June 6, 20206 yr Hi, Samsung released an update to their android browser which states they have improved 3rd party autofillers. It seems bitwarden got it to work. Will Enpass further improve on autofill and Samsung internet as well?
June 8, 20206 yr Hi @Anon9898, Welcome to the forums! We have noted down your valuable suggestion and forwarded it to the concerned team for further consideration. Thanks for your feedback!
July 17, 20206 yr Hey, Thanks for using Enpass and writing to us. Thanks for letting us know that you would like to see support for the same. Significant user demand is a big factor that determines our priorities for new features. We really appreciate you for exploring the app and giving time in finding this valuable suggestion. The suggestion has been noted and forwarded to the concerned team. Thanks.
July 27, 20206 yr Hey All, Thanks for the patience. We would like to share that the requested feature has been considered by the Dev team and aligned for implementation. Thanks for your co-operation.
March 21, 20233 yr This feature is missing from enpass for several years now. Any idea when the developers will implement it??
February 16, 20242 yr On 3/21/2023 at 8:32 AM, Saptak said: This feature is missing from enpass for several years now. Any idea when the developers will implement it?? Hi, we're in 2024 and still no autocompletion on Samsung Internet, which is very embarassing... :/
July 26, 20242 yr Hi @Garima Singh, any update on this? It's long been a major feature missing from Enpass, stopping it from fully replacing 1Password on my phone, which has had it since 2019! Is there some compromising requirement Samsung is demanding to be on their whitelist?
July 30, 20242 yr To troubleshoot the auto-filling issue you're experiencing, please follow these steps: 1. Ensure that all auto-filling methods in Enpass for Android are enabled. You can find these settings under Autofill on Android, Android Autofill Framework, Android Accessibility, and Enpass Keyboard. Try toggling them off and on again if they are already enabled. 2. Try removing the saved credentials for the webpage/app where the issue is occurring and then re-save them in Enpass. After re-saving, attempt to auto-fill again. 3. Create a manual backup of your vault data or set up synchronization and then reinstall the Enpass app. If the issue persists, please provide the following details for further investigation: - The version of the browser you are using. - Specify if the issue occurs on all webpages/apps or only on specific ones. If specific, please provide the names of those webpages/apps. Feel free to reach out if you need any further assistance or information. We're here to help!
July 31, 20242 yr 18 hours ago, Amandeep Kumar said: To troubleshoot the auto-filling issue you're experiencing, please follow these steps: 1. Ensure that all auto-filling methods in Enpass for Android are enabled. You can find these settings under Autofill on Android, Android Autofill Framework, Android Accessibility, and Enpass Keyboard. Try toggling them off and on again if they are already enabled. 2. Try removing the saved credentials for the webpage/app where the issue is occurring and then re-save them in Enpass. After re-saving, attempt to auto-fill again. 3. Create a manual backup of your vault data or set up synchronization and then reinstall the Enpass app. If the issue persists, please provide the following details for further investigation: - The version of the browser you are using. - Specify if the issue occurs on all webpages/apps or only on specific ones. If specific, please provide the names of those webpages/apps. Feel free to reach out if you need any further assistance or information. We're here to help! Hi Amandeep, None of the suggestions work in getting Enpass to autofill in Samsung Internet. I'm using Samsung Internet v26.0.1.3. The issue occurs on ALL sites in Samsung Internet.
July 31, 20242 yr Our development team is currently aware of this issue and they are working on identifying a fix. We apologize for any inconvenience this may have caused you, and we appreciate your patience and understanding as we work to fix this issue. #SI-1167
November 16, 20241 yr On 7/30/2024 at 2:23 PM, Amandeep Kumar said: To troubleshoot the auto-filling issue you're experiencing, please follow these steps: 1. Ensure that all auto-filling methods in Enpass for Android are enabled. You can find these settings under Autofill on Android, Android Autofill Framework, Android Accessibility, and Enpass Keyboard. Try toggling them off and on again if they are already enabled. 2. Try removing the saved credentials for the webpage/app where the issue is occurring and then re-save them in Enpass. After re-saving, attempt to auto-fill again. 3. Create a manual backup of your vault data or set up synchronization and then reinstall the Enpass app. If the issue persists, please provide the following details for further investigation: - The version of the browser you are using. - Specify if the issue occurs on all webpages/apps or only on specific ones. If specific, please provide the names of those webpages/apps. Feel free to reach out if you need any further assistance or information. We're here to help! Does this apply to Samsung browser? Is Samsung browser even supported or are these steps general steps for other supported browsers?
February 9, 20251 yr On 7/31/2024 at 10:59 AM, Amandeep Kumar said: Our development team is currently aware of this issue and they are working on identifying a fix. We apologize for any inconvenience this may have caused you, and we appreciate your patience and understanding as we work to fix this issue. #SI-1167 Anyupdates on this...it's 2025 now and still no autofill...
August 20, 20251 yr So it is August 2025 -- any updates? I'm an Enpass lifetime member but I can't even use Enpass on my phone with Samsung Internet
August 22, 20251 yr Thanks for checking in! Yes, we’re aware of the issue with Samsung Internet and it’s already on our priority list. Our team is actively working on broader browser support, and Samsung Internet is part of that roadmap. While I don’t have an exact ETA to share just yet, please rest assured it’s in progress and will be addressed in an upcoming release.
October 22, 20251 yr Hi there,are there any updates on when auto fill will be supported in Samsung Internet Browser?
January 18Jan 18 7 years later and they still haven't implemented what the competition has long had since 2019...at this pace, don't think we'll be ever seeing it implemented.
July 30Jul 30 At this time, we do not have an estimated timeline to share regarding when this feature will be available. However, the request has been shared with the relevant team and is under consideration.
July 31Jul 31 Thank god the request is under consideration.....then we have to wait just another 6 rather than 7 years...
