Problem with Firefox Extension
I have a problem with the installation of my enpass firefox extension. It just doesn't work. It's not possible to connect the App with the extension. It didn't work with version from the microsoft store and it didn't work with the version from the website (see below).
I don't know what to do. For me the app is quite useless without the extension.
Thank you in advance.
Kind regards
Mafri
Hey @Mafri
It seems that any app or third party software is blocking the Enpass extension to communicate with the app. Please share some more info so that we can help you better.
  • On which device (along with OS version) are you using Enpass?
  • Are you using any Antivirus or third-party security-related extension?
Thanks for your co-operation.
Hi, thank your quick help. It works now, has been the Antivirus system!
