December 22, 20205 yr Hi I'm a lifetime subscription member in enpass. For the past week enpass has been malfunctioning with error sync repeatedly. I use enpass mostly on my mobile (android 10) & iPad pro (ipados 14). I'm repeatedly getting a sync error with onedrive and when I select the resolve option it shows that I purposely deleted the enpass file on onedrive and now I have to upload the enpass vault on my device to onedrive. But no matter how many times I do this the same error occurs after sometime. This happens on both my devices. Naturally changes I made in one device did not get synced to the other device. I will attach a few screenshots (had to enable screenshots in the app just for this) to show the error issue. I tried disconnecting onedrive account and re-added and re-authenticated onedrive again on enpass but the issue still remains. This has become a bit of a nightmare. Please resolve this issue as soon as possible. Thank you in advance.
December 23, 20205 yr Author @Garima Singh, @Pratyush Sharmaplease respond to this ASAP and help resolve this issue. App versions : Android Version : 6.5.4.428 IOS version : 6.6 Edited December 23, 20205 yr by harryotaku
December 23, 20205 yr Hi @harryotaku, Sorry for the trouble you are going through. We regret the inconvenience. Please follow the below steps to restore the sync: Take a manual backup of the Enpass data on all the devices. Disconnect the sync on all devices that are synced with Onedrive. Remove the folders Enpass and Enpass1 on One-drive account. Re-set up the sync with One-drive on all the devices and check. If the issue persists, please let us know. Thanks!
February 3, 20215 yr Hello, I've got the same problem on my 3 devices : windows pc, macOS and iOS. Synchonisation failed due to supposedly files deleted from OneDrive... But no files concerning Enpass was deleted... A tempoary fix is to kill EnPass and restart it. Then the synchronisation can be done. But the problem reapears soonafter... I was tired of this, buggy OneDrive Sync so I move to GDrive Sync, and it seems there is no problems anymore... Let's see on the long run... But after abaondonning iCloud Sync because of the iCloud Sync keep expiring problem, I have to abandon OneDrive... Let's hope there will be no problem like this with Gdrive... If this is the case, I'll have to move to another application's passwords.
February 4, 20215 yr Hi @MilesTEG, Apologies for the trouble you are going through. We want to inform you that Microsoft made a change for OneDrive APIs that caused the OneDrive sync problem. Our team has reproduced and identified the issue at our end and is working on it. An update with the fix will be available soon. Till then, we will request you to please co-operate with us. Thanks!
February 5, 20215 yr Hey All, Apologies for the inconvenience. Today, we've released an update with a fix to this issue on all the platforms. Please update the app and let us know if the issue still persists.. Also, if someone doesn't get the latest version as mentioned below, they may get the same in a couple of hours. For Desktops- The latest version is 6.6.0 For mobile- The latest version is 6.6.2 Thanks.
February 5, 20215 yr Hi, can you please update your download links --> on Downloads Enpass | Enpass Download from website mac os still points to an old 6.5 release --> https://dl.enpass.io/stable/mac/package/6.5.1.723/Enpass.pkg
February 6, 20215 yr I'm having the same issue, disconnected both devices, deleted data, reconnected and still says no file that I deleted. Been having this issue for quite some time now and starting to get old, please fix the problem! Edited February 6, 20215 yr by wash
February 7, 20215 yr I had been seeing regular issue with OneDrive sync on Android but v6.6.2.458 appears to have fixed the problem. HOWEVER.. The Windows Desktop version has now started throwing OneDrive sync errors constantly where I was never having issues previously. I have Enpass for Windows v6.6.0 (760), and continually get the "Sync Error. No data found on OneDrive." error I disconnect, then reconnect, and everything is fine for maybe 2-3 mins, and then it happens again. And again. And again. I have also tried disconnecting all devices from OneDrive, deleting the Enpass folders from my OneDrive, and then reconnecting Enpass Desktop to re-populate the files on OneDrive, and then reconnect Enpass Android. Still, the error "Sync Error. No data found on OneDrive" reappears. I'm running Windows 10 Pro v20H2, OS Build 19042.746 Edited February 7, 20215 yr by Anthony additional data
February 9, 20215 yr Hi @Anthony, Sorry for the inconvenience caused to you. Please retry by installing the latest app, version 6.6.770, from Windows Store and let me know if the problem persists? Thanks.
