September 14, 20215 yr Hey there, I keep running into problems with both methods for setting up Wi-Fi sync. I’ve tried all the recommended troubleshooting tips, restarting devices, pausing/stopping the sync server, etc., but nothing seems to be working. Trying to set up Wi-Fi sync with the QR code yields the following message: "Error Couldn’t connect to Wi-Fi Sync Server. Make sure that server is running and you are connected to same network.” But unfortunately, the server is running and I am connected to the same wireless local area network. Attempting to connect manually results in my iOS application just spinning its gears indefinitely on the “Looking up for servers…” status. The vault has already been set up on my desktop version of the application, as well. Thoughts? I’m at somewhat a loss.
September 14, 20215 yr Hi @rigmarole Welcome to the Enpass Community! Please share the below information with me and I will get it checked with the concerned team - The OS you are using on your desktop and its version The version of the Enpass App you are using Would also suggest you to check the following links to make sure you are not missing any steps while trying to setup Wifi Sync- For Setting wifi sync through Manual Setup For setting wifi sync through QR Code For Troubleshooting
September 15, 20215 yr I have run into this same issue with an iPad Pro that previously was working with WiFi sync to a Mac running the server. I had not synced in a while so I was updating all the devices today and just this one iPad will not sync and cannot see the WiFi server running on the Mac. The iPad is running iOS 14.8 and Enpass 6.7.0 (562). I tried all the troubleshooting methods and rebooted every device including the WiFi and router. I can successfully sync a Macbook, a Mac Mini, an iPad and an iPhone. It's just this one iPad Pro that is not working. The server Mac is running Mac OS 11.6 and Enpass 6.7.3 (888).
September 16, 20215 yr Hi @Welshdog Thank you for bringing this issue to our attention. Our team has reproduced the bug on their end and we are working on getting it fixed. The fix will be implemented in the future Enpass updates. Appreciate your patience in the meantime.
October 12, 20215 yr I tried 6.7.1 on the iPad Pro and it still cannot see the WiFi server on the Mac.
November 21, 20215 yr Any estimate on when this issue will be fixed on iPad Pro models? Still on version 6.7.1
January 4, 20224 yr Hi @Welshdog Our dedicated team is still working on a fix that will be implemented soon in the upcoming Enpass version, but I will not be able to provide any ETA at the moment. Rest assured, I'm closely following this case and will share any news or update regarding a fix on this forum. #SI-2303
February 13, 20224 yr I'm having the same issue. It works after I disconnect and add it again with a qr code. So annoying to do this all the time, the wifi sync is very unreliable. Given that it works with a new qr code setup it doesn't seem like there would be any connection issue, rather a bug with the app.
May 13, 20224 yr I have installed both the Mac and iPad Pro updates of Enpass and the WiFi sync still does not work on the iPad Pro.
May 16, 20224 yr Hi @Welshdog Thank you for notifying me that you are still facing this issue after updating the Enpass app. I have forwarded your comments as feedback to the dedicated testing team so they may investigate this issue again. We appreciate your patience while we look into it for you.
May 17, 20224 yr Over two weeks now with a completely borked update. I would consider rolling back to the previous version. Really not acceptable that a core feature breaks like this. This version was launched for your business offering. As someone who runs a business I do not gain trust to pay for a business subscription given how lightly this issue have been tackled. Very little information. Barely able to confirm the issue on Twitter. A very serious bug and two weeks of radio silence. I run a software company myself and for such a serious bug I would just roll back to the previous version. This together with your outdated external security audit makes it difficult for me to trust Enpass with a business subscription. I know fixing bugs can be difficult but please improve how you communicate such issues.
June 9, 20224 yr FYI I finally broke down and deleted Enpass from the iPad Pro. After reinstallation I was able to connect and sync to the Mac serving WiFi. What I don't know is if I lost any Enpass entries made on the iPad since it had been unable to sync to the vault on the Mac over the last several months. I did made a backup of the iPad vault first, but I did not see a way of merging/syncing it with the up-to-date vault on the Mac. It's probably fine as I don't think anything critical was created on the iPad that could not be recovered.
June 10, 20224 yr Hi @Welshdog Thank you for updating me that it is working fine for you now. @Sleepyhead Could you please create a manual backup, then reinstall the app on the device on which you are facing this issue and share your findings with me? I would also suggest disconnecting the Wi-Fi-sync server and enabling it again once.
June 12, 20224 yr @Abhishek Dewan no need for local changes here, the problem was introduced with the wifi sync bug in the previous version of Enpass. After 3 weeks it was fixed with the latest version.
June 13, 20224 yr Hi @Sleepyhead Thank you for notifying me that the issue you were facing got resolved with the recent update!
June 26, 20224 yr A new update and again not able to sync over Wi-Fi. Please improve your software testing. It seems like there are major problems with how you release software updates. I really like Enpass but so often new updates just breaks a core feature like sync.
June 27, 20224 yr @Sleepyhead I can certainly understand your disappointment in this matter. For troubleshooting purposes, please try disconnecting the Wifi sync from all connected devices and re-sync them again. I would also suggest checking our troubleshooting guide. If the issue persists, please share the below information with me and I'll get it investigated for you - The version of the Enpass App and OS you are using on the devices on which you are facing this issue. A screenshot of the error occurring would be helpful.
