OLLI_S
[Forwarded] Export Password Vault and Settings
Hello,
At work our administrators have restricted the access to all cloud storage sites (like OneDrive, Dropbox, Google Drive, and many others).
So I can no longer sync my password vault at work (so Enpass is unusable for me now).
So please offer a feature in Enpass that exports (packs) the password vault to a ZIP file.
Then I can send this ZIP file via email to work (also USB-devices are blocked).
At work I can import the password vault in Enpass (so you also should offer an import-feature).
You should also offer the same feature for the settings.
So I can export the settings from my PC and import them at work and also at my Surface Go (so I have the same settings at 3 computers without having to manually adjust them on every device separate).
Best regards
OLLI
Edited by OLLI_S
  • Like 1
Share this post
Link to post
Share on other sites
Hello @Vikram Dabas,
i have some enhancement for this suggestion:
  • after the Vault was exported (packed to ZIP) open the folder where the ZIP file is stored, so I can drag it in an new email
  • add an option to protect the ZIP with the password that is used for the vault (this option is checked by default, but users can un-check it)
Best regards
OLLI
  • Like 1
  • Thanks 1
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