February 11, 20215 yr Hi, I have the same problem, my program version is 6.6.0 (760) and when I make software checking update it found 6.6.0.770 but when I click on "Update now" and open Microsoft Store the store answer me I've already the last version and doesn't let me make any upgrade.
February 12, 20215 yr On 2/9/2021 at 6:10 PM, Pratyush Sharma said: Hi @Anthony, Sorry for the inconvenience caused to you. Please retry by installing the latest app, version 6.6.770, from Windows Store and let me know if the problem persists? Thanks. Thanks @Pratyush Sharma, will do and will let you know how it goes. 10 hours ago, Fabryhorus said: Hi, I have the same problem, my program version is 6.6.0 (760) and when I make software checking update it found 6.6.0.770 but when I click on "Update now" and open Microsoft Store the store answer me I've already the last version and doesn't let me make any upgrade. @Fabryhorus that often happens. It is just lag time between Enpass being submitted to Microsoft Store, and it going through approvals and then able to be seen by us. Give it ~24 hours. I sometimes wonder if it would be less confusing if the app didn't have a direct 'new update available' check that the Enpass team can push content through directly which creates this slightly confusing situation.
February 13, 20215 yr 21 hours ago, Anthony said: @Fabryhorus that often happens. It is just lag time between Enpass being submitted to Microsoft Store, and it going through approvals and then able to be seen by us. Give it ~24 hours. I sometimes wonder if it would be less confusing if the app didn't have a direct 'new update available' check that the Enpass team can push content through directly which creates this slightly confusing situation. OK, make that 48 hours (I'm still not seeing it either). ..and given it is President's Day long weekend in the U.S. it might even be 72 hours..
February 18, 20215 yr Still no sign of the 6.6.0 (770) build in the Microsoft Store for me. @Pratyush Sharma can you advise if there have been any issues/delays with Microsoft Store submission and approval process?
February 19, 20215 yr Hi @Anthony, Sorry for the trouble you are going through. There was some technical glitch which has been fixed now. Could you please check if the problem still persists?
February 20, 20215 yr On 2/19/2021 at 7:00 PM, Pratyush Sharma said: Hi @Anthony, Sorry for the trouble you are going through. There was some technical glitch which has been fixed now. Could you please check if the problem still persists? Still no sign of it. I'll give it another day or two..
February 22, 20215 yr Hey @Anthony Thanks for the patience. Please let us know if the problem still persists.
February 23, 20215 yr 19 hours ago, Garima Singh said: Hey @Anthony Thanks for the patience. Please let us know if the problem still persists. Still no sign of the v6.6.0 (770) update in the Microsoft Store...
February 23, 20215 yr Hey @Anthony Please try updating the Enpass app again from the Microsoft Store and share your findings. Thanks!
February 24, 20215 yr On 2/23/2021 at 11:39 PM, Garima Singh said: Hey @Anthony Please try updating the Enpass app again from the Microsoft Store and share your findings. Thanks! It has finally appeared Will update and provide feedback with regards to the OneDrive sync issues.
February 26, 20215 yr 24 hours of usage and so far no sync errors on any devices (Windows and Android for me)!
May 19, 20215 yr A tempoary fix is to kill EnPass and restart it. Then the synchronisation can be done.But the problem reapears soonafter... spice money login tumangaonline paymanager Edited July 7, 20215 yr by spiceagent11
May 20, 20215 yr Hi @spiceagent11, Welcome to the forums! It would be a great help if you can explain the scenario a bit more. It will help us to clear understanding the problem before further proceeding. If possible, share the screenshot of the error you are getting so we can help you better.
