October 6, 20197 yr Dear Support, in version 6.2.0 the functionality of the password field was changed. In edit mode of a new entry you can not copy the password anymore. This is very bad. When creating a new account it can happen that a chosen (generated) password is not accepted. For this reason I get a password generated by Enpass, copy the password and enter it in the browser. Only after the change has been accepted by the website do I save my change in Enpass. I would be very grateful if you could find a copy option. Thanks Klaus
October 21, 20197 yr I am using 6.2.0 on Windows Desktop, iPhone, and iPad, and the option to copy and test the new password is still there! See screenshot. Its in the upper right in the "Generate" window.
October 22, 20197 yr Hey @Red0210, This is a known bug and our team is working to fix this in the next update. Thanks for reporting it!
October 22, 20197 yr 6 minutes ago, Kashish said: Hey @Red0210, This is a known bug and our team is working to fix this in the next update. Thanks for reporting it! @Kashish I don't have a problem, @Klaus Heim has a problem!
