David Deehan Posted January 10, 2019 Report Posted January 10, 2019 Apologies if this topic has been discussed before. On the Box Community website, Box has stated that WebDAV support will end on 31st Jan 2019. Would someone please advise me on how I may synchronise my Enpass Vault across Windows and Android devices after 31Jan2019. Regards, David Deehan
Vinod Kumar Posted January 11, 2019 Report Posted January 11, 2019 Hi @David Deehan, We are working on it and dedicated Box support will land before Jan 31. Cheers:)
David Deehan Posted January 11, 2019 Author Report Posted January 11, 2019 Great news. One thing less to worry about.
DouggerJ Posted January 15, 2019 Report Posted January 15, 2019 Sync via BOX Win10 via webdav seemed to work fine however failed using same settings on iphone. Resulted in SYNC ERROR - Conflict in syncing data with WebDav. Resolution required. Hopefully a resolution is coming soon!
Vinod Kumar Posted January 16, 2019 Report Posted January 16, 2019 Hi @DouggerJ, Sorry for the delay. 'Conflict in syncing data with Dropbox' error occurs when Enpass detects that items on local vault are different than items found in the cloud database. If you are trying to sync two different databases/vaults then follow the steps:- 1. Tap on Sync Error, and you will get a screen where you can see the number of items of both vaults and there will be two options 'Merge' and 'Disconnect'. 2. Tap on 'Merge' and syncing will be continued. You can safely continue with 'Merge' option even if Enpass is showing this error on same databases. Please let me know if you ever imported data from any other password manager or csv file. That may be the cause of issue. Thanks.
