david Posted February 14, 2019 Report Posted February 14, 2019 I'm not sure this is correct but there are sometimes in-page-popups that are positioned by z-index in the css. So we click "login" and something like a popup, except it's not a separate page, it's more of an overlay. When trying to fill in forms/passwords on these types of situations, enpass tries to fill in something in the background but not on the actual "popup" if that makes sense. Is this possible to fix? I use synologys photo station for my pictures and this is one example where it does not work. I can right click in the username field and choose the password in enpass but nothing happens because enpass doesn't know where the form is I believe..
Anshu kumar Posted February 15, 2019 Report Posted February 15, 2019 Hey @david Sorry for the trouble you are going through. I have noted down this website and notified the dev team to look into it. Till then please co-operate with us.
david Posted February 15, 2019 Author Report Posted February 15, 2019 9 hours ago, Anshu kumar said: Hey @david Sorry for the trouble you are going through. I have noted down this website and notified the dev team to look into it. Till then please co-operate with us. np, I'm just asking if it's possible to fix, it's not a life or death situation =) It would just make enpass, which is already great, even better!
Anshu kumar Posted February 18, 2019 Report Posted February 18, 2019 Hey @david Could you please try saving the login credentials using Save Webform option and try again. To do so please follow these steps: Open the particular website --> Enter the login credentials manually --> Click on Enpass extension icon --> Click on Menu --> Tap Save Webform. Thanks!
david Posted February 18, 2019 Author Report Posted February 18, 2019 I've tried this, it's the same behaviour unfortunately.
Create an account
Register a new accountSign in
Sign In Now
