Timo002 Posted February 18, 2017 Report Posted February 18, 2017 I have enabled the feature to ask for storing passwords when logging into a new site. But after that popup, has show, my click function in Chrome seems to be broken. I need to double click on all links to activate a click. At a certain point, this issue solves itself and I can just use a single click again. This issue seems to happen after Enpass asks to store the user credentials after login. Using a MacBook Pro (Retina, 15-inch, Mid 2014) macOS Sierra 10.12.3 (16D32) Chrome 56.0.2924.87 (64-bit) Enpass 5.4.1 (74)
Anshu kumar Posted February 20, 2017 Report Posted February 20, 2017 Hi @Timo002, Thanks for reporting this issue and I apologize for the inconvenience. I have noted down this issue and forwarded to the concerned team so they can check where the problem could be and try to fix asap. Thanks for your co-operation!
