Posted (edited)
Hello,
I use Enpass at home (Windows 10 Pro) and also sync my vault to OneDrive.
At work we have Windows 7 and there I have a separate user account.
There is also no OneDrive App installed.
I plan to use Enpass also at work but I did not test this yet.
How can I access my vault (that is stored at OneDrive) from work?
At work I can access OneDrive via the web browser.
Any hints for me?
Best regards
OLLI
Edited by OLLI_S
Posted
Please follow these simple steps on your Windows 7 PC:
  • Download Enpass from this link.
  • Now open Enpass --> And Restore the data from same OneDrive account which you are using on your Home PC.
If I misunderstood the problem please explain little more so that I can help you better.
Thanks!
  • Like 1
