September 13, 20233 yr I was surprised that Enpass showed me a prompt to "re-register" via a TOTP sent to my registeration email. What is going on here? Its not like I am logged in a website
September 13, 20233 yr I purchased Enpass and I use it on Windows, MacOS, and Android. Starting a few months ago on Windows (not the other two) ever since the last update or so, when I start Enpass after powering on or resuming my PC, Enpass keeps asking me to reauthenticate my licensed copy of Enpass ... almost every two days or so. It's not just annoying but also counterproductive and time wasting. Can you please do something? Note that this has nothing to do with whether I use cloud sync or not, and as I said - the MacOS and Android versions do not ask me to do this (there I had done this only once years ago). Only the Windows version keeps annoying me with this. It didn't use to do this before a few months ago (I used it on Windows for years). Using version 6.9.0 (1465) on Windows 10. Edited September 13, 20233 yr by johnq
September 14, 20233 yr Hi @johnq @flyingbirds @johnq I have sent you a DM with instructions related to this concern. Kindly follow them and share your findings with me. @flyingbirds Please let me know the version of the Enpass app and OS you are using so I may assist you further with the appropriate steps.
September 20, 20233 yr I followed your instructions. It still does the same thing. However, i may have identified the cause: it only happens if I put my machine to sleep (not shutdown ro restart) and I resume a number of hours later (like after a whole night, e.g. 10h). Enpass was left running before going to sleep. I may be that Windows resumes from sleep with the wrong system time and takes a few seconds to update the time to the correct time (NTP sync, etc). If Enpass relies on the system time to be correct or to not have lagged -- system time versus hardware clock time are not the same -- then it may think that the machine has travelled in time or that too much time has passed because all of a sudden it's 10h behind. You may want to look into that.
September 21, 20233 yr Hi @johnq Thank you for sharing the feedback with us. While we look into this concern for you, please share the requested logs with us as well.
October 9, 20233 yr Hi @q9f Could you please share the version of the Enpass app and OS you are using?
October 11, 20233 yr On 9/21/2023 at 11:53 AM, Abhishek Dewan said: Hi @johnq Thank you for sharing the feedback with us. While we look into this concern for you, please share the requested logs with us as well. Hi - first, I tried the executable you provided in private, as well as the newest 1511 build, and they still behave the same. I can also practically now confirm that the issue happens every time the PC resumes from standby/sleep (after a few hours of standby) -- you should look into that, possibly a time sync issue as I explained above. Second, I enabled logs a week ago, the app requested to re-validate the license several times since then, but there are no logs. I will likely move away from Enpass given this issue, but more importantly the mobile issue with calling home and SSL (reported here) -- I can't accept being locked out of my password vault because the app wantrs to call home. I'm willing to spend a little more extra time to help resolve this one. In the meantime, where can I download older versions of Enpass? I need to be able to rely on being able to open my vaults. Edited October 11, 20233 yr by johnq
October 12, 20233 yr Hi @johnq I appreciate you trying the steps and build I shared with you. I have also forwarded your feedback to our development team so they may thoroughly analyze this concern and look into the request. As soon as I have more information on this matter, I will be sure to update this forum.
October 18, 20233 yr On 10/9/2023 at 1:04 PM, Abhishek Dewan said: Hi @q9f Could you please share the version of the Enpass app and OS you are using? Yes, ArchLinux with Enpass Desktop version 6.9.0.1467.
November 19, 20232 yr This is still persisting. I noticed Enpass had at least 5 new versions since this was first reported and none of them fixed it. It's been at least 6 months. Can you guys please fix this? It's very disruptive, especially when one is offline. Defeats the whole point of Enpass which is advertised as an offline and local password manager ... Also, why was my post moved to this topic which is titled "Enpass asks to verify local storage"? ... I haven't reported that and I do not have that error or request from Enpass. What I reported has nothing to do with Local storage, but clearly says "Session expired" Edited November 22, 20232 yr by johnq
November 22, 20232 yr Only an idiot would make this a feature — EnPass must be collecting so much money from customers they have a zero-fooks given policy. I find it insane, that the absolute level of retardation involved to invest development hours into this feature was pushed forward... mind-boggling really. It was already bad enough you make people wait on your budget transactional email servers to send laggard automated B$. Edited November 22, 20232 yr by webmaster forgot to blast away once more...
December 30, 20232 yr Any update on this? It has been an issue for 4 months now rendering the Desktop client unusable. Fortunately, I can still access my secrets through the mobile app.
