February 13Feb 13 We understand your frustration and appreciate your patience. The issue has been acknowledged, and our technical team is working toward a solution that will be included in an upcoming release. Thank you for your patience until then.
February 13Feb 13 I don't know what the problems are. With another program, the developer needed two days before a new key was made available to the community.Perhaps the technical team is also wondering how to get the "upcoming" release (really??) if apt refuses to read the repository.As I said, I've been using Enpass for many years and I'm happy with it. I'm also willing to pay for it. But not if the money goes into "nirvana" because I can't access the repository.Why don't you release a binary that can be installed if the valid key is causing these problems?
February 24Feb 24 @geierI don't know what the problems are.They don't give a shit, or more likely they don't know shit. A password manager sitting on this issue for a whole year probably means they fired the people who knew the shit. They haven't even released a Linux version for some time. Check the version numbers on the their Download page. Better start looking for a different password manager. Edited March 6Mar 6 by Brahma Dev
March 4Mar 4 On 2/9/2026 at 12:06 AM, JeffB said:Thanks to @randomguy for a work around. It seems Debian is enforcing the secure certificate test, and Ubuntu and derivatives are more permissive; I don't get the error there. I too wonder if there is any real team there, at least on Linux. But for me, it is still the best solution and as long as it continues to work, there are no reported vulnerabilities, and there are no clear alternatives, it seems like it will be best to continue. However, I plan to evaluate periodically.In the last few months I received the following message when I update the repositries informaton on Debian Testing:Advertencia: Fallo al obtener https://apt.enpass.io/dists/stable/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on B6DA722E2E65721AF54B93966F7565879798C2FC is not bound: No binding signature at time 2025-07-28T06:45:22Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z But thanks to @randomguy I can update the Enpass repository information and install new Enpass versions. I hope the Enpass team configures a new key soon because I like Enpass but only the future will say if I will stay on Enpass or I will migrate my vault to another password manager.
March 8Mar 8 On 3/4/2026 at 6:42 PM, Luis said:(...) I hope the Enpass team configures a new key soon (...)😂 Look at the date of the first message, and read my other replies on this subject.
March 8Mar 8 Come on Enpass team - you can do it!This really isn't fun for many Linux users and it's an easy fix. Please escalate this - it won't take much work!Think of the good will you'll create for a small amount of work.
March 10Mar 10 56 minutes ago, Artemy Tregubenko said:Today I got an update of Enpass and it installed a new signing keyNo changes on Debian Linux.And if you try to install Enpass, you will also get an error.
March 10Mar 10 22 minutes ago, NikosBzh said:No changes on Debian Linux.And if you try to install Enpass, you will also get an error.It appears that the install links are still for 6.11.12 but the update installs 6.11.13 with the new signing key. Until the download/install page is updated, you should be able to use the @randomguy instructions and execute an update/upgrade to get 6.11.13.
March 10Mar 10 Author I got this message,$ sudo apt-get updateGet:8 https://apt.enpass.io stable Release [6,621 B]Get:9 https://apt.enpass.io stable Release.gpg [1,321 B]Ign:9 https://apt.enpass.io stable Release.gpgReading package lists... DoneW: OpenPGP signature verification failed: https://apt.enpass.io stable Release: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key F433834B65BE665BCE974660877653760D0214BC, which is needed to verify signature.E: The repository 'https://apt.enpass.io stable Release' is no longer signed.N: Updating from such a repository can't be done securely, and is therefore disabled by default.N: See apt-secure(8) manpage for repository creation and user configuration details.Will I have too install the new one manually or do you think it can be updated with apt-get?
March 11Mar 11 Thanks for your patience.We have fixed the issue. The signing key used to verify Enpass Linux packages has been upgraded to a stronger security standard, ensuring smooth installs and updates on newer distributions such as Debian 13. Please import the updated signing key as described in the installation guide. See the Linux installation guide for details.
March 12Mar 12 I did the update to see.The issue seemed to have been resolved.But anyway, it was too late for me, I switched to another password manager, which suits me very well.
April 16Apr 16 On 3/11/2026 at 11:11 AM, Tarun Singh Rawat said:Thanks for your patience.We have fixed the issue. The signing key used to verify Enpass Linux packages has been upgraded to a stronger security standard, ensuring smooth installs and updates on newer distributions such as Debian 13. Please import the updated signing key as described in the installation guide. See the Linux installation guide for details.I can't believe it. Someone actually tackled the problem. And successfully, too!An update was released immediately:[UPGRADE] enpass:amd64 6.11.12.1953 -> 6.11.13.1957.It would be helpful if the key were installed directly in the correct directory.Here's how to do it without sudo:# curl -fsSL "https://apt.enpass.io/keys/enpass-linux.key" | gpg --quiet --dearmor | tee /usr/share/keyrings/enpass.gpg >/dev/nulland the source in the new DEB822 format:~$ cat /etc/apt/sources.list.d/enpass.sources Types: deb URIs: https://apt.enpass.io/ Suites: stable Components: main Signed-By: /usr/share/keyrings/enpass.gpg Edited April 16Apr 16 by geier
September 15Sep 15 On 3/11/2026 at 11:11 AM, Tarun Singh Rawat said:Thanks for your patience.We have fixed the issue. The signing key used to verify Enpass Linux packages has been upgraded to a stronger security standard, ensuring smooth installs and updates on newer distributions such as Debian 13. Please import the updated signing key as described in the installation guide. See the Linux installation guide for details.somehow the old key is used again by the server or something like that.It used to be fixed in April, but now I get the error message:Warnung: Während der Überprüfung der Signatur trat ein Fehler auf. Das Depot wurde nicht aktualisiert und die vorherigen Indexdateien werden verwendet. OpenPGP-Signaturüberprüfung fehlgeschlagen: https://apt.enpass.io stable Release: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B6DA722E2E65721AF54B93966F7565879798C2FC, which is needed to verify signature.Warnung: Fehlschlag beim Holen von https://apt.enpass.io/dists/stable/Release.gpg Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B6DA722E2E65721AF54B93966F7565879798C2FC, which is needed to verify signature.Warnung: Einige Indexdateien konnten nicht heruntergeladen werden. Sie wurden ignoriert oder alte an ihrer Stelle benutzt.The Key offered on your site (https://apt.enpass.io/keys/enpass-linux.key) has the signature: F433834B65BE665BCE974660877653760D0214BCWhile the error message is talking about signature: B6DA722E2E65721AF54B93966F7565879798C2FC
September 16Sep 16 Author Same here, please update.Get:16 https://apt.enpass.io stable Release.gpg [1,321 B]Err:16 https://apt.enpass.io stable Release.gpg Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B6DA722E2E65721AF54B93966F7565879798C2FC, which is needed to verify signature.Fetched 51.4 kB in 1s (72.4 kB/s)Reading package lists... DoneW: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://apt.enpass.io stable Release: Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B6DA722E2E65721AF54B93966F7565879798C2FC, which is needed to verify signature.W: Failed to fetch https://apt.enpass.io/dists/stable/Release.gpg Sub-process /usr/bin/sqv returned an error code (1), error message is: Missing key B6DA722E2E65721AF54B93966F7565879798C2FC, which is needed to verify signature.
September 17Sep 17 Please update Enpass app to the latest version. The issue has been resolved in the latest release.
