November 28, 20215 yr Clicking on the Change link on Google docs is prevented by the Enpass extension. I think that the extension is not properly name-spaced. Please fix so that the extension does not interfere with other websites
December 8, 20214 yr Hi, I found that focusing any input element makes the extension do strange things. The bug can make keyboard-only usage of the entire website impossible. At first, I thought it's a browser bug, so I even asked a question on stackoverflow, only to find out that it's in fact caused by this extension. The problem doesn't actually seem to have anything to do with passwords at all. You can find a description, including an example, in this codesandbox (if you have no technical understanding, just ignore the code part on the left and focus on the rendered part on the right): https://codesandbox.io/s/input-element-destroys-focus-behaviour-bydvv Note that the input field does not even have type="password".
December 9, 20214 yr Hello @Timon Welcome to the Enpass Community Forums. Thank you for sharing the details of the issue you are facing with the inline autofill. I will be sharing this with the concerned team to investigate it further. Your patience is highly appreciated here. Also, it would be so helpful if you can share the website URL with the browser version details with us. #SI-2494
December 10, 20214 yr Hi Manish, thanks for sharing it with the concerned team. On 12/9/2021 at 8:50 AM, Manish Chokwal said: Also, it would be so helpful if you can share the website URL with the browser version details with us The bug is not limited to a specific website. I think the example that I attached should be more than sufficient. I found the bug in various chromium browsers, Chrome and Vivaldi, and on both Windows and Mac. My Chrome is up to date (version 96.0.4664.55) Edited December 10, 20214 yr by Timon
December 12, 20214 yr I recently was editing some info in my Google account (updating address, adding credit card) and noticed that it was not working. If I clicked on the Save button on the page, it did nothing. Navigating through the Google pages I ended up noticing that any time I had to submit any type of information to Google, I would get the same problem. Click on the Save/Submit button and nothing would happen. I tried Edge, Chrome, Firefox - all had the same problem. I also tried the various In Private/Incognito modes and still the same problem. After some troubleshooting, I discovered that if I disabled the Enpass extension in the browser, the Google site started to work again and I was able to Save/Submit information. If I reenabled the Enpass extension, the problem came back. The Enpass extension is causing some type of problem on Google's sites that is not allowing submission of information.
December 13, 20214 yr Hi @Timon, I would like to share that the issue has been reproduced and our concerned team is working on its fix. However, it requires some additional information. Please save, and share the webpage where this issue is occurring. You can refer following steps: On your Chrome browser, open the webpage on which the issue is occurring. Use the command “Ctrl+S“ to save the webpage to your Desktop. An HTML file and a folder of that webpage will be saved on your PC. Select both documents and compress them into a ZIP file. Then share that ZIP file with us at support@enpass.io and we will get this issue further investigated. Thank you for your understanding and cooperation in advance.
December 13, 20214 yr Hi @Rojma, Thank you for contacting Enpass. For the time being, I would like to share that you have to add the URL in the blocked list in the Extension settings page on which you are facing this issue. For example: Also, share the following details so that I can assist you better. On which device (along with the OS version) you are using? The version of Enpass, Enpass extension, and Browser version you are facing this issue? Please save, and share the webpage where this issue is occurring. You can refer to the below steps on how to do it - On your Edge browser, open the webpage on which the issue is occurring. Use the command “ Ctrl + S“ to save the webpage to your Desktop. An HTML file and a folder of that webpage will be saved on your PC. Select both documents and compress them into a ZIP file. Then share that ZIP file with us, and we will get this issue further investigated. Note: Please share the zip file over PM or please write to us at support@enpass.io (along with this Forum Link).
December 14, 20214 yr Hi Manish, I am sorry, but I cannot figure out your intentions. If you already reproduced the problem, I don't see why that proposal of yours is still necessary.
December 15, 20214 yr Hi @Timon, Just for testing purposes, we requested you to share that webpage so that we can make sure it works as expected on all the reported web pages. It is not mandatory, if you are not comfortable to share it.
December 16, 20214 yr He did provide it in the first post https://codesandbox.io/s/input-element-destroys-focus-behaviour-bydvv?file=/index.html . At the bottom left of the html preview window there's a preview icon. Unfortunately I can't link it, it gets detected as spam.
December 20, 20214 yr I think i have the same issue with the Chrome / Firefox enpass addon on MacOS. On certain Forms, the Input Focus acts erratically. For eg. i can't select another Menu or Text-input field. The Input Focus snaps immediately back. It partially works when i use Keyboard and tab through the fields, but makes propper work impossible. Disable the Enpass Addon in Chrome and Firefox and BINGO works again. There seems to be a lot of focus switching happening when i was trying to work with it. WORSE: (Assumption) Lately a certain account gets locked again and again. As it looks now, when i try to log in, i immediatly get "Invalid user / password" and the User gets locked in the AD. It seems, that the addon fires a lot Input Focus events with incomplete data to the server.
