iCloud Sync does not work despite connection
Hi @rednewsch,
Thanks for sharing the details.
Can you please try to open iCloud in your default browser and sign out from it. Now, set up the sync with Enpass and let us know if the issue persists.
  • Replies 50
  • Views 24.8k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • I too have this same problem with iphone sync on my windows 10 laptop, a Dell tablet running windows 8.1, and two Desktop PCs running Windows 7.  All of my systems are running 6.4.0.  On my systems I
  • Hello @Timo K., We have identified the issue with the iCloud sync and are working on an update with the fix for it. You could let us know if there's anything else. Thanks.
  • As far as I know, they identified the problem. We are all waiting for the update containing the fix. Stay strong!
Posted Images
it does not make a difference. After sign out of iCloud with the browser - and I even signed out of iCloud in Windows - the spinning wheel is still there.
What I have noticed however is that Enpass has still be connected with iCloud. So this time when I opened enpass and checked the sync settings it did not say that I had to sign back on to iCloud. Seems as if in the background the "keep me signed in" has been checked when I signed on last time. I will keep an eye on this. If that persists then I don't care about the spinning wheel issue.
Hi @rednewsch,
Thanks for writing back in.
Can you please do some sample change like mark any item to favorite, add a new item in any one device. Now check does the changes are reflected in other devices?
ok, I've just seen the iCloud session has expired again, so what I thought yesterday is not true. When I sign in to iCloud for the synchronization the problem of not being able to check "Keep me signed in" still persists.
Hi @rednewsch,
Please try after changing the default browser. If you still face the issue with another browser, let us know.
I can confirm the same behavior with Firefox, Chrome, Edge and Internet Explorer.
I'm using multi factor authentication. Could that be a problem?
Hi rednewsch,
If you mean with Multifactor Authentication the same as 2-factor authentication , I can confirm that this works without problems for me. It seems it must be something else. Have you possibly created an app-specific password in icloud and are you using your normal apple-id password for synchronization in enpass? And when not, you could try to create an Enpass Password in your apple-id account.
yes, 2-factor authentification. I sign in to iCloud with my iCloud password. There is only one iCloud account that I use. So in order to connect Epnass to iCloud for synchronization the browser asks me for my iCloud password. Which I then enter. Then I get referred back to Enpass and the synchronization procedure starts and is successful. Only that the connection with expire after 24h or so.
I have just discovered the possibility to create an app specific password. I'm sure I have not used this because I have not been aware of this before. Is it recommended to use this?
I don't know if it is recommended, but you can give it a try.
For me Enpass works fine with my normal apple-id password. But you could give it a try.
It could also be a virus scanner issue. Have you already tried to temporarily disable it?
it's not the virus scanner, I just tried. I'll go check with the app specific password and let you know the result.
After given the icloud password you should get a popup-screen where you are asked to open Enpass Password Manager. Whitout mouseclicking this "Open Enpass Password Manager" button the screen stays hanging in the spinning circle screen. Do you guys get this popup? If not, maybe something is blocking the popup.
Edited by Dennis J
yes. I get this popup and I press the button which brings Enpass into the foreground and the signon starts. The browser is in the background with the spinning wheel, I suppose I should see the check box to keep me signed on, but that doesn't happen. If I reload the page it says "Authentication Error, this action could no be completed".
If that would help I could offer to have a screen sharing session where I could demonstrate what happens.
Hi @rednewsch,
While entering your iCloud username and password, you have the option to check "Keep me logged in", in my case it's in dutch "Houd me ingelogd". That are all the checkboxes you need to set.
After that you will get the popup, and you have to open Enpass if it doesn't happen automatically.
You will then see that synchronization is started
and after a few seconds it is ready.
If you then go back to your browser, the spinning circle is still there.
1040828975_EnpassBrowserwhensynchronisingisready.thumb.png.748504dd5472dad15dbac47d8ab81231.png
You can just close the browser at this point, because the setup is already done.
Hopefully the screenshots will help you foreward.
8 hours ago, Garima Singh said:
Hey @rednewsch and @yellowtee
Please try the steps given above. If the problem persists, please revert us back along with the Enpass version so that we can investigate it further.
Thanks @Dennis J for describing the steps.
I can confirm that the steps from above aren't solving the issue for me.
Hello,
ok, so here's how my sign-on screen to iCloud looks like:
THere is a check box "Apple ID merken", which means "keep Apple ID", or "memorize Apple ID". I have never checked this box because I was waiting to see something like "keep me logged in" and the semantics of "keep Apple ID" is not the same as "keep me logged in". This was misleading me.
So this time I have checked this box. Let's see what happens. From the descriptions so far I was waiting to see the "keep me signed in" check box after Enpass signs in to iCloud and not before. Sorry if this was the problem.
Thanks for pointing this out so clearly.
Hey @yellowtee
Thanks for sharing the video.
Please try the latest beta version of Enpass from windows Store and share your findings with us.
Thanks.
Hello,
when i try to sign up for the beta program i get this error, it seems that your PHP code is a little bit broken at that point.
Hey @yellowtee
Thanks for writing back.
Please let us know the Enpass version and device OS version on which you are using Enpass so that we can investigate the issue better.
Thanks.
Hi, I'll try the BETA. I'm also having the issue for iCloud using Mac OS 10.15.5.
