October 6, 20205 yr When I update Enpass to 6.5.1(716) version from the Microsoft Store. Enpass under the high resolution screen,the font has become very small again. But the previous version did not have this problem. Is it possible to fix this issus? Thank you. Edited October 6, 20205 yr by Chernsha
October 7, 20205 yr Hey @Chernsha We are sorry for the inconvenience caused to you. Please have a look at this FAQ for quick troubleshooting and revert to us if the issue still persists. Thanks!
October 8, 20205 yr Garima, The same thing happened when I updated via the Enpass update alert to version 6.5.1 (723). I followed the FAQ and it did the trick with one modification: you have to restart / reboot the machine before the new environment variable will take effect.
October 8, 20205 yr Hey @It is me If the FAQ shared above didn't help you. Could you please share the below details so that we can try to diagnose the issue - The Enpass language you are using? The screenshot of the issue? Windows OS version, scaling factor and the resolution? @wmc Thanks for sharing your inputs.
October 8, 20205 yr Just change the theme and you have the former size again. With 6.5.1 they just made "classic" theme as default and it has small letter. "modern" still has big letters.
October 9, 20205 yr Matis, >> Just change the theme and you have the former size again. With 6.5.1 they just made "classic" theme as default and it has small letter. "modern" still has big letters. << This does not work for version 6.5.1 (723) on the latest version of Windows 10 whereas the environment variable addition does.
October 9, 20205 yr Hey @wmc Apologies for the inconvenience. We have found the problem and are now working towards a fix. Stay tuned for the new updates of Enpass. Thanks!
October 9, 20205 yr 14 hours ago, Garima Singh said: Hey @wmc Apologies for the inconvenience. We have found the problem and are now working towards a fix. Stay tuned for the new updates of Enpass. Thanks! Garima, Great news! Thanks for keeping us informed.
October 11, 20205 yr I have no update for the Enpass version 6.5.1(716) in the German Microsoft Store. I am constantly told that the 6.5.0 (700) is still the latest version I have installed. Could someone from Enpass say something about this?
October 12, 20205 yr Hi @Bob___, There might be some intermittent glitch with the App Store. Could you please try again after some time and if there is still a problem, try signing out and signing in to the App Store. Hope this helps!
