January 5, 20233 yr I use a chromebook. I cannot get the app to work in a reasonable way. The chrome extension shows ENABLE AUTOFILL SERVICE! and it is asking me for ip address and port. What on earth does that mean? I have installed the app for Chromebook, but I guess the extension and the app are not talking to each other? This is really a horrible first start. Help?
January 6, 20233 yr Hi @t7m Welcome to the Enpass Forums. We have received your query on support@enpass.io and have responded to the same. To avoid duplication of efforts and confusion, we request you to please revert to the same. We appreciate your understanding in this matter.
January 13, 20233 yr Just an FYI, also having this problem. [Although I'm not nearly as upset about it as t7m seems to be ;-) ] I am running: Enpass Version 6.8.5.758 Enpass Chrome Extension Version 6.8.0 Google Chrome/Google ChromeOS Version 108.0.5359.172 (Official Build) (64-bit) Enpass is running in the background Autofill in Chrome browser (Beta) is version 100.115.92.6:10395 Thank you!
January 16, 20233 yr Hi @rorywohl Could you please confirm that you have ticked the checkbox for AUTOFILL IN CHROME BROWSER under Enpass app Settings → Autofill? If not, please do so and share your findings with me.
January 20, 20233 yr Hi @rorywohl I'm discussing this case with my team. In the meantime, could you please check and confirm - That you have allowed access to Enpass in your Antivirus/Firewall/VPN settings. Also try disabling them to see if the issue persists. (If you are using such services, do share their names) Also, try clearing the cache and cookies of the browser.
January 20, 20233 yr It's a Chromebook, so there's no antivirus installed, the firewall has no settings that a user can access: Quote Unfortunately, the latest Chromebooks and ChromeOS don’t provide users with an interface to configure or tweak the firewall settings I am not running a VPN. Cleared the cache & cookies & that seems to have resolved the issue. Thank you!
May 10, 20233 yr On 1/20/2023 at 3:16 PM, rorywohl said: It's a Chromebook, so there's no antivirus installed, the firewall has no settings that a user can access: I am not running a VPN. Cleared the cache & cookies & that seems to have resolved the issue. Thank you! Did you ever get this sorted? I have the same issues on a Chromebook. Enpass is flaky at best. Sometimes the autofill opens Enpass, other times it moans and says the autofill isn't ticked (it is), and still other times absolutely NOTHING happens.
May 11, 20233 yr Hi @CeePeeBee Could you please confirm if you tried the steps I shared in this post? If not, kindly try them and share your findings with me - Ensure that you have ticked the checkbox for AUTOFILL IN CHROME BROWSER under Enpass app Settings → Autofill. That you have allowed access to Enpass in your Antivirus/Firewall/VPN settings. Also try disabling them to see if the issue persists. (If you are using such services, do share their names) Also, try clearing the cache and cookies of the browser. If the issue persists, please share the version of the Enpass app and OS you are using.
May 11, 20233 yr I never did get this to work consistently. Sometimes it works, sometimes it doesn't and I can't be clearing the cache & cookies every time it doesn't because I have way too many cookies that save my logins on various web pages. I am now running version 6.8.7.786 of the Enpass Android app with version 6.8.6 of the Chrome extension on a Chromebook running ChromeOS version 112.0.5615.134 (Official Build) (64-bit). Oh, this is interesting. Chrome/ChromeOS now has the ability to display any errors that an extension throws. Here's what I just found: (()=>{'use strict';const e=()=>{var e=(navigator&&navigator.userAgent||'').toLowerCase(),t=(navigator&&navigator.vendor||'').toLowerCase(),n=null!==e.match(/(?:firefox|fxios)\/(\d+)/),o=null!==e.match(/version\/(\d+).+?safari/),r=null!==e.match(/edge\/(\d+)/),s=null!==e.match(/(?:^opera.+?version|opr)\/(\d+)/),i=/google inc/.test(t)?e.match(/(?:chrome|crios)\/(\d+)/):null;return n?'FIREFOX':o?'SAFARI':r?'EDGE':s?'OPERA':null!==i&&!s?'CHROME':void 0};let t=null;const n=e();'SAFARI'!==n&&(t=void 0===n||Object.getPrototypeOf(n)!