Enpass not in background at system start
Hello,
very often and since 2-3 month, when I unlooking my macOS lookscreen, Enpass is shown in the foreground and asks to unlook (with password or touch ID). Is that a misfunction? What do I need it for? I cannot find a setting to disable this annoying prompt.
Enpass 6.3.3
MacOS 10.15.2
  • Replies 90
  • Views 44.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The  shown in foreground issue is finally fixed in the recent update - v6.7.3 (888) MAS. Yey for that There's still a visible flash from Enpass on the screen everytime I log in, but at least it'
  • Gulshan Dogra
    Gulshan Dogra
    Hi all, Apologies for the delay in responding to your comments. We do monitor all our discussions and this issue is on our priority list. A fix will be available in next week release. Enpass
  • I can confirm that. It seems like a quick fix. I hope it will start invisible after another update.
Posted Images
Hey @someenpassuser,
Welcome to the forums!
This is a strange behaviour. Does this happen when the Mac wakes from sleep or does this happen every time the screen is locked? Meanwhile, we're checking this at our end for further analysis.
Thanks.
  • 1 month later...
Hello @Kashish,
sorry for my late response. I did some checks. I use the Enpass browser extension in Chrome and Firefox (on MacOS). I am very sure (but not 100%) that Chrome causing that prompts. Chrome is very often opened on-focus and not focused, or minimized. When I completely close Chrome the prompts seem not to came up.
Pleas let me know if I can provide logs or do something to get this fixed asap.
Kind Regards
  • 2 weeks later...
Hi @someenpassuser
Thanks for sharing the details.
Please check if you have enabled 'Open automatically at system startup' in the 'General Settings' of Enpass. If yes, please disable the same and share the findings. If the problem still persists, share the screenshot of Enpass 'General Settings'
Thanks.
  • 1 month later...
Hello, since a while I am on the settings you recommended, with same behavior as before. Still the unlook popup comes up after unlook my Mac-Account from lockscreen. (Chrome was in foreground)
Hey @someenpassuser
Please disable the other two options of the 'Run' in the 'General Settings' of Enpass and share the findings with us.
Thanks.
Hi @someenpassuser,
Thanks for writing back in.
Please let us know have you Enable the checkbox in "Are you sure....." pop-up when you restart or shut down the system. If Yes, it is system behavior as the user enables the checkbox while restarting or shutdown, which opens the Enpass application in the foreground.
Hi, I guess we started to not talk about the same thing. I do not mean that this issue comes up after a reboot of the device, it comes up after unlooking the lockscreen. e.g. when you are 10 min away from desk and return, you need to unlook your screen with password/fingerprint. When done, enpass pops up in the foreground. I can confirm that it seems to be caused by chrome browser plugin.
Hey @silv3r23
Thanks for writing to us.
Please close the chrome browser and change the default browser to any other and check if the issue occurs again. If yes, please share the screenshot of Enpass 'General Settings'.
Thanks.
Hello, would that mean that I need to stop my chrome browser?
I know that the issue does not come up when using Firefox. So I have my chrome started with debug enabled but when the popup came up after unlooking the lockscreen, I cannot find something about the extension activity.
cat chrome_debug.log | grep npass
no results
Please tell me how I can collect logs, I think it would be the most efficient way to find the cause.
Hey @someenpassuser
Thanks for the patience.
Please share if Enpass is running in the background when the system sleeps, If yes, is it in focused/open at the back, minimized or what condition?
Thanks for the co-operation.
Hello, I hide/minimize it using CMD+W/CMD+M so its running in the background. Its never focused but it come into foreground when unlooking the lockscreen.
  • 1 month later...
Hello, do you have any status update? Its reproducible with Opera GX (LVL2 (core: 68.0.3618.191)) on Mac OS X 10.15.5 64-bit. Will it be ever fixed?
Hey @someenpassuser
Apologies for the inconvenience. Our Dev team is looking into this issue. Will let you know once we receive any update from the team.
  • 1 month later...
Hello,
I bought this software to unlook premium features but this bug/problem is really annoying. I changed the unlock type from Touch ID (paid feature!) to PIN with having the same problem. Also I changed the shortcut without any result.
Please tell me if it will ever be fixed and when a fix could be expected. Maybe you can provide a suitable workaround. Unfortunately I really have to think about changing the software what I really don't want. Please provide a better flow of updated information.
Thank you!
Hey @someenpassuser
We apologize for it has been pending since long because we haven't been able to reproduce it. Please help us with these details:
  1. What is the device you're using - Mac book, Mac mini or Mac?
  2. Could you share a screen-record of the problem? Maybe, you could use an external camera while you're unlocking the screen.
Meanwhile, we're try to reproduce the same at our end.
Thanks.
  • 1 month later...
Same here on macOS 10.14.6 (Mojave) on an iMac (Retina 5K, 27 inch, 2017, 4,2 GHz Intel Core i7, 40 GB RAM). Quite often when I’m waking the iMac from sleep the small Enpass window (not the main application!) is showing up asking me to unlock like if I was visiting a website needing a password (which I don’t). The window is always showing were the mouse pointer is. The phenomenon suddenly appeared a couple of months ago. Since recently I’m using Safari version 14.0 (14610.1.28.1.9) but the problem occurred already with older versions of Safari.
