May 8, 20206 yr Hello, i use enpass on my windows 10 pc (version 6.4.1). On the following sites autofile doesn't work: https://meine.santander.de/login/#/login/ Is that a bug or a fault of mine? cheers Edited May 8, 20206 yr by lesefreudig
May 8, 20206 yr Hey @lesefreudig Welcome to the forum! Thanks for reporting this issue. I have noted down this issue and notified the QA team to look into it. Thanks for your co-operation.
May 12, 20206 yr Hi @lesefreudig & @Leonid Feldman, Sorry for the inconvenience caused to you. Please share the following details so that we can investigate where the problem could be. On which device (along with OS version) are you using Enpass? Which Enpass and Enpass extension version are you using? Which browser are you using? Also, let us know, which part of Autofill is not working. Whether username/password fields are not getting filled or It is not getting auto submitted after filing the login fields? Thanks for your co-operation.
May 13, 20206 yr I am using Google Chrome latest version 81 Enpass 6.4.1 and extension 6.4.0 for chrome Not working Autofill ..
May 13, 20206 yr Hi @Leonid Feldman, Thanks for sharing the details. I have noted down this issue and notified the QA team to look into it.
May 17, 20206 yr Author Okay, here the information: - Windows 10 - Enpass 6.4.1 - Firefox 75.0 - Extension: 6.4.0 - At the Moment the passwort autofill doesnt work; last week was the username the probleme.
May 18, 20206 yr Hey @Leonid Feldman and @lesefreudig Thanks for the patience. We would like to share that the issue has been reproduced by the QA team. Now our Dev team is looking into this issue to resolve and hopefully, a fix will be available in the future update. Thanks for your co-operation.
May 19, 20206 yr Same here. FT.com The Financial Times webpage. Enpass won't put in my email address. I've previously reported this to your team. They said they had duplicated the problem. They said they would like it. But no word yet. It's been a while...
May 20, 20206 yr Hey @Captain_Eric Thanks for notifying us. Notified the same to the team. We are listening to our users and will actively make changes to the app update based on the constructive feedback we have been receiving, so thank you for getting in touch. I shall pass your comments onto our development team. Thanks.
July 28, 20206 yr On 5/20/2020 at 9:09 AM, Garima Singh said: Hey @Captain_Eric Thanks for notifying us. Notified the same to the team. We are listening to our users and will actively make changes to the app update based on the constructive feedback we have been receiving, so thank you for getting in touch. I shall pass your comments onto our development team. Thanks. Still not working. Do you think you fixed it (and I still have a unique problem)? Or have you not gotten to it yet?
July 29, 20206 yr Hey @Captain_Eric Apologies for the inconvenience. This issue is already assigned to the Dev team for a fix and the team is working on the same issue. Your co-operation will be highly appreciated. Thanks for the patience.
August 14, 20206 yr @Leonid Feldman Thanks for getting in touch! We're on the brink of releasing a Beta version for desktops with improved auto-fill functionality across all sites. The beta will tentatively release within a week or two. Meanwhile, an updated stable version of Enpass is available on the iOS and Android stores. If you happen to use Enpass on mobile, you can try auto-filling the login and share your feedback, which we would absorb before the Beta release of desktops.
August 17, 20206 yr I use latest Enpass Portable with Edge Chromium and Autofill not work. I have test many sites but nothing work.
August 18, 20206 yr Hi @Scoty, We are sorry for the inconvenience caused to you. Please revert to us with the answer to the following queries and we will get it sorted out for you: Which Enpass Portable OS version are you using? Which Enpass and Enpass extension version are you using? Which Edge version are you using? Are you facing the same problem with other browsers too? Are you using any Antivirus or third-party security-related extension?
August 18, 20206 yr 6 hours ago, Pratyush Sharma said: Hi @Scoty, We are sorry for the inconvenience caused to you. Please revert to us with the answer to the following queries and we will get it sorted out for you: Which Enpass Portable OS version are you using? Which Enpass and Enpass extension version are you using? Which Edge version are you using? Are you facing the same problem with other browsers too? Are you using any Antivirus or third-party security-related extension? EnpassPortable_6.4.0, Plugin for Edge 6.4.0, Edge 85.0.564.36. I have this on Firefox and Chrome too. I only use Defender on Windows 10. Any you know all have this issues. Automatic Autofill is a big issues on Enpass after weeks.
August 19, 20206 yr Hi @Scoty, Thanks for sharing the details. First, make sure you have correctly installed the extension. Disable and re-enable the autofill option in Enpass Portable settings and try auto-filling again. Also, do you have any other instance of Enpass installation along with Enpass Portable - like Enpass from Microsoft Store etc.? You could also check our user manual for help on auto-fill.
August 20, 20206 yr Hi @Scoty, We have taken note of this and our team is now analyzing into the issue. We will soon share an update.
August 21, 20206 yr Hi @Scoty, Can you please let us know the websites in which you are facing issues in autofill.
August 24, 20206 yr Hey @Scoty Thanks for sharing the details.. I have forwarded your inputs to the QA team. We understand the inconvenience you are having with this and apologies for the same. Please co-operate with us. Thanks for understanding.
August 27, 20206 yr Hey @Scoty Thanks for the patience. Auto-fill through Enpass Browser extension works by manually selecting and double-clicked on the item with which you want to auto-fill as this gives better control if you have multiple items there (and you can peep into there details). However, You can enable "Auto-fill details without showing Enpass Assistant" in Enpass browser settings. Enable this setting to allow Enpass to auto-fill the details using the keyboard shortcut without showing Enpass Assistant. To know how to setup/configure Keyboard shortcut please refer this link. NOTE: Enpass auto-fill the details without showing Enpass Assistant if the particular domain item save in Enpass is only one. For example, in Enpass if the only one Facebook item is saved then you try to auto-fill via keyboard shortcut then it auto-fill without showing assistant. If you have two Facebook item save in Enpass then it only open the Enpass Assistant and you have to manually select and double click on the item to auto-fill. Thanks.
