We’re on Reddit now πŸŽ‰ πŸŽ‰ πŸ’¬ Come and join us there!! Γ—
Posted
Hello,
Having issues with AutoFill (Chrome), for some reason it stopped working.
I have tried to re-install both Enpass and Chrome, with no luck, still doesn't work.
Any suggestions? This is pain in the butt :)
Please advise
Guest Vikram Dabas
Posted
Hi @celavakosa
Sorry to hear that.
Please re-enable the Enpass Autofill options from the app settings and try again. If the problem persists, then share the following details so that we can assist you better:
  • Which Enpass Autofill options have you enabled?
  • Where does the problem occur?
    • The app doesn't show an option to fill the details.
    • App shows the option, but doesn't fill the details.
  • Does the issue occur with a specific webpage or every webpage?
