Allow change of icon colour in MS Edge
Hi, the MS Edge plug in colour is almost exactly the same as the colour of MS Edge dark mode. As such I cannot see the icon and can only click by knowing where it is (when I mouse over it the colour changes slightly and can be seen).
Please either change the icon colour or give an option to change it to white, for example.
Thank you
Hi @Tom12345
Thank you for sharing your valuable feedback.
I have duly noted your comments and have shared them with our dedicated team so they may check its feasibility and consider it for future Enpass versions. Your patience in the meantime is appreciated.
#SI-3200
