Posted
I'm on Enpass 6.0.6, looking under password verification to show, for instance, weak passwords it shows some elements with strong password instead. Same for same password: it shows elements with different password.
Posted
11 hours ago, Anshu kumar said:
Hey @saifer,
It seems that your entry has one password field in the saved web-form. Please click on the "Show Webform" on the info page and check if there is any password field having a weak password.
Thanks.
Thank you, solved.
  • Thanks 1
