September 27, 20206 yr Even so I have configured to lock the app only after 30min and „locking when leaving“ is disabled I have to log in all the time. Also when just switching to a different app for seconds. This seems not to work. It would be nice to fix this!
September 28, 20206 yr Hi @Matis, We are working on this issue, and will keep you posted on the status updates.
September 30, 20215 yr I found this thread when searching for the same problem: I’m tired of Enpass on iOS and iPadOS not respecting the Lock After Leaving setting. Specifically, when the setting is set to OFF, the app still locks immediately upon switching to and back from another app. This is highly frustrating, as is seeing that this threat has gone unanswered for a year now. Edited September 30, 20215 yr by MarcS Duplicate posts > 2 separate posts
September 30, 20215 yr I wonder if this bug is not related to the fact that the app “blanks out” the moment you switch to another app and appears so when you browse all your open apps. This is a security option in some apps and is, frankly, useless. There does not appear to be a setting in Enpass to turn that on or off, as in certain other apps. You need to provide a setting to turn that off, too.) Edited September 30, 20215 yr by MarcS Duplicate posts > 2 separate posts
October 18, 20215 yr Hi @Pratyush Sharma. So, it's been a year since: On 9/28/2020 at 4:13 AM, Pratyush Sharma said: We are working on this issue, and will keep you posted on the status updates. Can we please get an update on progress?
November 18, 20214 yr On 10/17/2021 at 7:45 PM, MarcS said: Hi @Pratyush Sharma. So, it's been a year since: Can we please get an update on progress? A month later...
December 26, 20214 yr 43 minutes ago, EnpassQuestions said: It's extremely tedious to enter the master password on an iPad mini This doesn’t solve the main problem which is the topic of this thread, but if your device doesn’t have FaceID (which is the quickest way to unlock Enpass) you can try to set up the PIN unlock option in Enpass Security Settings, which you might find a faster way to unlock than typing the full password. Edited December 26, 20214 yr by MarcS
January 7, 20224 yr Attached are my settings on my iPad running iOS 15(not that it was different last 1.5 years on any iOS software) so why do I have to enter my pin AND again go to where I was even 5 sec later? I’ve complained to support but they offered nothing of any value. Am I missing something here or is it never going to work with my iPad? It’s fine on Mac. Not sure on iPhone. This is what I use it for, on the iPad, more than 50% of the time and so frustrating.
January 7, 20224 yr Hi @JASJ, Welcome to the Enpass community. I would like to share that these settings are applicable till Enpass app is alive in background. If you remove the app from background by swiping away from tasklist/recentlist, or iOS kill it to free the resources, the app is no longer alive. The next launch will be fresh launch and master password will be needed. This is not an issue of Enpass, iOS closes the Enpass due to memory and processor utilization and our team is unable to reproduce this issue and still looking into it. Also, I have added your feedback and it has been forwarded to the concerned team for further investigation. Your patience is highly appreciated. #SI-1959
January 16, 20224 yr Author This is still NOT fixed. Your support is really tiring in some cases. Really anoying things last years to get fixed. Are your really working on it? IOS devices lock immediately, no matter what you enter in the settings.
January 16, 20224 yr Author I played with this feature as it is so anoying. Here what I figured out: If you switch ON "Lock after Leaving" and switch it OFF again, than it does what it is supposed to do. So there seams to be an issue with keeping the setting or with the initial setting. But at least this is a possibility to get is working.
January 22, 20224 yr Author …. And the setting not avoid new login for some time does not work for any app. You always have to log in again. Please fix this. It is really annoying.
January 28, 20224 yr On 1/16/2022 at 10:26 AM, Matis said: If you switch ON "Lock after Leaving" and switch it OFF again, than it does what it is supposed to do. Thanks for the suggestion but it didn't work for me (Enpass 6.7.1 on iOS 15.3): I still have to unlock (I use FaceID) each time in short succession when filling username and password fields.
February 9, 20224 yr Author You are right it works only for starting the app itself, not for logging into websites. it is a pitty that the support is so lousy, some things take for ever to get fixed
February 10, 20224 yr Hi @all, I would like to inform you that this issue has been reproduced on our end, and as per the information shared by our development team, it will be fixed in the future updates of Enpass. As soon as I have any updates regarding the same, I will post them on this forum. In the meantime, we appreciate your co-operation and support.
August 22, 20224 yr @Matis, Apologies for the inconvenience caused. Your feedback has been shared with our backend team for further analysis. As of now, we do not have an ETA for the patch that will resolve this issue. #SI-1959
April 16, 20233 yr Author Still not fixed! You still have to login everytime you want to use Enpass not matter which inactivity timer you have set. It should also for login activities. I'm not even sure why I'm still writing things here, how can issues be open for yours and beeing totally ignored?
February 23, 20242 yr Author Hi, should‘t it be a basic function to do what is selected in the settings? It does totally ignore the setting to lock after x Min. You have to login with each and every usage of Enpass in any application or webpage. This is really very disappointing, especially that it does not get fixed after years.
February 23, 20242 yr Author On 1/7/2022 at 11:30 AM, Gulshan Dogra said: Hi @JASJ, Welcome to the Enpass community. I would like to share that these settings are applicable till Enpass app is alive in background. If you remove the app from background by swiping away from tasklist/recentlist, or iOS kill it to free the resources, the app is no longer alive. The next launch will be fresh launch and master password will be needed. This is not an issue of Enpass, iOS closes the Enpass due to memory and processor utilization and our team is unable to reproduce this issue and still looking into it. Also, I have added your feedback and it has been forwarded to the concerned team for further investigation. Your patience is highly appreciated. #SI-1959 The usage of Enpass UI itself ist not the problem. It is the usage of a password that requires a new log in all the time, even within the specified timeout in settings.
February 26, 20242 yr Our technical team is actively working on a solution. Fixing this bug may take some time, and the resolution will be included in the upcoming updates of the application.
June 26, 20242 yr Hey @Matis we have relesed the updated version of Enpass Website version 6.11.1. Try downloading it from the link below: Enpass Latest version Please try it to see if this resolves the issue and share your feedback with us.
