I want to solve some problems
H.S ROH
 Share
1. Item creation is not possible in Enpass. I tried several times, but it didn't work.
2. Error occurs when attempting to synchronize with Dropbox. The error message is as follows 'Something went wrong while syncing with Dropbox. Error code: 209997 or 204401'
I have reinstalled Enpass, but the problem remains.
Link to comment
Share on other sites
Hey @H.S ROH,
The error code 209997 usually occurs when Enpass doesn't have permissions to write on default location of Enpass database. Please share some more info so that we can help you better.
  • On which device (along with OS version) are you using Enpass?
  • While creating an item what problem are you facing?
  • Have you changed the default location (The default data location is under theUser Document) of Enpass database?
Thanks for your co-operation.
Link to comment
  • 2 weeks later...
I have the same problem, first with OneDrive and then with Dropbox. I have reset Enpass apps (Windows 10, Android 7.0), I have re-created the main vault... but the issue stills.
Windows 10 Pro 1809 17763.316
Enpass 6.0.6 (314)
Android 7.0
Enpass 6.0.6.200
The vault location is the default.
Link to comment
  • 2 weeks later...
 Share
