Not staying unlocked even after Auto-Locking Settings
14 hours ago, Amandeep Kumar said:
Hey @Matis
we have relesed the updated version of Enpass Website version 6.11.1. Try downloading it from the link below:
Please try it to see if this resolves the issue and share your feedback with us.
This is great, it makes it so much more useable! Thanks a lot.
  • 5 months later...
It would be very much appreciated to have the same fix now for IOS.
There is the same problem, it does not remember beeing login already and does not go with the settings. You have to lock in again even after you used it a second before.
  • 3 weeks later...
This issue is now over 4 years old .. i‘m using iPadOS and the constant need to enter the PIN is obnoxious.
  • 2 months later...
Any update? Your ignorance to this topic which is so cumbersome and annoying since years is annoying and disappointing as well!
Our technical team has acknowledged the issue and is actively working on a solution. Fixing this bug may take some time, and the resolution will be included in the upcoming updates of the application.
We appreciate your patience and understanding.
  • 1 month later...
Guys, this is a basic feature of your configuration.
It is so annoying to log in with IOS hundred times and I do not understand how you cannot work on a basic malfunction on your settings.
Even not after years. How should someone recommend Enpass, if stone-old basic bugs get not fixed?
Sorry, I'm just frustrated.
I have the same problem since roughly 2 month. (iPhone 14 Pro, latest iOS, release, latest enpass version)
This is so annoying. I need to enter my Masterpassword ~ 30 times a day.
The last years, the app worked like a charm
  • 2 months later...
Any update?
This is sooooooooooooooooooo anoying and a basic feature.
How can you expect me to pay for additional plans if you are not able to fix bug for important features over years?
I'm really frustrated every day I'm using enpass.
We truly apologize for the inconvenience. The issue turned out to be more complex than expected, but our team is on it. We’re committed to getting this resolved and will keep you posted through this thread. Thanks so much for your patience.
  • 6 months later...
NO PROGRESS ON IOS SINCE 6 YEARS! UNBELIEVABLE! I'M REALY FRUSTRATED AND ANNOYED.
  • 1 month later...
No fix since 6 years. Support for important feature officially in the setting cannot be worse.
  • 4 months later...
