MikDev Posted November 18, 2024 Report Posted November 18, 2024 (edited) After the Update from Enpass 6.11.4 to Enpass 6.11.5 (1819) the Wi-Fi Sync Server macOS 14.7.1 (Mac Studio) does not work anymore on all synced Devices either macOS 14.x or iPhones / iPads with iOS 17.7.1. The error is "Incorrect Password" - but the sync password is correct & still the same. The same problem happens at other customers sites as well with totally different network hardware ! Our support tried everything, the only remedy that helped was deleting all the clients & stopping Wi-Fi Sync Server, set it up new and synchronising alle clients again from scratch. Not a very nice thing to be forced to by a little update from 6.11.4 to 6.11.5 !!! We support thousands of Machines and usually recommend Enpass to our security conscious customers which want to keep their date local, but lately there are several problems with the Wi-Fi Sync Server - we hope that ENPASS Support could solve this matter to address our concerns ? - one other big Problem with Wi-Fi Sync Server is, that Enpass chooses the IP-Address of that machine and does not offer to use a hostname instead (would be easy to do ;-) and would solve the problem of changing IPs due to DHCP or different Networks (Wifi, LAN, DMZ, or some security measures). A hostname could easily be mapped via Firewall or Router and would relieve our Support efforts considerably. ps: while we're at it - there is a wonderful option on iOS to choose from a simple Menu which Browser should open a requested item (General:Open Links in: always ask), why not implement it on macOS as well, some sites work better with Enpass on another than the default Browser... Thanks for listening Edited November 18, 2024 by MikDev
Amandeep Kumar Posted December 10, 2024 Report Posted December 10, 2024 It seems the problem is related to the "Local Network Privacy" permission settings introduced in recent versions of macOS and iOS. To resolve this, please follow the steps below: For macOS: Open System Settings > Privacy & Security > Local Network. Locate Enpass in the list and enable access. Restart the Wi-Fi sync server and Enpass app. For iOS: Go to Settings > Privacy > Local Network. Find Enpass and toggle access to "On." Restart the Enpass app. Once done, try syncing again using Wi-Fi sync to verify if the issue is resolved. Regarding the issue of Enpass choosing the IP address of the machine instead of using a hostname, we understand how this could be a challenge, especially with changing IPs. We will forward this suggestion to our product team as a feature request for future updates.
Create an account
Register a new accountSign in
Sign In Now
