August 27, 20206 yr Ok thanks. Working with keyboard shortcut i dont like this. Roboform or Bitwarden fill every field without keyboard shortcut too. I hope Enpass can do this too in the Future,
August 27, 20206 yr Hey @Scoty The keyboard shortcut is an alternative way to the auto-fill via double-clicking on the item in Enpass assistant. Thanks!
August 27, 20206 yr Author Hello, now i use 6.5.0 and the misstake is already there! It is frustrating that the issue is still there.. Here is the site: https://meine.santander.de/login/#/login/
August 28, 20206 yr Hey @lesefreudig Thanks for writing back. I have highlighted this problem with my team. We will share an update with you on this pretty soon!
August 29, 20206 yr Author Hi, this Side is also doesnt working:https://access.ing.de/delogin/w/login?t=https://access.ing.de/delogin/oauth/authorize?response_type%3Dcode%26client_id%3Dibbr%26scope%3Dbanking%20paydirekt%20tpa%26state%3D5e-MR-awTYvMyq7ZH5TVoPIrALmVkiF2_nL7YlL2awU%3D%26redirect_uri%3Dhttps://banking.ing.de/app/login/oauth2/code/ibbr I get the message that the password is wrong but that isn't true because if i paste it manuell it works..
September 2, 20206 yr Hi @lesefreudig, Our team has been informed about this. Thanks for your feedback!
September 2, 20206 yr I'm still having problems with Financial Times, which I reported to you many months ago. The precise page is: https://accounts.ft.com/login?location=https%3A%2F%2Fwww.ft.com The "general" webpage is ft.com. Please fix it,
September 2, 20206 yr Also, Enpass fails to fill in the library card and pin at this site. https://mcplmd.overdrive.com/account/ozone/sign-in?forward=%2F&showIdcSignUp=false Please fix it as soon as you can. Thank you in advance. Edited September 2, 20206 yr by Captain_Eric typos
September 3, 20206 yr @Captain_Eric Thanks for sharing the websites. Our team is now looking into this. We will keep you posted on the updates.
September 8, 20206 yr Hey @Leonid Feldman We have found the problem and are now planning for the fix for it. Please stay tuned for the updated version of Enpass. Thanks!
September 14, 20206 yr Hi @Leonid Feldman, We are still working on this issue and will update you once the problem fixes.
