February 5, 20224 yr Often a merchant will require a billing zip code along with the credit card number. Is there a way to put a zip code in a credit card entry in Enpass so that it, too, will autofill along with the card number and CVV?
February 6, 20224 yr I too intersted to know if Enpass can fill other fields than username and password if not maybe build it in the future. I am not sure how these managers figure out which field is which any way
February 7, 20224 yr Hello @SFurst& @flyingbirds, Your request to add a zip code for credit card filling has been shared with the concerned team. Your patience is greatly appreciated here. SI-2609
August 16, 20242 yr Any progress on this? An online form I use regularly has a "billing address" section with address and postcode. Enpass doesn't fill in any of these fields, despite me adding them to the Enpass record.
August 16, 20242 yr I get the following after using Enpass to fill in the rest of the form: EDIT: The payment site in question is https://docs.payments.service.gov.uk/testing_govuk_pay/ but the form isn't available to mess with unless you are a merchant. Edited August 16, 20242 yr by JamRoller
August 16, 20242 yr If I am not mistaken the problem lies within Enpass' field type selection. As of right now, there is no option to set a specific field as adress / zip code / city. Therefore the autofill will not work. But this is a nice to have feature, so I'll add a +1 to request that feature.
August 22, 20242 yr @JamRoller Please provide us with the HTML webpage by following these steps: 1. Open the Webpage on which the issue is occurring in your browser. 2. Save the Webpage: - Press “Ctrl + S” on your keyboard to open the “Save As” dialog. - Alternatively, right-click on the webpage and select “Save Page As”. 3. Save the Page: - Choose a location on your Desktop or another convenient location to save the webpage. - This will create an HTML file and a folder containing associated files. 4. Compress the Files: - Select both the HTML file and the folder. - Right-click on the selected items and choose “Send to” → “Compressed (zipped) folder” to create a ZIP file. 5. Share the ZIP File: - Send the ZIP file to us, and we will further investigate the issue.