December 20, 20214 yr @HomerNarr Yep, sounds exactly like the same problem. Focus snapping back all the time.
December 23, 20214 yr I'm having the same problem too, with chrome on windows. I thought it was my organization ERP problem, but the other password addons don't give any problems (I tried 1password and bitwarden). I already have an ongoing request with support, let's see what happens...
December 26, 20214 yr I found an example of a standard site where the "focus" problem occurs: lastpass.com. I was trying to change a login from the web app with the enpass extension active and I couldn't activate the notes field. The same thing happens if, while modifying a login, you enter "edit forms fields" (the icon in the shape of a wrench): there, after clicking on "add form field" it is impossible to select the values from the combobox "field type" with the mouse, while you can do that with the keyboard. Can you check if you also encounter the same problem? Thank you! I'm using Enpass (6.7.4 (933)) on windows 10 and the extension (6.7.4) on Chrome
January 2, 20224 yr I have exactly the same problem on multiple websites. Focus just snaps back to 1 specific field, causing dropdowns and other fields to become unusable. Disabling the extension fixes the problem. I have this on both firefox and chrome, and on Windows 11 and a MacBook Pro. No problem with Keeper Security password manager.
January 6, 20224 yr With Enpass Chrome extension enabled, I cannot create events (or close out partially created events) in the Calendar sidebar in GMail. If I disable the Enpass extension and refresh, it works normally. Verified with a new Chrome user account, on multiple computers (Windows 10 and 11 all running latest stable Chrome), and with all other extensions disabled. If you create an event you will not be able to save it or X to close it out.
January 7, 20224 yr Hey everyone - here's an easy place to reproduce this bug: Google's products! Go to Gmail. Open the sidebar where the calendar lives. Now try to add an appointment, or modify an existing one, or whatever. Especially if you invite someone to said appointment. You will be totally unable to use the sidebar. No cancelling, no saving, no nothing. Same issue in all Google products: drive, docs, sheets, etc. Very frustrating. Please fix!
January 7, 20224 yr Hi @DrSuSE I will gladly assist you with your query. Please share the below details with me, and I'll get this investigated for you - The version of the Enpass app and Extension you are using. Are you facing a similar issue on any other browsers as well? A short video capture showcasing this issue would be helpful.
January 12, 20224 yr Extension: 6.7.4 App: 6.7.4 (934) I don't use any other browsers, I will leave that testing to you. I will also leave the video cap up to you. I am simply reporting the issue.
January 14, 20224 yr I can also report the same issue. Furthermore, additional problems with Google websites as follows: - On gmail, tab is not working when composing a new email, and moving from subject line to email body. Need to mouse click in the body field. - On Google sheets, right click contextual menus do not work. Need to use the corresponding menu items. - On Google sheets, drag by change the column sizes also don't work. Need to manually adjust the column width by menu item and modal dialogue window. All these problems disappear when disabling the Enpass extensions. Issues happen on Chrome for Linux, Firefox for Linux, and Chrome for Windows. Thanks for the forthcoming fix.
January 14, 20224 yr I can also report the same issue. Furthermore, additional problems with Google websites as follows: - On gmail, tab is not working when composing a new email, and moving from subject line to email body. Need to mouse click in the body field. - On Google sheets, right click contextual menus do not work. Need to use the corresponding menu items. - On Google sheets, drag by change the column sizes also don't work. Need to manually adjust the column width by menu item and modal dialogue window. All these problems disappear when disabling the Enpass extensions. Issues happen on Chrome for Linux, Firefox for Linux, and Chrome for Windows. All latest versions as of Jan 2022, also Enpass latest version. Thanks for the forthcoming fix.
January 14, 20224 yr Additional note: I juist fouind out that removing the Enpass activation shortcut in chrome://extensions/shortcuts fixes all the mentioned issues on Google sites.
January 14, 20224 yr Additional note: I just found out that removing the Enpass activation shortcut in chrome://extensions/shortcuts fixes all the mentioned issues on Google sites.
January 17, 20224 yr Same problem here, Chrome/Brave on MacOS. Google products are perfect for replication. Does anyone have a workaround?
January 17, 20224 yr Hello @ZioSam, Thank you for reporting the presence of this issue. I have shared it all with the concerned team for further investigation. Your patience is highly appreciated here. SI-2471
