September 15, 20197 yr Hello, I am running multiple services on the same domain but with different ports. When opening mydomain.com:4000 Enpass is also suggesting logins for different ports. Is there a way to force Enpass to use a stricter URL matching? Thanks in advance! Edited September 15, 20197 yr by ProXy
September 16, 20197 yr Hello @ProXy, Thanks for using Enpass. Yes! You can certainly enforce strict URL matching in Enpass. Open Enpass Settings, Go to Browser menu and check Match URL Hostname option. Please let us know if this helps! Thanks!
September 16, 20197 yr 20 hours ago, ProXy said: Hello, I am running multiple services on the same domain but with different ports. When opening mydomain.com:4000 Enpass is also suggesting logins for different ports. Is there a way to force Enpass to use a stricter URL matching? Thanks in advance. Have a look at: Settings -> Browser -> Match URL Hostname See if that is what you are looking for.
April 14, 20206 yr How about the URI part? I want Enpass to make difference between http://foo.com/bar and http://foo.com/foo so only the part after the / .. Right now, the "Match URL hostname" only matches the hostname, not the URI behind the hostname.
April 14, 20206 yr Hi @ascent, Thanks for contacting to us. Currently there is no option to check the whole URL of the item in Enpass. The Match URL Hostname only checks the hostname of the item. However, we have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
April 28, 20206 yr I also have an issue with the hostname matching. I absolutely love the soft match ability (which is something some other password managers **cough** Passwordstate could learn from), but I would like the ability to specify on the record itself to do hard matching. For instance, I want soft matching on all the records except three. I want the ability to make just a few records hard match so that I can quickly fill several stored passwords for work, all at the same core domain.
April 30, 20206 yr Hi @beardedmogul, Thanks for writing in. We have shared your feedback to the concerned team.
June 1, 20206 yr @Pratyush Sharma @Kashish Especially the support of wildcard domains would also be very welcome: test.domain.de newtest.domain.de
June 1, 20206 yr Hey @Seger Thanks for using Enpass and writing to us. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the development team. Thanks for the suggestion!
September 30, 20206 yr I would like that as well! Having the ability to define the matching at the item level. Having the ability to leverage regex (either in the matching, or in the url field directly) would be awesome
