Autofill problem on iphone
I'm using iphone 13 pro max with ios 16.3 and the latest enpass version from the app store.
When signing in to any application, there no way for enpass to recognize the application in order to suggest the correct login, it gives a message says "we could not find a corresponding item please try search", then it lists all available logins for me to choose from, is there a way to make enpass more smart?
Edited by gahawy
Spelling mistakes
Link to comment
Share on other sites
Hi @gahawy
For troubleshooting purposes, please try the below steps -
  1. Kindly check and ensure that you have set up autofill correctly and you are not missing any crucial steps by referring to this link.
  2. If you are facing this concern for any particular app/webpage, take a note of your credentials of this app/website, then remove the item that you have saved in your Enpass app. After filling in the credentials again, save the Item and try autofilling.
  3. In case you are using multiple vaults, please ensure that you have selected the correct vault from which you would like to autofill.
If the issue persists, please share the below details -
  1. The version of the Enpass app and browser you are using.
  2. The apps/webpages on which you are facing this concern.
Link to comment
Hi @Abhishek Dewan
Thanks for the reply.
I tried the first 2 steps with no luch, while for the 3rd one, I'm not using multiple vaults.
I'm using enpass version 6.8.6(684).
I'm not facing the issue on webpages, only apps
Some apps like (CIB, ARABI-MOBILE, NBE MOBILE,Mashreq Egypt) and others.
Link to comment
Hi @gahawy
Upon a thorough investigation of this issue, the apps you mentioned do not provide any URL. That is the reason Enpass cant show the matching items.
As for the CIB app, try searching for the Item, perform autofill and choose the 'YES' option to link the local URL with that Item. Once done, this Item will be shown in the CIB app to autofill.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
 Share
