seems that the when we clicked on login, it went unnoticed. However, on pressing the return key, the dialog for saving the login appeared. So for now, please use the return key. Meanwhile, I've forwarded it to the tech team to look into it. Cheers! Link to comment Share on other sites More sharing options...
Rooco Posted March 8, 2018 Author Report Share Posted March 8, 2018 Hello @Akash Vyas Thank you for checking this case. Unfortunately, in my case, pressing the return arrow on the browser does not cause a popup window to save login data. My browser is Slimjet Best regards Link to comment Share on other sites More sharing options...
DeveloperChris Posted November 28, 2018 Report Share Posted November 28, 2018 (edited) Is this going to be fixed? I have tried on firefox/waterfox and Chrome and saving does not work on clicking the login/submit button however the enter key does work. I am on windows 7 Edited November 28, 2018 by DeveloperChris Link to comment Share on other sites More sharing options...
