April 1Apr 1 I exported my passwords (relating to my email addresses) and upon viewing the CSV file, noticed strange info that's not in any record! (Starts with the 2FA into the next columns). What is causing this? Using 6.11.19 (2206) Edited April 1Apr 1 by macRBC
April 1Apr 1 While my .csv export looks nothing like what you're presenting here, I also don't understand what your message and your image are referring to. Could you get into a more descriptive explanation of your problem please?
April 10Apr 10 To help us investigate further, kindly create a test vault item with dummy data that reproduces the issue. Export it and share a sample CSV file at support@enpass.io
