September 27, 20197 yr Using the Mac Desktop app. I have two vaults set up (primary and a secondary), both are working fine. I added an item to my primary vault by mistake, and have been looking for a way to just move it to the secondary vault without needing to re-create it. When I right-click on the item I see a command Add to Vault, but it's greyed out. I've tried dragging and editing the item, but nothing seems to allow it to be moved to the secondary vault without re-creating it from scratch. I think I might be missing something simple. Thanks! Edited September 27, 20197 yr by tsieling
October 4, 20197 yr Author Just giving this a bump, I got hit by this limitation again today and it's pretty frustrating. I just want to move an item from one vault to another (both vaults are enabled in Enpass). How do I do that, or will it be added?
October 16, 20197 yr Hello @tsieling, On 9/27/2019 at 10:00 PM, tsieling said: When I right-click on the item I see a command Add to Vault, but it's greyed out Please share a screenshot of the app. It could possibly be due to "All vaults" selected in the upper left pane. Try selecting Primary vault and then move to secondary vault.
October 18, 20197 yr Author Thanks - you're right that I had All Vaults selected. After choosing a single vault I could then move the item. There is a kind of logic in how it works now, but it's somewhat counter-intuitive. I'm glad I can move items though it was becoming an obstacle. Cheers Edited October 18, 20197 yr by tsieling
May 6, 20206 yr On 10/16/2019 at 6:52 AM, Kashish said: Hello @tsieling, Please share a screenshot of the app. It could possibly be due to "All vaults" selected in the upper left pane. Try selecting Primary vault and then move to secondary vault. This solved it on my side as well, thanks. Would be nice to be able to move to another vault if "All vaults" are selected as well.
May 7, 20206 yr Hey @fmb Thanks for notifying us. I am glad to know that your issue has been resolved and also have shared your suggestion with the concerned team. Thanks.
July 20, 20215 yr I had the same problem and thanks to this thread, I could solve it. But I agree with @fmb suggestion - this feature should be available also when ALL VAULTS is selected... I see this request was suggested one year ago but still not solved? Thanx
March 22, 20233 yr To move an Item to another vault: At the top-left corner of the Enpass window, select the vault where the Item is currently stored. Right-click the Item, and select Add to Vault. Select the Item's new vault from the drop-down list, and click Move. Regards, James