==Object.prototype?chrome:n);const o=(e,n)=>{const o={command:e,payload:n};'object'==typeof safari&&safari.extension?safari.extension.dispatchMessage(e,n):t.runtime.sendMessage(o)},r=(e,n)=>t.i18n.getMessage(e,n);var s=null,i=!1;const c='support@enpass.io',d=`<a href='mailto:${c}'>${c}</a>`;var l;function a(e){let t=document.getElementById('main_header');e&&(t.textContent=r(e)),t.style.display='block'}function m(){document.getElementById('error_description').style.display='none'}function u(e){let t=document.getElementById('error_highlight_text');e&&(t.textContent=r(e)),t.style.display='block'}function g(){document.getElementById('loader').style.display='block',document.title='Enpass',s=setTimeout((()=>{_()}),2e4)}function _(){document.title='Error Page';let e=document.getElementById('main_header'),t=document.getElementById('error_highlight_text'),n=document.getElementById('error_description'),o=document.getElementById('loader');!function(){let e=document.querySelector('.error-highlight'),t=document.querySelector('.section-header');e.classList.remove('error-highlight--success'),e.classList.add('error-highlight--error'),t.classList.remove('bg-success-header'),t.classList.add('bg-error-header')}(),e.textContent=r('error_static_main_heading'),o.style.display='none',i?(f(!0),t.textContent=r('cb_error_static_highlight'),n.textContent=r('cb_error_static_description',d),n.style.display='block',y()):(t.textContent=r('error_static_highlight'),n.textContent=r('error_static_app_not_found'),n.style.display='block',document.getElementById('footer').style.display='block',function(){const e=document.querySelector('section.body_content');document.getElementById('info_bg_run').textContent=r('instruction_app_installed'),document.getElementById('info_ext_enabled').textContent=r('instruction_extension_enabled'),document.getElementById('download_instruction').textContent=r('instruction_download_app'),document.getElementById('help_text').textContent=r('string_help'),document.getElementById('ques_desktop_app_required').textContent=r('ques_desktop_app_required'),document.getElementById('contact_support').textContent=r('string_contact','support@enpass.io'),e.style.display='block'}())}function y(){document.getElementById('connector-section').classList.add('show'),document.getElementById('connector-section').classList.remove('hide')}function h(){document.getElementById('connector-section').classList.add('hide'),document.getElementById('connector-section').classList.remove('show')}function p(){let e=document.querySelector('.error-highlight'),t=document.querySelector('.section-header');e.classList.remove('error-highlight--error'),e.classList.add('error-highlight--success'),t.classList.remove('bg-error-header'),t.classList.add('bg-success-header')}function E(){document.getElementById('footer').style.display='none'}function I(){document.querySelector('section.body_content').style.display='none'}function f(e){let n=t?t.i18n.getUILanguage():'en';!n||'ar'!==n&&'he'!==n||(e?function(){document.body.style.direction='ltr',document.getElementById('error_description').style.textAlign='left';let e=document.getElementById('retry_link');e.classList.add('retry_link'),e.classList.remove('retry_link_rtl')}():function(){document.body.style.direction='rtl',document.getElementById('error_description').style.textAlign='right';let e=document.getElementById('retry_link');e.classList.remove('retry_link'),e.classList.add('retry_link_rtl')}())}f(),I(),l=e=>{e&&'cros'===e.os?(i=!0,document.getElementById('readmore_link').setAttribute('href','https://link.enpass.io/kb/cb-getting-connection-error/')):i=!1},t.runtime.getPlatformInfo((e=>{l(e)})),document.addEventListener('DOMContentLoaded',(e=>{!function(){let e=document.getElementById('retry_link'),t=r('retry');e&&t&&(e.textContent=t);let n=document.getElementById('readmore_link'),o=r('learn_more');n&&o&&(n.textContent=o)}(),p();let t=document.getElementById('main_header'),n=document.getElementById('error_highlight_text'),o=document.getElementById('error_description');t.textContent=r('heading_app_lookup'),n.textContent=r('error_static_highlight_3'),o.style.display='none',g()})),document.getElementById('retry_link').addEventListener('click',(e=>{p();let t=document.getElementById('main_header'),n=document.getElementById('error_highlight_text'),s=document.getElementById('error_description');t.textContent=r('heading_app_lookup'),n.textContent=r('error_static_highlight_3'),s.style.display='none',g(),E(),I(),o('retry_connection')}),!0),document.getElementById('connect_btn').addEventListener('click',(e=>{let t=document.getElementById('ip_addr').value,n=document.getElementById('port').value;if(t&&n){let