Changing Data Location
John Hind
 Share
I have Enpass Password Manager (5.6.17 (5428) Windows under evaluation for a switch from 1Password. I have become fed up with the latter's opaque data storage policies and constant pressure towards cloud/subscription. I want my data on (and only on) a removable USB drive. Manual suggests I can change the Enpass data location in Tools/Settings/Advanced, but the "change location" button is missing on my machine:
So how can I change the location?
Link to comment
Share on other sites
  • 5 months later...
Hey @Danny D
Thanks for writing in.
 I would like to share that Windows Store apps can access data only from their sandboxed container and it's not possible to change the default location.
Well, in this case, I recommend you to please use the Traditional version (downloaded from Enpass website), where it has the option to change the default location. Please have a look at our blog to know their different functionality and feature.
Hope this helps!
Link to comment
 Share