e=`ws://${t}:${n}`;g(),p(),E(),I(),a('heading_app_lookup'),m(),u('error_static_highlight_3'),h(),setTimeout((()=>{o('connect_details',{url:e})}),500),document.getElementById('connection_status').classList.add('hide'),document.getElementById('connection_status').classList.remove('show')}else document.getElementById('connection_status').classList.add('show'),document.getElementById('connection_status').classList.remove('hide')})),(e=>{'object'==typeof safari&&safari.self&&safari.self.addEventListener?safari.self.addEventListener('message',(({name:t,message:n})=>{e(t,n)})):t.runtime.onMessage.addListener(((t,n,o)=>{if(!t)return;const{command:r,payload:s}=t;e(r,s,n,o)}))})((function(t,n,o,i){let c=document.getElementById('main_header'),d=document.getElementById('error_highlight_text'),l=document.getElementById('error_description');switch(t){case'start_app':p(),c.textContent=r('heading_app_lookup'),d.textContent=r('error_static_highlight_3'),l.style.display='none';var f=e();if('EDGE'!==f&&'SAFARI'!==f){var B=document.createElement('iframe');B.src='enpassstart://',document.body.appendChild(B),setTimeout((()=>{document.querySelector('iframe').remove()}),1e3)}else window.location.href='enpassstart://';document.title='Enpass';break;case'show_connection_error':clearTimeout(s),_(),n&&n.show_port&&(y(),E(),I());break;case'connected_to_app':break;case'chromeos_connected':document.getElementById('connection_status').textContent='Connected';break;case'connection_details':n.connected?(g(),p(),E(),I(),a('heading_app_lookup'),m(),u('error_static_highlight_3'),h(),setTimeout((()=>{window.close()}),500)):(_(),document.getElementById('ip_addr').value=n.ip,document.getElementById('port').value=n.port,y())}}))})();
May 12, 20233 yr Hi @rorywohl I have forwarded this concern to our dedicated QA team for a thorough analysis. As soon as they update me on this matter, I will be sure to notify you on this forum. Kindly bear with us until then. #SI-3357
May 17, 20233 yr Hi @rorywohl Our team of experts is looking into this concern for you. However, they require some additional information on this matter. Could you please confirm when you click on the Enpass Extension Icon, does it show any error message, or does clicking on Enpass extension doesn’t perform any action? We appreciate your cooperation in this case.
May 17, 20233 yr Hi Abhishek, I will do better than telling you what happens, I will show you as well. Attached is a screen capture showing: A freshly booted chromebook I click on Enpass to start the application & enter my password I show you the settings > autofill configuration to verify that autofill is enabled I start Chrome I go to discussion.enpass.io I click the "Existing user? Sign in" link The "Sign In" dialog appears I click the Enpass icon A new tab in Chrome opens saying that Enpass is "Looking for Enpass App..." Which then changes to the "Connection Error!" message
May 19, 20233 yr Hi @rorywohl Thank you for sharing the details. We were able to reproduce the bug on our end due to which this issue is occurring, and our team is now working on a fix. While we work on fixing this glitch, could you please confirm once you get this error, does the connection between the app and extension gets established automatically or do you have to manually disable/enable the 'Autofill in Chrome browser ( beta)' option from Enpass Autofill settings?
May 19, 20233 yr Hi Abhishek, Once I get the error, the connection between the app and extension does not get established automatically. I have to manually disable/enable the 'Autofill in Chrome browser ( beta)' option from the Enpass Autofill settings in order for Chrome to "see" Enpass. Thank you! - Rory
May 22, 20233 yr Hi @rorywohl I appreciate you taking the time and sharing the requested information with me! I have shared all the details with our development team so they fix this concern asap. Thank you for your support in the interim.
October 9, 20251 yr Curiously this same behavior is happening again. 2 years on and Enpass is behaving in the same manner. Clearing cache works for one instance. Disengaging and then reengaging auto-fill both in the browser and the Android "beta" works one time and then fails. Also in the latest version the ability to turn on logging is not available. Why?
October 13, 20251 yr Thank you for sharing deatils of your issue. We’ll check with our Product Team regarding this and get back to you with an update soon.
